Home » Modeling » EMF » Re: [Teneo] Unable to use addEntity with Teneo generated code
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669197 is a reply to message #669181] Mon, 09 May 2011 12:49 Go to next message
Martin Taal is currently offline Martin TaalFriend
Hi David,
The query uses 2 aliases ins and ins_1_, I am not sure where this second alias is defined as the query does not show to
which table it applies. I guess it is a table which is joined to instrument some how, so ins_1_.instrument would be the
fk to instrument.
Does this sound familiar with anything in your model?
gr. Martin
On 05/09/2011 02:18 PM, David Wynter wrote:
> I found the work around bug 241537
> added this
> hbds.getExtensionManager().registerExtension(EntityNameStrat egy.class.getName(),EntityInterfaceNameStrategy.class.getNam e());
> And modifying my query slightly to allow for the lowercase table name
> SQLQuery query = session.createSQLQuery("SELECT {ins.*} FROM \"instrument\" {ins}").addEntity("ins", Instrument.class);
> I had forgotten to add all my 'favourite' Persistance Options. A dooh on my part.
> props.setProperty(PersistenceOptions.MAXIMUM_SQL_NAME_LENGTH , "28");
> props.setProperty(PersistenceOptions.ID_FEATURE_AS_PRIMARY_K EY, "true");
> props.setProperty(PersistenceOptions.DEFAULT_ID_FEATURE_NAME , "id");
> props.setProperty(PersistenceOptions.JOIN_COLUMN_NAMING_STRA TEGY, "simple");
> props.setProperty(PersistenceOptions.JOIN_TABLE_FOR_NON_CONT AINED_ASSOCIATIONS, "false");
> props.setProperty(PersistenceOptions.ALSO_MAP_AS_CLASS, "false");
> props.setProperty(PersistenceOptions.DISABLE_ECONTAINER_MAPP ING, "true");
> props.setProperty(PersistenceOptions.ALWAYS_VERSION, "false");
> props.setProperty(PersistenceOptions.ALWAYS_MAP_LIST_AS_BAG, "true");
> props.setProperty(PersistenceOptions.INHERITANCE_MAPPING, "JOINED");
> props.setProperty(PersistenceOptions.XSDDATE_CLASS, "java.util.Date");
> //ManyToOne and OneToMany are normally fetch eagerly, only if you do SET_PROXY=true then these are set to lazy
> props.setProperty(PersistenceOptions.SET_PROXY, "true");
> However still not out of the woods I now get
> Column "INS_1_.instrument" not found; SQL statement:
> SELECT ins."id" as id1_182_0_, ins."listmethodtype" as listmeth2_182_0_, ins."marketstatus_type" as marketst3_182_0_,
> ins."marketstatus_id" as marketst4_182_0_, ins."instrumentformtype" as instrume5_182_0_, ins."tradingrestrictiontype" as
> tradingr6_182_0_, ins."benchmarkstrategy" as benchmar7_182_0_, ins."contractvaluemultiplier" as contract8_182_0_,
> ins."createdate" as createdate9_182_0_, ins."defaultclause" as default10_182_0_, ins."firstamount" as firstam11_182_0_,
> ins."firstdate" as firstdate12_182_0_, ins."firstdealingdate" as firstde13_182_0_, ins."firsteventvalue" as
> firstev14_182_0_, ins."firstsettlementdate" as firstse15_182_0_, ins."isprimary" as isprimary16_182_0_, ins."lastamount"
> as lastamount17_182_0_, ins."lastdate" as lastdate18_182_0_, ins."lasteventvalue" as lasteve19_182_0_,
> ins."marketderivedinfperiddration" as marketd20_182_0_, ins."marketderivedinfoperiodend" as marketd21_182_0_,
> ins."marketderivedinfoperiodstart" as marketd22_182_0_, ins."modifieddate" as modifie23_182_0_, ins."name" as
> name24_182_0_, ins."nextamount" as nextamount25_182_0_, ins."nexteventvalue" as nexteve26_182_0_, ins."numberholders" as
> numberh27_182_0_, ins."numberholdersdatetime" as numberh28_182_0_, ins."nmberholderspreviousdatetime" as
> nmberho29_182_0_, ins."objective" as objective30_182_0_, ins."penultimateamount" as penulti31_182_0_,
