Home » Eclipse Projects » BIRT » Reports,Subreports and cell borders(How do You line up subreport cell borders)
Reports,Subreports and cell borders [message #668142] Wed, 04 May 2011 01:20 Go to next message
Chris  is currently offline Chris
Member
I have been trying to line up cell borders in a table and in a subreport which is a row in the table.
Table has 2 detail rows
Row 1 has 4 cells each of which has a border surrounding it.
Row 2 has merged all 4 cells and contains the subreport table which consists of 4 cells with borders.
The borders from the 1st row need to line up with the borders from subreport in the second row.
I have tried setting padding to 0 in both tables and all cells and all rows.
Setting the cell width to the same in both tables still does not line them up.
Trying to line them up by eye is not working. My report is output to PDF.
All help would be appreciated.
Chris
Re: Reports,Subreports and cell borders [message #668243 is a reply to message #668142] Wed, 04 May 2011 11:43 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
Chris
Can you reproduce this issue with the sample db? Use orders for the
outer and orderdetails for the inner.
If you can post the report.
Jason
On 5/4/2011 1:20 AM, Chris wrote:
> Table has 2 detail rows Row 1 has 4 cells each of which has a border
> surrounding it.
> rows.
> them up.
> Chris
Jason Weathersby
BIRT Exchange
Re: Reports,Subreports and cell borders [message #668522 is a reply to message #668243] Fri, 06 May 2011 00:09 Go to previous messageGo to next message
Member
Thanks Jason,
I have created a quick report. To me it has 2 issues
1. there is a gap between the orders row and the detail rows.
2. The left and right sides of the columns do not line up exactly.
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.22" id="1">
<property name="createdBy">Eclipse BIRT Designer Version 2.6.1.v20100902 Build &lt;2.6.1.v20100915-1750></property>
<property name="units">in</property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<property name="imageDPI">96</property>
<data-sources>
<oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source" id="7">
<list-property name="privateDriverProperties">
<ex-property>
<name>contentBidiFormatStr</name>
<value>ILYNN</value>
</ex-property>
<ex-property>
<name>metadataBidiFormatStr</name>
</ex-property>
</list-property>
<property name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet " name="Orders" id="8">
<list-property name="columnHints">
<structure>
<property name="columnName">ORDERNUMBER</property>
<text-property name="displayName">ORDERNUMBER</text-property>
<text-property name="heading">ORDERNUMBER</text-property>
</structure>
<structure>
<property name="columnName">ORDERDATE</property>
<text-property name="displayName">ORDERDATE</text-property>
<text-property name="heading">ORDERDATE</text-property>
</structure>
<structure>
<property name="columnName">REQUIREDDATE</property>
<text-property name="displayName">REQUIREDDATE</text-property>
<text-property name="heading">REQUIREDDATE</text-property>
</structure>
<structure>
<property name="columnName">SHIPPEDDATE</property>
<text-property name="displayName">SHIPPEDDATE</text-property>
<text-property name="heading">SHIPPEDDATE</text-property>
</structure>
<structure>
<property name="columnName">COMMENTS</property>
<text-property name="displayName">COMMENTS</text-property>
<text-property name="heading">COMMENTS</text-property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">ORDERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">ORDERDATE</property>
<property name="dataType">date</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">REQUIREDDATE</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">SHIPPEDDATE</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">COMMENTS</property>
<property name="dataType">string</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">ORDERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">ORDERDATE</property>
<property name="nativeDataType">91</property>
</structure>
<structure>
<property name="nativeName">REQUIREDDATE</property>
</structure>
<structure>
<property name="nativeName">SHIPPEDDATE</property>
</structure>
<structure>
<property name="nativeName">COMMENTS</property>
<property name="nativeDataType">12</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select CLASSICMODELS.ORDERS.ORDERNUMBER
,CLASSICMODELS.ORDERS.ORDERDATE
,CLASSICMODELS.ORDERS.REQUIREDDATE
,CLASSICMODELS.ORDERS.SHIPPEDDATE
,CLASSICMODELS.ORDERS.COMMENTS
from CLASSICMODELS.ORDERS]]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml version="1.0" encoding="UTF-8"?>
