Home » Eclipse Projects » Plugin Development Environment (PDE) » Headless build problem in
Headless build problem in [message #668630] |
Fri, 06 May 2011 14:01 |
Mikael Petterson Messages: 158 Registered: July 2009 |
I am trying to do a headless build of our eclipse plugin. It does all the copying correct and compiles classes.
But it seems to be something with the packaging. I cannot figure it out.
Any ideas?
br,
//mike
build.properties:
# Copyright (c) 2003, 2009 IBM Corporation and others.
# All rights reserved. This program and the accompanying materials
# are made available under the terms of the Eclipse Public License v1.0
# which accompanies this distribution, and is available at
# http://www.eclipse.org/legal/epl-v10.html
# Contributors:
# IBM Corporation - initial API and implementation
# Parameters describing how and where to execute the build.
# Typical users need only update the following properties:
# baseLocation - where things you are building against are installed
# bootclasspath - The base jars to compile against (typicaly rt.jar)
# configs - the list of {os, ws, arch} configurations to build.
# Of course any of the settings here can be overridden by spec'ing
# them on the command line (e.g., -DbaseLocation=d:/eclipse
eclipseLocation=C:/eclipse-java-helios-SR1-win32/eclipse
#The type of the top level element we are building, generally "feature"
topLevelElementType = feature
#The id of the top level element we are building
topLevelElementId =
############# PRODUCT/PACKAGING CONTROL #############
#product=/net.sourceforge.eclipseccase/helloworld.product //mike: Since we are not using an RCP product.
runPackager=true
#Set the name of the archive that will result from the product build.
#archiveNamePrefix=
# The prefix that will be used in the generated archive.
archivePrefix=eclipseccase
# The location underwhich all of the build output will be collected.
collectingFolder=${archivePrefix}
# The list of {os, ws, arch} configurations to build. This
# value is a '&' separated list of ',' separate triples. For example,
# configs=win32,win32,x86 & linux,motif,x86
# By default the value is *,*,*
configs = *, *, *
#configs=win32, win32, x86
# win32,win32,x86_64 & \
# win32,win32,wpf & \
# linux, gtk, ppc & \
# linux, gtk, x86 & \
# linux, gtk, x86_64 & \
# linux, motif, x86 & \
# solaris, motif, sparc & \
# solaris, gtk, sparc & \
# aix, motif, ppc & \
# hpux, motif, ia64_32 & \
# macosx, carbon, ppc & \
# macosx, carbon, x86 & \
# macosx, cocoa, ppc & \
# macosx, cocoa, x86 & \
# macosx, cocoa, x86_64
# By default PDE creates one archive (result) per entry listed in the configs property.
# Setting this value to true will cause PDE to only create one output containing all
# artifacts for all the platforms listed in the configs property.
# To control the output format for the group, add a "group, group, group - <format>" entry to the
# archivesFormat.
#groupConfigurations=true
#The format of the archive. By default a zip is created using antZip.
#The list can only contain the configuration for which the desired format is different than zip.
#archivesFormat=win32, win32, x86 - antZip& \
# linux, gtk, ppc - antZip &\
# linux, gtk, x86 - antZip& \
# linux, gtk, x86_64 - antZip& \
# linux, motif, x86 - antZip& \
# solaris, motif, sparc - antZip& \
# solaris, gtk, sparc - antZip& \
# aix, motif, ppc - antZip& \
# hpux, motif, PA_RISC - antZip& \
# macosx, carbon, ppc - antZip
#Allow cycles involving at most one bundle that needs to be compiled with the rest being binary bundles.
allowBinaryCycles = true
#Sort bundles depenedencies across all features instead of just within a given feature.
#flattenDependencies = true
#Parallel compilation, requires flattenedDependencies=true
#parallelCompilation=true
#parallelThreadCount=
#parallelThreadsPerProcessor=
#Set to true if you want the output to be ready for an update jar (no site.xml generated)
#outputUpdateJars = false
#Set to true for Jnlp generation
#codebase should be a URL that will be used as the root of all relative URLs in the output.
