Home » Newcomers » Newcomers » Error adding a CVS repository(Error adding a CVS repository)
Error adding a CVS repository [message #668516] Fri, 06 May 2011 00:43 Go to next message
Richard Poulsen is currently offline Richard PoulsenFriend
I'm trying to go through the Eclipse tutorials and am stuck on the Team CVS tutorial. I have XP and set up CVS on my machine, but am unable to add the new CVS Repository. The error I get is Error validating location: "Could not connect to :pserver:anonymous@RICK1:c:/test_repository: Cannot connect to host: Connection refused: connect". I've tried disabling my firewall temporarily, with no change. There is virtually nothing on the web that explains to a new user how to set up Eclipse and CVS on a local machine.
[Updated on: Fri, 06 May 2011 00:44]
Report message to a moderator
Re: Error adding a CVS repository [message #668642 is a reply to message #668516] Fri, 06 May 2011 14:08 Go to previous message
Eric Rizzo is currently offline Eric RizzoFriend
On 5/5/11 8:43 PM, Richard Poulsen wrote:
> I'm trying to go through the Eclipse tutorials and sm stuck on the Team
> CVS tutorial. I've set up CVS on my machine, but am unable to add the
> not connect to :pserver:mailto:anonymous@RICK1:c:/test_repository:
1) When you "set up CVS" on your machine, did that include running the
pserver to accept connections?
2) The repository location probably shouldn't include mailto:. It should
be formatted like
:pserver:anonymous@hostname:path
3) I'm not sure what repository paths for CVS on Windows generally look
like, but the c:/ looks suspicious to me.
4) Is RICK1 the host name of your machine? I'd stick with locahost or
127.0.0.1
Eric
Previous Topic:Class not found exception for JUnit
Next Topic:Locale for Android
Current Time: Tue May 22 10:29:06 GMT 2018
Powered by FUDForum. Page generated in 0.03193 seconds