> ins."penultimatedate" as penulti32_182_0_, ins."principalpaymentend" as princip33_182_0_, ins."principalpaymentstart" as
> princip34_182_0_, ins."purchasingminimums" as purchas35_182_0_, ins."qualifiedplans" as qualifi36_182_0_,
> ins."recurrable" as recurrable37_182_0_, ins."shortname" as shortname38_182_0_, ins."issuer" as issuer39_182_0_,
> ins_1_."instrument" as instrument2_396_0_, ins_1_."calculationtype" as calculat3_396_0_, ins_1_."indicatorstype" as
> indicato4_396_0_, ins_1_."fxratecalctype" as fxrateca5_396_0_, ins_1_."settlementtype" as settleme6_396_0_,
> ins_1_."quantitydescriptiontype" as quantity7_396_0_, ins_1_."quantitytype" as quantity8_396_0_, ins_1_."unittype" as
> unittype9_396_0_, ins_1_."cashtype" as cashtype10_396_0_, ins_1_."valuationtype" as valuati11_396_0_,
> ins_1_."adjustedquantity" as adjuste12_396_0_, ins_1_."allocatepercent" as allocat13_396_0_, ins_1_."basevalue" as
> basevalue14_396_0_, ins_1_."capvalue" as capvalue15_396_0_, ins_1_."cashamount" as cashamount16_396_0_,
> ins_1_."componentvalue" as compone17_396_0_, ins_1_."currentvalue" as current18_396_0_, ins_1_."dirtyprice" as
> dirtyprice19_396_0_, ins_1_."endprice" as endprice20_396_0_, ins_1_."endvalue" as endvalue21_396_0_, ins_1_."fxrate" as
> fxrate22_396_0_, ins_1_."multiplier" as multiplier23_396_0_, ins_1_."price" as price24_396_0_, ins_1_."quantity" as
> quantity25_396_0_, ins_1_."startvalue" as startvalue26_396_0_, ins_1_."valuationref" as valuati27_396_0_,
> ins_1_."weighting" as weighting28_396_0_, case when ins_1_."cm_exmpl_mddbym_instrment_id" is not null then 1 when
> ins."id" is not null then 0 end as clazz_0_ FROM "instrument" ins [42122-146]
> There is no instrument column and I am wondering why it is looking for one?
> David
> On 09/05/11 13:02, David Wynter wrote:
>> I have used Teneo to build a large SQL database from an Annotated XSD. I
>> use Hibernate with Scalars to query the same database, this all works
>> fine. I now need to try to grab some entities from the database and use
>> them in a foreign key relationship associated with the persistence of a
>> related Entity.
>> But I am getting an exception on this
>> SQLQuery query = session.createSQLQuery("SELECT {ins.*} FROM Instrument
>> List instruments = query.list();
>> I get
>> "Unknown entity: com.example.mddbyam.Instrument"
>> I am running this in a JUnit test case and have done what is asked here
>> http://wiki.eclipse.org/Teneo/Hibernate/Download_and_Install #Teneo.2C_import-packages_and_ClassNotFoundException_when_ru nning_junit_testcaseshave
>> added the
>> So I figure maybe I need a mapping file? I know it is supposed to do it
>> in memory, but clearly something is wrong there?
>> I use the Teneo menu on the ecore file associated with my xsd source for
>> the schema and try to generate a mapping file I get this.
>> An internal error occurred during: "Generate Mapping File".
>> java.lang.NullPointerException
>> I have previously tried
>> Query qury = session.createQuery("FROM Instrument");
>> But that fails because I do not have a VERSION column, and it seems to
>> expect it.
>> I just want all Instrument in the Db so I can later do a
>> "relatedEntity.setInstrument(instr);"
>> I am using Hibernate 3.6 with Teneo 1.1.2 V201101061255 plugin
>> Ideas?
>> Thx.
>> David
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669198 is a reply to message #669181] Mon, 09 May 2011 12:49 Go to previous messageGo to next message
Hi David,
fk to instrument.
gr. Martin
> added this
> David
>> related Entity.
>> I get
>> added the
>> expect it.
>> Ideas?
>> Thx.
