Home » Eclipse Projects » DSDP - Mobile Tools for Java (MTJ) » canot start wtk emulator within eclipse
canot start wtk emulator within eclipse [message #670133] Thu, 12 May 2011 18:52 Go to next message
Hofer  is currently offline Hofer Friend
Hello everybody, i've just installed Java_ME_platform_SDK_3.0 on my XP machine and i use eclipse helios with the eclipseme 1.7.9 for developing midlets. now, when i start a simple midlet with the emulator for my nokia device (S60_3rd_FP2_SDK_v1.1) the nokia emulator comes up and start the midlet. but when i choose the Java_ME_platform_SDK_3.0 as emulator i got the following output:
-Xdebug Use a remote debugger
-Xrunjdwp:[transport=<transport>,address=<address>,server= <y/n>
suspend=<y/n>]
Debugging options
-Xdevice:<device> Select a device skin for the emulator
-Xdomain:<domain_name>
Set the MIDlet suite's security domain
-Xquery Print device information
-Xjam[:install=<JAD file url> | force | list | storageNames |
run=[<storage name> | <storage number>] |
remove=[<storage name> | <storage number> | all]]
Java Application Manager and support
for Over The Air provisioning (OTA)
-Xautotest:<JAD file url>
Run in autotest mode
-Xdescriptor:<JAD file name>
The JAD file to be executed
any ideas how i can start the emulator directly from inside eclipse?
Re: canot start wtk emulator within eclipse [message #670256 is a reply to message #670133] Fri, 13 May 2011 09:10 Go to previous message
I found a solution. in the run configurations select MIDlet and in the group Executable you must select either JAD URL or Over the Air.
Previous Topic:'Create Obfuscated Package' is suddenly away
Next Topic:Corrupt JAR, error while reading: midlet/MIDlet.class
Current Time: Fri Jun 22 15:35:31 GMT 2018
Powered by FUDForum. Page generated in 0.01620 seconds