#generateJnlp=false
#jnlp.codebase=<codebase url>
#jnlp.j2se=<j2se version>
#jnlp.locale=<a locale>
#jnlp.generateOfflineAllowed=true or false generate <offlineAllowed/> attribute in the generated features
#jnlp.configs=${configs} #uncomment to filter the content of the generated jnlp files based on the configuration being built
#Set to true if you want to sign jars
#signJars=false
#sign.alias=<alias>
#sign.keystore=<keystore location>
#sign.storepass=<keystore password>
#sign.keypass=<key password>
#Arguments to send to the zip executable
zipargs=
#Arguments to send to the tar executable
tarargs=
#Control the creation of a file containing the version included in each configuration - on by default
#generateVersionsLists=false
############## BUILD NAMING CONTROL ################
# The directory into which the build elements are fetched and where
# the build takes place.
buildDirectory=${user.home}/eclipse.build
# Type of build. Used in naming the build output. Typically this value is
# one of I, N, M, S, ...
buildType=I
# ID of the build. Used in naming the build output.
buildId=HelloWorld
# Label for the build. Used in naming the build output
buildLabel=${buildType}.${buildId}
# Timestamp for the build. Used in naming the build output
timestamp=007
#The value to be used for the qualifier of a plugin or feature when you want to override the value computed by pde.
#The value will only be applied to plugin or features indicating build.properties, qualifier = context
#forceContextQualifier=<the value for the qualifier>
#Enable / disable the generation of a suffix for the features that use .qualifier.
#The generated suffix is computed according to the content of the feature
#generateFeatureVersionSuffix=true
############# BASE CONTROL #############
# Settings for the base Eclipse components and Java class libraries
# against which you are building.
# Base location for anything the build needs to compile against. For example,
# in most RCP app or a plug-in, the baseLocation should be the location of a previously
# installed Eclipse against which the application or plug-in code will be compiled and the RCP delta pack.
base=c:/net.sourceforge.eclipseccase-base
baseLocation=${base}/target/eclipse
#Folder containing repositories whose content is needed to compile against
repoBaseLocation=${base}/repos
#Folder where the content of the repositories from ${repoBaseLocation} will be made available as a form suitable to be compiled against
transformedRepoLocation=${buildDirectory}/transformedRepos
#Os/Ws/Arch/nl of the eclipse specified by baseLocation
baseos=win32
basews=win32
basearch=x86
#this property indicates whether you want the set of plug-ins and features to be considered during the build to be limited to the ones reachable from the features / plugins being built
filteredDependencyCheck=false
#this property indicates whether the resolution should be done in development mode (i.e. ignore multiple bundles with singletons)
resolution.devMode=false
#pluginPath is a list of locations in which to find plugins and features. This list is separated by the platform file separator (; or :)
#a location is one of:
#- the location of the jar or folder that is the plugin or feature : /path/to/foo.jar or /path/to/foo
#- a directory that contains a /plugins or /features subdirectory
#- the location of a feature.xml, or for 2.1 style plugins, the plugin.xml or fragment.xml
