Home » Modeling » EMF » Create 1000 XMI model from one ecore using multi threading
Create 1000 XMI model from one ecore using multi threading [message #677028] Tue, 07 June 2011 11:08 Go to next message
ModelGeek Mising name is currently offline ModelGeek Mising nameFriend
I have ecore model and i want to create 1000 XMI models using threading.
I am using
EOperation.Internal.InvocationDelegate.Factory.Registry.INSTANCE.put(oclDelegateURI,
new OCLInvocationDelegateFactory.Global());
EStructuralFeature.Internal.SettingDelegate.Factory.Registry.INSTANCE.put(oclDelegateURI, new OCLSettingDelegateFactory.Global());
When i create 1000 model in one thread then every thing works fine and it calculates every derived property but when i use multiple threads for less execution time it gives exception in delegation and says concurrent access.
Is the delegation being used is thread safe?
what is right procedure to make it work in multi threaded environment?.
Please help me
Re: Create 1000 XMI model from one ecore using multi threading [message #687153 is a reply to message #677028] Tue, 07 June 2011 16:19 Go to previous message
Ed Willink is currently offline Ed WillinkFriend
See reply on OCL newgroup.
Ed Willink
On 07/06/2011 12:08, forums-noreply@eclipse.org wrote:
> I am using
> concurrent access.
> Please help me
Previous Topic:(no subject)
Next Topic:(no subject)
Current Time: Tue Feb 20 06:09:59 GMT 2018
Powered by FUDForum. Page generated in 0.01237 seconds
