Home » Eclipse Projects » EGit / JGit » authentication fails after password change
authentication fails after password change [message #669364] Tue, 10 May 2011 05:43 Go to next message
Henrik Rentz-Reichert is currently offline Henrik Rentz-ReichertFriend
I'm using Eclipse's secure storage and this worked fine until eclipse.org forced me to change my password.
Now accessing my git repository aborts with
An internal Exception occured during push: https://git.eclipse.org/gitroot/etrice/org.eclipse.etrice.gi t: not authorized
I would expect a prompt for correct credentials in this case.
Also I wasn't able to change the password in the secure storage.
How can I tell EGit to use my new password?
Henrik
Re: authentication fails after password change [message #673230 is a reply to message #669364] Sun, 22 May 2011 23:28 Go to previous messageGo to next message
Matthias Sohn is currently offline Matthias SohnFriend
Yeah, this shouldn't raise an ugly error but prompt for credentials, please file a bug here [1].
In order to change credentials try the following:
Open Git repositories view, open "Remotes > origin > <your push url>" and click "Change Credentials..."
[1] https://bugs.eclipse.org/bugs/enter_bug.cgi?product=EGit
Re: authentication fails after password change [message #736150 is a reply to message #673230] Thu, 13 October 2011 16:54 Go to previous messageGo to next message
Eike Stepper is currently offline Eike StepperFriend
Am 23.05.2011 01:28, schrieb Matthias Sohn:
Has a bug been filed? I'm experiencing the same problem ;-(
Cheers
/Eike
http://www.esc-net.de
Re: authentication fails after password change [message #1418896 is a reply to message #736150] Sun, 07 September 2014 20:59 Go to previous messageGo to next message
Ajit Dingankar is currently offline Ajit DingankarFriend
I had the same problem (after all the years Wink so I filed a bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=443471
Using the workaround suggested by Matthias Sohn in the meanwhile;
thanks, Matthias!
Ajit
Re: authentication fails after password change [message #1419911 is a reply to message #1418896] Tue, 09 September 2014 08:37 Go to previous message
which EGit version are you using ?
Previous Topic:Configure... dialog for fetch shows wrong remote
Next Topic:Custom merge commit message
Current Time: Sat Jan 20 01:15:02 GMT 2018
Powered by FUDForum. Page generated in 0.01558 seconds