#pluginPath=
skipBase=true
eclipseURL=<url for eclipse download site>
eclipseBuildId=<Id of Eclipse build to get>
eclipseBaseURL=${eclipseURL}/eclipse-platform-${eclipseBuildId}-win32.zip
############# MAP FILE CONTROL ################
# This section defines CVS tags to use when fetching the map files from the repository.
# If you want to fetch the map file from repository / location, change the getMapFiles target in the customTargets.xml
skipMaps=true
mapsRepo=:pserver:anonymous@example.com/path/to/repo
mapsRoot=path/to/maps
mapsCheckoutTag=HEAD
#tagMaps=true
mapsTagTag=v${buildId}
############ REPOSITORY CONTROL ###############
# This section defines properties parameterizing the repositories where plugins, fragments
# bundles and features are being obtained from.
# The tags to use when fetching elements to build.
# By default thebuilder will use whatever is in the maps.
# This value takes the form of a comma separated list of repository identifier (like used in the map files) and the
# overriding value
# For example fetchTag=CVS=HEAD, SVN=v20050101
# fetchTag=HEAD
skipFetch=true
############# JAVA COMPILER OPTIONS ##############
# The location of the Java jars to compile against. Typically the rt.jar for your JDK/JRE
#bootclasspath=${java.home}/lib/rt.jar
# specific JRE locations to compile against. These values are used to compile bundles specifying a
# Bundle-RequiredExecutionEnvironment. Uncomment and set values for environments that you support
#CDC-1.0/Foundation-1.0= /path/to/rt.jar
#CDC-1.1/Foundation-1.1=
#OSGi/Minimum-1.0=
#OSGi/Minimum-1.1=
#JRE-1.1=
#J2SE-1.2=
#J2SE-1.3=
#J2SE-1.4=
#J2SE-1.5=
#JavaSE-1.6=
#PersonalJava-1.1=
#PersonalJava-1.2=
#CDC-1.0/PersonalBasis-1.0=
#CDC-1.0/PersonalJava-1.0=
#CDC-1.1/PersonalBasis-1.1=
#CDC-1.1/PersonalJava-1.1=
# Specify the output format of the compiler log when eclipse jdt is used
logExtension=.log
# Whether or not to include debug info in the output jars
javacDebugInfo=false
# Whether or not to fail the build if there are compiler errors
javacFailOnError=true
# Enable or disable verbose mode of the compiler
javacVerbose=true
# Extra arguments for the compiler. These are specific to the java compiler being used.
#compilerArg=
# Default value for the version of the source code. This value is used when compiling plug-ins that do not set the Bundle-RequiredExecutionEnvironment or set javacSource in build.properties
javacSource=1.5
# Default value for the version of the byte code targeted. This value is used when compiling plug-ins that do not set the Bundle-RequiredExecutionEnvironment or set javacTarget in build.properties.
javacTarget=1.5
Build log:
Buildfile: C:\Users\mike\opensource\net.sourceforge.eclipseccase.build\build.xml
clean:
[delete] Deleting directory C:\Users\mike\eclipse.build
init:
[mkdir] Created dir: C:\Users\mike\eclipse.build
[mkdir] Created dir: C:\Users\mike\eclipse.build\plugins
[mkdir] Created dir: C:\Users\mike\eclipse.build\features
[copy] Copying 642 files to C:\Users\mike\eclipse.build\plugins
[copy] Copying 11 files to C:\Users\mike\eclipse.build\features
pde-build:
[java] Buildfile: C:\eclipse-java-helios-SR1-win32\eclipse\plugins\org.eclipse.pde.build_3.6.1.R36x_v20100823/scripts/productBuild/productBuild.xml
[java] main:
[java] preBuild:
[java] preSetup:
[java] checkLocalMaps:
[java] getMapFiles:
[java] postSetup:
[java] checkLocalBase:
[java] getBaseComponents:
[java] processRepos:
[java] preProcessRepos:
[java] allElements:
[java] allElementsDelegator:
[java] transformRepos:
[java] postProcessRepos:
[java] generateFeature:
[java] fetch:
[java] [eclipse.generateFeature] Some inter-plug-in dependencies have not been satisfied.
[java] [eclipse.generateFeature] Bundle net.sourceforge.eclipseccase:
[java] [eclipse.generateFeature] Missing required plug-in org.eclipse.core.resources_0.0.0.
[java] [eclipse.generateFeature] Missing required plug-in org.eclipse.team.core_0.0.0.
[java] [eclipse.generateFeature] Bundle net.sourceforge.eclipseccase.ui:
[java] [eclipse.generateFeature] Missing required plug-in net.sourceforge.eclipseccase_0.0.0.
[java] [eclipse.generateFeature] Missing required plug-in org.eclipse.ui.ide_0.0.0.
[java] [eclipse.generateFeature] Missing required plug-in org.eclipse.team.ui_0.0.0.
