Re: Noob questions [message #672332 is a reply to message #670303] |
Fri, 20 May 2011 17:40 |
Quote:In a Use Case diagram, I add the actors and use cases but where to I put the narratives? In a comment? What is the intent here?
If you want to put in the model the narrative, you need to associate a comment. I could be usefull for model transformation...
But if you want to associate a file for example a doc word, you can click on the small green plus at left bottom of your selected element and choose tab "document hyperlink" then add it.
The Save option in the File menu is never active. This appears to be bug 337122. Kind of basic!
it is stange, I will read the associated bug
When a papyrus perspective is selected, the Update Software option in the help menu disappears. Is this by design?
the papyrus perspective hides all menus that are declared as " we want to see". this is in the perspective to not complexify it use by the adding of all possible menu and actions.
So we need only to add it in our configuration.
Where are the release notes? I'm using version 0.8.0v201103161726.
I do not think so. I will verified with sebastien
I realize that I can't be of much help since I am new to this but if there is something I can do, please let me know.
Your comments are welcome, but we need to be more reactive in this forum
FUDForum. Page generated in 0.03510 seconds