<model:DesignValues xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design" xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>ORDERNUMBER</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>ORDERDATE</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>91</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>ORDERDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERDATE</design:label>
<design:displaySize>10</design:displaySize>
<design:attributes>
<design:name>REQUIREDDATE</design:name>
<design:position>3</design:position>
<design:uiHints>
<design:displayName>REQUIREDDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>REQUIREDDATE</design:label>
<design:attributes>
<design:name>SHIPPEDDATE</design:name>
<design:position>4</design:position>
<design:uiHints>
<design:displayName>SHIPPEDDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>SHIPPEDDATE</design:label>
<design:attributes>
<design:name>COMMENTS</design:name>
<design:position>5</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>32700</design:precision>
<design:uiHints>
<design:displayName>COMMENTS</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>COMMENTS</design:label>
<design:displaySize>32700</design:displaySize>
</design:resultSetColumns>
<design:criteria/>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>
]]></xml-property>
</oda-data-set>
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet " name="OrderLines" id="9">
<structure>
</structure>
<structure>
<property name="columnName">PRODUCTCODE</property>
<text-property name="displayName">PRODUCTCODE</text-property>
<text-property name="heading">PRODUCTCODE</text-property>
</structure>
<structure>
<property name="columnName">QUANTITYORDERED</property>
<text-property name="displayName">QUANTITYORDERED</text-property>
<text-property name="heading">QUANTITYORDERED</text-property>
</structure>
<structure>
<property name="columnName">PRICEEACH</property>
<text-property name="displayName">PRICEEACH</text-property>
<text-property name="heading">PRICEEACH</text-property>
</structure>
</list-property>
<list-property name="parameters">
<structure>
<property name="name">porderno</property>
<property name="nativeName"></property>
<expression name="defaultValue" type="javascript">10100</expression>
<property name="isOptional">true</property>
<property name="allowNull">true</property>
<property name="isInput">true</property>
<property name="isOutput">false</property>
</structure>
</list-property>
<structure>
</structure>
<structure>
<property name="name">PRODUCTCODE</property>
</structure>
<structure>
<property name="name">QUANTITYORDERED</property>
</structure>
<structure>
<property name="name">PRICEEACH</property>
<property name="dataType">float</property>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
<property name="nativeName">PRODUCTCODE</property>
</structure>
<structure>
<property name="nativeName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="nativeName">PRICEEACH</property>
<property name="nativeDataType">8</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select CLASSICMODELS.ORDERDETAILS.ORDERNUMBER
,CLASSICMODELS.ORDERDETAILS.PRODUCTCODE
,CLASSICMODELS.ORDERDETAILS.QUANTITYORDERED
,CLASSICMODELS.ORDERDETAILS.PRICEEACH
from CLASSICMODELS.ORDERDETAILS
where CLASSICMODELS.ORDERDETAILS.ORDERNUMBER=?]]></xml-property>
<design:DataSetParameters>
<design:parameterDefinitions>
<design:inOutMode>In</design:inOutMode>
<design:attributes>
<design:name></design:name>
<design:inputAttributes>
<design:elementAttributes>
<design:optional>true</design:optional>
</design:elementAttributes>
</design:inputAttributes>
</design:parameterDefinitions>
</design:DataSetParameters>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:name>PRODUCTCODE</design:name>
<design:precision>15</design:precision>
<design:uiHints>
<design:displayName>PRODUCTCODE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRODUCTCODE</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>QUANTITYORDERED</design:name>
<design:uiHints>
<design:displayName>QUANTITYORDERED</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>QUANTITYORDERED</design:label>
<design:attributes>
<design:name>PRICEEACH</design:name>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>PRICEEACH</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRICEEACH</design:label>
<design:displaySize>22</design:displaySize>
<design:criteria/>
]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
<style name="report" id="4">
<property name="fontFamily">sans-serif</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab-cell" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="6">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="10">
<property name="dataSet">Orders</property>
<list-property name="boundDataColumns">
<structure>