[java] [eclipse.generateFeature] Missing required plug-in org.eclipse.ui.console_0.0.0.
[java] [eclipse.generateFeature] Missing required plug-in org.eclipse.ui.forms_0.0.0.
[java] [eclipse.generateFeature] Missing required plug-in org.eclipse.compare_0.0.0.
[java] [eclipse.generateFeature] Bundle org.eclipse.core.filesystem.hpux.ia64_32:
[java] [eclipse.generateFeature] Host plug-in org.eclipse.core.filesystem_[1.0.0,2.0.0) has not been found.
[java] [eclipse.generateFeature] Bundle org.eclipse.core.filesystem.linux.ppc:
[java] [eclipse.generateFeature] Host plug-in org.eclipse.core.filesystem_[1.1.0,2.0.0) has not been found.
[java] [eclipse.generateFeature] Bundle org.eclipse.core.filesystem.linux.x86:
[java] [eclipse.generateFeature] Bundle org.eclipse.core.filesystem.linux.x86_64:
[java] [eclipse.generateFeature] Bundle org.eclipse.core.filesystem.macosx:
[java] [eclipse.generateFeature] Bundle org.eclipse.core.filesystem.solaris.sparc:
[java] [eclipse.generateFeature] Bundle org.eclipse.core.filesystem.win32.x86:
[java] [eclipse.generateFeature] Bundle org.eclipse.core.net.linux.x86:
[java] [eclipse.generateFeature] Host plug-in org.eclipse.core.net_1.1.0 has not been found.
[java] [eclipse.generateFeature] Bundle org.eclipse.core.net.win32.x86:
[java] [eclipse.generateFeature] Bundle org.eclipse.core.resources.win32.x86:
[java] [eclipse.generateFeature] Host plug-in org.eclipse.core.resources_[3.4.0,3.5.0) has not been found.
[java] [eclipse.generateFeature] Bundle org.eclipse.equinox.launcher.win32.win32.x86:
[java] [eclipse.generateFeature] Bundle org.eclipse.equinox.security.macosx:
[java] [eclipse.generateFeature] Host plug-in org.eclipse.equinox.security_[1.0.0,2.0.0) has not been found.
[java] [eclipse.generateFeature] Bundle org.eclipse.equinox.security.win32.x86:
[java] [eclipse.generateFeature] Bundle org.eclipse.jdt.launching.macosx:
[java] [eclipse.generateFeature] Missing required plug-in org.eclipse.debug.core_0.0.0.
[java] [eclipse.generateFeature] Missing required plug-in org.eclipse.jdt.debug_0.0.0.
[java] [eclipse.generateFeature] Missing required plug-in org.eclipse.jdt.core_0.0.0.
[java] [eclipse.generateFeature] Missing required plug-in org.eclipse.jdt.launching_0.0.0.
[java] [eclipse.generateFeature] Missing required plug-in org.eclipse.jdt.ui_0.0.0.
[java] [eclipse.generateFeature] Bundle org.eclipse.swt.win32.win32.x86:
[java] [eclipse.generateFeature] Bundle org.eclipse.ui.win32:
[java] [eclipse.generateFeature] Host plug-in org.eclipse.ui.ide_[3.2.0,4.0.0) has not been found.
[java] [eclipse.generateFeature] Bundle org.eclipse.update.core.linux:
[java] [eclipse.generateFeature] Host plug-in org.eclipse.update.core_[3.0.0,4.0.0) has not been found.
[java] [eclipse.generateFeature] Bundle org.eclipse.update.core.win32:
[java] generate:
[java] preGenerate:
[java] allElements:
[java] init:
[java] generateScript:
[java] [eclipse.buildScript] Some inter-plug-in dependencies have not been satisfied.
[java] [eclipse.buildScript] Bundle net.sourceforge.eclipseccase:
[java] [eclipse.buildScript] Missing required plug-in org.eclipse.core.resources_0.0.0.
[java] [eclipse.buildScript] Missing required plug-in org.eclipse.team.core_0.0.0.
