Home » Modeling » TMF (Xtext) » Inheritance in XText
Inheritance in XText [message #676842] Mon, 06 June 2011 17:34 Go to next message
Simon Stratmann is currently offline Simon StratmannFriend
in my language I have a type declaration that looks a bit like:
type myType is
a: integer;
b: integer;
end type;
signal x: myType;
use x.a; //this is the tricky part
I looked in the documentation but didn't find any clues on how to achieve this. a and b aren't seen as exported child objects of x.
Any help would be appreciated.
Simon
Re: Inheritance in XText [message #676856 is a reply to message #676842] Mon, 06 June 2011 18:09 Go to previous messageGo to next message
Andreas   is currently offline Andreas Friend
checkout the part about Local Scoping in the Documentation:
http://www.eclipse.org/Xtext/documentation/1_0_1/xtext.html#scoping
Best Regards
Andreas
Re: Inheritance in XText [message #676862 is a reply to message #676856] Mon, 06 June 2011 18:47 Go to previous messageGo to next message
I did (repeatedly), but I am not sure there's anything that might help me.
Re: Inheritance in XText [message #676873 is a reply to message #676862] Mon, 06 June 2011 19:48 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
without having your grammar it is hard to give you precise advice. if you want to refernce "things" in Xtext these things must have an attribute "name". If this is not the case you have to fix this using a qualified name provider. you often may want to restrict the things visible by some criteria. in your case you want only to see the attributes of myType and not these of other type.
lets asume you have following grammar
Model:
	typs+=Type*
	signals+=Signal*
	usages+=Usage*
enum Datatype : string | integer | boolean;
Type:
	"type" name=ID "is"
		attributes+=Attribute*
	"end" "type" ";";
	Attribute: id=ID ":" type=Datatype ";";
Signal: "signal" name=ID ":" type=[Type] ";";
Usage: "use" signal=[Signal] "." attr=[Attribute] ";";
then a QualifiedNameProvider (bound in the Runtime Module)
public class MyQNP extends DefaultDeclarativeQualifiedNameProvider {
	public String qualifiedName(Attribute a) {
		return a.getId();
and a scopeprovider
public class MyDslScopeProvider extends AbstractDeclarativeScopeProvider {
	public IScope scope_Usage_attr(Usage u, Attribute a) {
		return Scopes.scopeFor(u.getSignal().getType().getAttributes());
might solve your problem Wink
~Christian
Need professional support for Xtext, Xpand, EMF?
Go to: http://xtext.itemis.com
Twitter : @chrdietrich
Blog : christiandietrich.wordpress.com
Re: Inheritance in XText [message #677100 is a reply to message #676873] Tue, 07 June 2011 15:14 Go to previous messageGo to next message
Christian,
thanks for your help! I realize not posting the grammar might make the problem somewhat abstract, but having a pretty complex grammar with more than 1200 lines I thought posting it or even parts of it might confuse more than help. The real grammar is pretty much what you deducted from my example, but I refer to the variable by a FQN. SO I tried your approach with something like this:
Signal:
"signal" name=IDENTIFIER;
QualifiedName:
IDENTIFIER("."IDENTIFIER);
Usage: "use" signal=[Signal|QualifiedName] ("." attr=[Attribute|IDENTIFIER])? ";";
At the same place there can either be a referrance like "use work.a" or "a" (with an ImportScope) but also like "work.a.attribute1".
Because of the QualifiedName-Rule when looking for candidates for the Usage target it will look for something with the QualifiedName "work.a.attribute1" instead of "work.a" and then something with the simple name "attribute1".
Part of my grammar:
refToSimpleName:
	refersTo=[Referrable|QualifiedName]("." rt=record_type)?;
QualifiedName:
	IDENTIFIER ("." IDENTIFIER)*;
record_type:
	name=IDENTIFIER;
record_type_definition:
	"record" ED+=record_type_list+ "end" "record" (ends_record=refToSimpleName)?;
record_type_list :
records+=record_type ("," records+=record_type)*	":" ESD=element_subtype_definition ";";
variable_declaration:
	("shared")? "variable" variables+=variable_name ("," variables+=variable_name)* ":"
	variable_subtype=subtype_indication (":=" E=expression)? ";";
variable_name:
	name=IDENTIFIER;
Referrable:
variable_name;
[Updated on: Tue, 07 June 2011 15:16]
Report message to a moderator
Re: Inheritance in XText [message #677124 is a reply to message #677100] Tue, 07 June 2011 16:10 Go to previous messageGo to next message
can't you simply remove the ambiguity from your grammar?
~Christian
Re: Inheritance in XText [message #677135 is a reply to message #677124] Tue, 07 June 2011 16:44 Go to previous messageGo to next message
Not sure what you mean. If you mean changing the language, nope, it's an already existing language which I need to write an editor for. I've already made a lot of compromises (like not differentiating between between constants and variables and functions, hence the type Referrable).
I'd even go with something like
refersTo=[Referrable|QualifiedName]("." foobar=STRING)?;
or so, but the ? in QualifiedName consumes the whole string and doesn't "leave" anything for the foobar part.
Re: Inheritance in XText [message #677156 is a reply to message #677135] Tue, 07 June 2011 18:12 Go to previous message
what i mean is that the grammar (modified to Usage: "use" signal=[Signal|FQN] ("." attr=[Attribute])? ";"; is ambigous. so what you have here is i want to refernce to a signal or to an attribute (qualified by the signal)
so my grammar works when changed to (similar as your refferable)
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl "http://www.xtext.org/example/mydsl/MyDsl"
Model:
	typs+=Type*
	signals+=Signal*
	usages+=Usage*
FQN: ID ("." ID)*;
Type:
	"type" name=ID "is"
	"end" "type" ";";
Signal: "signal" name=FQN ":" type=[Type] ";";
SignalOrAttribute : Signal | Attribute;
Usage: "use" {Usage} ref=[SignalOrAttribute|FQN] ";";
and fixing the local scoping
	@Inject
	IQualifiedNameProvider nameProvider;
	public IScope scope_Usage_ref(Usage u, EReference r) {
		List<IEObjectDescription> objects = new ArrayList<IEObjectDescription>();
		Model m = EcoreUtil2.getContainerOfType(u, Model.class);
		for (Signal s : m.getSignals()) {
			objects.add(EObjectDescription.create(nameProvider.getQualifiedName(s), s));
			for (Attribute a : s.getType().getAttributes()) {
				objects.add(EObjectDescription.create(nameProvider.getQualifiedName(s) + "." + a.getId(), a));
		return new SimpleScope(IScope.NULLSCOPE, objects);
~Christian
Previous Topic:EClass from Ecore model in xtext runtime editor
Next Topic:navigating through an importURI statement
Current Time: Sun Jan 21 04:45:23 GMT 2018
Powered by FUDForum. Page generated in 0.02145 seconds