>> David
The Netherlands
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669203 is a reply to message #669181] Mon, 09 May 2011 12:49 Go to previous messageGo to next message
Hi David,
fk to instrument.
gr. Martin
> added this
> David
>> related Entity.
>> I get
>> added the
>> expect it.
>> Ideas?
>> Thx.
>> David
The Netherlands
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669204 is a reply to message #669197] Mon, 09 May 2011 13:11 Go to previous messageGo to next message
David Wynter is currently offline David WynterFriend
OK, I realise that I had added an extension for Instrument
Like so:
<xsd:complexType name="Underlying">
<xsd:complexContent>
<xsd:extension base="mddbyam:Instrument">
It seems to be getting the Underlying attributes in the projection but
not including the table in the table list. My preference is not to get
the extension columns. Does this mean I cannot use the xsd:extension
element type?
Thx.
David
On 09/05/11 13:49, Martin Taal wrote:
> Hi David,
> alias is defined as the query does not show to which table it applies. I
> ins_1_.instrument would be the fk to instrument.
> gr. Martin
>> added this
>> on my part.
>> "simple");
>> "false");
>> [42122-146]
>> one?
>> David
>>> Hi,
>>> related Entity.
>>> I get
>>> added the
>>> expect it.
>>> Ideas?
>>> Thx.
>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669227 is a reply to message #669204] Mon, 09 May 2011 14:22 Go to previous messageGo to next message
Hmm this seems like a Hibernate bug, right? The table should be listed in the from (joined to the main table). How does
the generated hbm look like?
If you don't want Underlying to be mapped at all then you should add @Transient to the complexType as an annotation.
If Underlying is mapped then it is difficult to prevent Hibernate from fetching the columns, as it does not know upfront
what type to instantiate without getting the subclass columns.
gr. Martin
> Like so:
> It seems to be getting the Underlying attributes in the projection but not including the table in the table list. My
> preference is not to get the extension columns. Does this mean I cannot use the xsd:extension element type?
> Thx.
> David
>> Hi David,
>> gr. Martin
>>> Hi,
>>> added this
>>> on my part.
>>> "simple");
>>> "false");
>>> [42122-146]
>>> one?
>>> David
>>>> Hi,
>>>> related Entity.
>>>> I get
>>>> added the
>>>> expect it.
>>>> Ideas?
>>>> Thx.
>>>> David
The Netherlands
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669256 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
Yes this seems like a Hibernate bug to me. I hate the way they presume I
would want the subclass (if that is what you end up with when using the
xsd:Extension) every time and give me no option to prevent Hibernate
fetching it.
I had that NPE when I tried to generate the hbm, see the original email.
In the end using JDBCTemplate was a much simpler solution, so given my
time constraints I abandoned Hibernate.
Thx. for your advice.
David
> in the from (joined to the main table). How does the generated hbm look
> like?
> fetching the columns, as it does not know upfront what type to
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669260 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669261 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669263 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669266 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669269 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669277 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669285 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669286 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669290 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669292 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669294 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669300 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669304 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669308 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669310 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669313 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669314 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669315 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669316 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669317 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669319 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669323 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669326 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669329 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669330 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669332 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669333 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669334 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669335 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669336 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669337 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669338 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669339 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669342 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669343 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669346 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669347 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669348 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669349 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669350 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669351 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669352 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669353 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669354 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669355 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669356 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669359 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669361 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669363 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669367 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669375 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669378 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669382 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669388 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669389 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669407 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669408 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669409 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> [42122-146]
>>>> one?
>>>> David
>>>>> Hi,
>>>>> XSD. I
>>>>> use
>>>>> of a
>>>>> related Entity.
>>>>> Instrument
>>>>> I get
>>>>> here
>>>>> added the
>>>>> do it
>>>>> source for
>>>>> expect it.
>>>>> Ideas?
>>>>> Thx.
>>>>> David
Re: [Teneo] Unable to use addEntity with Teneo generated code [message #669411 is a reply to message #669227] Mon, 09 May 2011 15:29 Go to previous message
fetching it.
David
> like?
> gr. Martin
>> Like so:
>> Thx.
>> David
>>> Hi David,
>>> gr. Martin
>>>> Hi,
>>>> added this
>>>> on my part.
>>>> "true");
>>>> "simple");
>>>> "false");
>>>> "true");
>>>> ins_1_."adjus