[java] [eclipse.buildScript] Bundle net.sourceforge.eclipseccase.ui:
[java] [eclipse.buildScript] Missing required plug-in net.sourceforge.eclipseccase_0.0.0.
[java] [eclipse.buildScript] Missing required plug-in org.eclipse.ui.ide_0.0.0.
[java] [eclipse.buildScript] Missing required plug-in org.eclipse.team.ui_0.0.0.
[java] [eclipse.buildScript] Missing required plug-in org.eclipse.ui.console_0.0.0.
[java] [eclipse.buildScript] Missing required plug-in org.eclipse.ui.forms_0.0.0.
[java] [eclipse.buildScript] Missing required plug-in org.eclipse.compare_0.0.0.
[java] [eclipse.buildScript] Bundle org.eclipse.core.filesystem.hpux.ia64_32:
[java] [eclipse.buildScript] Host plug-in org.eclipse.core.filesystem_[1.0.0,2.0.0) has not been found.
[java] [eclipse.buildScript] Bundle org.eclipse.core.filesystem.linux.ppc:
[java] [eclipse.buildScript] Host plug-in org.eclipse.core.filesystem_[1.1.0,2.0.0) has not been found.
[java] [eclipse.buildScript] Bundle org.eclipse.core.filesystem.linux.x86:
[java] [eclipse.buildScript] Bundle org.eclipse.core.filesystem.linux.x86_64:
[java] [eclipse.buildScript] Bundle org.eclipse.core.filesystem.macosx:
[java] [eclipse.buildScript] Bundle org.eclipse.core.filesystem.solaris.sparc:
[java] [eclipse.buildScript] Bundle org.eclipse.core.filesystem.win32.x86:
[java] [eclipse.buildScript] Bundle org.eclipse.core.net.linux.x86:
[java] [eclipse.buildScript] Host plug-in org.eclipse.core.net_1.1.0 has not been found.
[java] [eclipse.buildScript] Bundle org.eclipse.core.net.win32.x86:
[java] [eclipse.buildScript] Bundle org.eclipse.core.resources.win32.x86:
[java] [eclipse.buildScript] Host plug-in org.eclipse.core.resources_[3.4.0,3.5.0) has not been found.
[java] [eclipse.buildScript] Bundle org.eclipse.equinox.launcher.win32.win32.x86:
[java] [eclipse.buildScript] Bundle org.eclipse.equinox.security.macosx:
[java] [eclipse.buildScript] Host plug-in org.eclipse.equinox.security_[1.0.0,2.0.0) has not been found.
[java] [eclipse.buildScript] Bundle org.eclipse.equinox.security.win32.x86:
[java] [eclipse.buildScript] Bundle org.eclipse.jdt.launching.macosx:
[java] [eclipse.buildScript] Missing required plug-in org.eclipse.debug.core_0.0.0.
[java] [eclipse.buildScript] Missing required plug-in org.eclipse.jdt.debug_0.0.0.
[java] [eclipse.buildScript] Missing required plug-in org.eclipse.jdt.core_0.0.0.
[java] [eclipse.buildScript] Missing required plug-in org.eclipse.jdt.launching_0.0.0.
[java] [eclipse.buildScript] Missing required plug-in org.eclipse.jdt.ui_0.0.0.
[java] [eclipse.buildScript] Bundle org.eclipse.swt.win32.win32.x86:
[java] [eclipse.buildScript] Bundle org.eclipse.ui.win32:
[java] [eclipse.buildScript] Host plug-in org.eclipse.ui.ide_[3.2.0,4.0.0) has not been found.
[java] [eclipse.buildScript] Bundle org.eclipse.update.core.linux:
[java] [eclipse.buildScript] Host plug-in org.eclipse.update.core_[3.0.0,4.0.0) has not been found.
