Home » Eclipse Projects » Virgo » Problem registering service
Problem registering service [message #676965] Tue, 07 June 2011 02:26 Go to next message
Barbara Rosi-Schwartz is currently offline Barbara Rosi-Schwartz
Hello.
I am trying to register this OSGi service via Spring DM:
<bean id="bundleInspector"   class="com.iggroup.administrator.business.internal.BundleInspector">
      <property name="bundleContext" ref="bundleContext" />
</bean>
<osgi:service id="bundleInspector" ref="bundleInspector"
      interface="com.iggroup.administrator.api.business.BundleService"/>
where BundleInspector implements BundleService.
However I get the exception below. Any idea what I may be doing wrong?
TIA,
B.
[2011-06-07 07:13:23.291] region-dm-3                  <AG0000E> Application context creation failure for bundle 'com.iggroup.administrator.business' version '0.0.1.SNAPSHOT'. org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'bundleInspector': Invocation of init method failed; nested exception is java.lang.IllegalArgumentException: Exported service object does not implement the given interface: interface org.osgi.framework.ServiceRegistration is not assignable to interface com.iggroup.administrator.api.business.BundleService
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1420)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:519)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456)
	at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:291)
	at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:222)
	at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:288)
	at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:190)
	at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:563)
	at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:895)
	at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.access$1600(AbstractDelegatedExecutionApplicationContext.java:69)
	at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext$4.run(AbstractDelegatedExecutionApplicationContext.java:355)
	at org.springframework.osgi.util.internal.PrivilegedUtils.executeWithCustomTCCL(PrivilegedUtils.java:85)
	at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.completeRefresh(AbstractDelegatedExecutionApplicationContext.java:320)
	at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$CompleteRefreshTask.run(DependencyWaiterApplicationContextExecutor.java:132)
	at org.eclipse.virgo.kernel.agent.dm.ContextPropagatingTaskExecutor$2.run(ContextPropagatingTaskExecutor.java:95)
	at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
	at java.lang.Thread.run(Thread.java:662)
Caused by: java.lang.IllegalArgumentException: Exported service object does not implement the given interface: interface org.osgi.framework.ServiceRegistration is not assignable to interface com.iggroup.administrator.api.business.BundleService
	at org.springframework.util.Assert.isAssignable(Assert.java:368)
	at org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean.afterPropertiesSet(OsgiServiceFactoryBean.java:197)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1477)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1417)
	... 17 common frames omitted
Re: Problem registering service [message #676988 is a reply to message #676965] Tue, 07 June 2011 04:05 Go to previous messageGo to next message
Found my problem (I need to sleep more... Sad
I was using the "id" attribute in the <osgi:service> element, which is wrong. Removing that attribute fixed my issues -- cryptic exception though!
Re: Problem registering service [message #677149 is a reply to message #676965] Tue, 07 June 2011 13:54 Go to previous messageGo to next message
Costin Leau is currently offline Costin Leau
Member
The problem comes from the fact that the service references itself (this can work in advanced cases where a bean is OSGi aware and simply wants to publishes itself (for example for service factories)). However this is not the case and since both beans use the same name (the service and the bean) the last one to be read (the service) overrides the former. And since the interface is not a ServiceReference (required to export a service), the "cryptic" exception is being thrown.
Re: Problem registering service [message #678801 is a reply to message #677149] Thu, 09 June 2011 10:45 Go to previous message
Thanks Costin, your explanation makes it all clear now.
Previous Topic:Virgo 3.0 plan date
Next Topic:Build Virgo Kernel 3.0.0.M05 testing with a bundle
Current Time: Sun May 19 17:36:51 EDT 2013
Powered by FUDForum. Page generated in 0.04234 seconds
