Home » Newcomers » Newcomers » Class not found exception for JUnit
Class not found exception for JUnit [message #668531] Fri, 06 May 2011 06:33 Go to next message
Vishal  is currently offline Vishal Friend
I have been trying to execute for Junit s in eclipse environment.
I have been running the Junit as follows :
Right Click on Junit Test file -> Run As -> Junit Test
On the console I get the error
Class not found packagename.MyJunitTest
java.lang.ClassNotFoundException: packagename.MyJUnitTest
at java.net.URLClassLoader$1.run(URLClassLoader.java:202)
at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301 )
at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.loadC lass(RemoteTestRunner.java:683)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.loadC lasses(RemoteTestRunner.java:425)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:445)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:673)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:386)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main( RemoteTestRunner.java:196)
Basically it is complaining that it is not able to find the JUnit class file which I am trying to execute.
Java Build path is also set as follows :
Build Path -> Configure Build Path -> Java Build Path -> Source tab
Default Output Folder :
FullPathOfTheProject/target/classes
Any Help here would be appreciated.
Thanks and Regards,
Vishal
Re: Class not found exception for JUnit [message #668610 is a reply to message #668531] Fri, 06 May 2011 12:21 Go to previous messageGo to next message
Russell Bateman is currently offline Russell BatemanFriend
Is MyJUnitTest.java in the same folder as the source code you're trying
to test? If not, is it nevertheless in a folder that is or whose parent
is a Source Folder?
On 2011.05.06 0:33, Vishal wrote:
> Hi, I have been trying to execute for Junit s in eclipse environment.
> I have been running the Junit as follows : Right Click on Junit Test
> at java.security.AccessController.doPrivileged(Native Method)
> Thanks and Regards, Vishal
Re: Class not found exception for JUnit [message #668620 is a reply to message #668610] Fri, 06 May 2011 12:53 Go to previous message
(Sorry got distracted...)
Did you also ensure that you have the JUnit JARs in your project (via
Build Path)? I can't see your project, obviously, so I can only ask dumb
questions in an effort to help. Sorry if I'm not being much help.
> is a Source Folder?
>> [snip]
Previous Topic:delete me
Next Topic:Error adding a CVS repository
Current Time: Mon Jan 22 12:39:11 GMT 2018
Powered by FUDForum. Page generated in 0.03004 seconds