[java] [eclipse.buildScript] Bundle org.eclipse.update.core.win32:
[java] postGenerate:
[java] clean:
[java] allElements:
[java] init:
[java] cleanElement:
[java] [echo] C:\Users\mike/eclipse.build/features/org.eclipse.pde.build.container.feature
[java] init:
[java] clean:
[java] init:
[java] all.features:
[java] init:
[java] clean:
[java] all.plugins:
[java] update.feature:
[java] all.children:
[java] process:
[java] preProcess:
[java] allElements:
[java] init:
[java] processElement:
[java] processViaFeature:
[java] init:
[java] build.jars:
[java] init:
[java] init:
[java] build.jars:
[java] all.plugins:
[java] processFlat:
[java] postProcess:
[java] assemble:
[java] preAssemble:
[java] allElements:
[java] init:
[java] assembleElement:
[java] main:
[java] defaultAssemble:
[java] main:
[java] [mkdir] Created dir: C:\Users\mike\eclipse.build\I.HelloWorld
[java] [mkdir] Created dir: C:\Users\mike\eclipse.build\tmp
[java] gather.bin.parts:
[java] init:
[java] [subant] Failure for target 'rootFiles*_*_*' of: C:\net.sourceforge.eclipseccase-base\target\eclipse\features\org.eclipse.equinox.executable_3.3.101.R34x_v20080805-7H-ELeE8hXnkE15Wh9Rz0yu\build.xml
[java] [subant] The following error occurred while executing this line:
[java] [subant] Target "rootFiles*_*_*" does not exist in the project "org.eclipse.platform.launchers".
[java] customAssembly:
[java] jar.processing:
[java] generate.p2.metadata:
[java] assemble.archive:
[java] BUILD FAILED
[java] C:\eclipse-java-helios-SR1-win32\eclipse\plugins\org.eclipse.pde.build_3.6.1.R36x_v20100823\scripts\productBuild\productBuild.xml:44: The following error occurred while executing this line:
[java] C:\eclipse-java-helios-SR1-win32\eclipse\plugins\org.eclipse.pde.build_3.6.1.R36x_v20100823\scripts\build.xml:118: The following error occurred while executing this line:
[java] C:\eclipse-java-helios-SR1-win32\eclipse\plugins\org.eclipse.pde.build_3.6.1.R36x_v20100823\templates\headless-build\customTargets.xml:12: The following error occurred while executing this line:
[java] C:\eclipse-java-helios-SR1-win32\eclipse\plugins\org.eclipse.pde.build_3.6.1.R36x_v20100823\scripts\productBuild\allElements.xml:20: The following error occurred while executing this line:
[java] C:\eclipse-java-helios-SR1-win32\eclipse\plugins\org.eclipse.pde.build_3.6.1.R36x_v20100823\scripts\genericTargets.xml:186: The following error occurred while executing this line:
[java] C:\Users\mike\eclipse.build\assemble.org.eclipse.pde.build.container.feature.all.xml:25: The following error occurred while executing this line:
[java] C:\Users\mike\eclipse.build\assemble.org.eclipse.pde.build.container.feature.all.xml:15: The following error occurred while executing this line:
[java] C:\eclipse-java-helios-SR1-win32\eclipse\plugins\org.eclipse.pde.build_3.6.1.R36x_v20100823\scripts\productBuild\allElements.xml:35: The following error occurred while executing this line:
[java] C:\Users\mike\eclipse.build\assemble.org.eclipse.pde.build.container.feature.xml:99: The following error occurred while executing this line:
[java] C:\Users\mike\eclipse.build\assemble.org.eclipse.pde.build.container.feature.xml:118: C:\Users\mike\eclipse.build\tmp\eclipseccase\ANY.ANY.ANY\eclipseccase not found.
[java] Total time: 14 seconds
[java] An error has occurred. See the log file
[java] C:\Users\mike\workspace\.metadata\.log.
BUILD FAILED
C:\Users\mike\opensource\net.sourceforge.eclipseccase.build\build.xml:73: Java returned: 13
Total time: 32 seconds
Current Time: Thu Apr 25 16:59:51 GMT 2024
Powered by FUDForum. Page generated in 0.03289 seconds