<expression name="expression" type="javascript">dataSetRow["ORDERNUMBER"]</expression >
</structure>
<structure>
<expression name="expression" type="javascript">dataSetRow["ORDERDATE"]</expression>
</structure>
<structure>
<expression name="expression" type="javascript">dataSetRow["REQUIREDDATE"]</expression >
</structure>
<structure>
<expression name="expression" type="javascript">dataSetRow["SHIPPEDDATE"]</expression >
</structure>
<structure>
<expression name="expression" type="javascript">dataSetRow["COMMENTS"]</expression>
</structure>
</list-property>
<list-property name="sort">
<structure>
<expression name="key" type="javascript">row["ORDERNUMBER"]</expression>
<property name="direction">asc</property>
<property name="strength">-1</property>
</structure>
</list-property>
<column id="39"/>
<column id="40"/>
<column id="41"/>
<column id="42"/>
<header>
<row id="11">
<cell id="12">
<label id="13">
<text-property name="text">ORDERNUMBER</text-property>
</label>
</cell>
<cell id="14">
<label id="15">
<text-property name="text">ORDERDATE</text-property>
</label>
</cell>
<cell id="16">
<label id="17">
<text-property name="text">REQUIREDDATE</text-property>
</label>
</cell>
<cell id="18">
<label id="19">
<text-property name="text">SHIPPEDDATE</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="22">
<cell id="23">
<property name="borderBottomColor">#000000</property>
<property name="borderBottomWidth">thin</property>
<property name="borderLeftColor">#000000</property>
<property name="borderLeftWidth">thin</property>
<property name="borderRightColor">#000000</property>
<property name="borderRightWidth">thin</property>
<property name="borderTopColor">#000000</property>
<property name="borderTopWidth">thin</property>
<property name="paddingTop">0pt</property>
<property name="paddingLeft">0pt</property>
<property name="paddingBottom">0pt</property>
<property name="paddingRight">0pt</property>
<data id="24">
<property name="whiteSpace">nowrap</property>
<property name="resultSetColumn">ORDERNUMBER</property>
</data>
</cell>
<cell id="25">
<data id="26">
<property name="resultSetColumn">ORDERDATE</property>
</data>
</cell>
<cell id="27">
<data id="28">
<property name="resultSetColumn">REQUIREDDATE</property>
</data>
</cell>
<cell id="29">
<data id="30">
<property name="resultSetColumn">SHIPPEDDATE</property>
</data>
</cell>
</row>
<row id="44">
<cell id="45">
<property name="colSpan">4</property>
<property name="rowSpan">1</property>
<table id="50">
<property name="dataSet">OrderLines</property>
<list-property name="paramBindings">
<structure>
<property name="paramName">porderno</property>
<simple-property-list name="expression">
<value type="javascript">row["ORDERNUMBER"]</value>
</simple-property-list>
</structure>
</list-property>
<structure>
</structure>
<structure>
<expression name="expression" type="javascript">dataSetRow["PRODUCTCODE"]</expression >
</structure>
<structure>
<expression name="expression" type="javascript">dataSetRow["QUANTITYORDERED"]</expression >
</structure>
<structure>
<expression name="expression" type="javascript">dataSetRow["PRICEEACH"]</expression>
</structure>
</list-property>
<structure>
</structure>
<structure>
<expression name="key" type="javascript">row["PRODUCTCODE"]</expression>
</structure>
</list-property>
<column id="74"/>
<column id="75"/>
<column id="76"/>
<column id="77"/>
<detail>
<row id="60">
<cell id="61">
<data id="62">
</data>
</cell>
<cell id="63">
<data id="64">
<property name="resultSetColumn">PRODUCTCODE</property>
</data>
</cell>
<cell id="65">
<data id="66">
<property name="resultSetColumn">QUANTITYORDERED</property>
</data>
</cell>
<cell id="67">
<data id="68">
<property name="resultSetColumn">PRICEEACH</property>
</data>
</cell>
</row>
</detail>
</table>
</cell>
</row>
</detail>
</table>
</body>
</report>
Re: Reports,Subreports and cell borders [message #668664 is a reply to message #668522] Fri, 06 May 2011 11:41 Go to previous message
You still had 1 in the padding for the cell containing the detail row.
Take a look at the revised example.
Jason
id="1">
<data-sources>
<oda-data-source
id="7">
<ex-property>
</ex-property>
<ex-property>
</ex-property>
</list-property>
<property
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
<structure>
<text-property
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
<text-property
</structure>
<structure>
<text-property
<text-property
</structure>
<structure>
<text-property
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<model:DesignValues
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:criteria/>
</model:DesignValues>]]></xml-property>
</oda-data-set>
<oda-data-set
<structure>
<text-property
<text-property
</structure>
<structure>
<text-property
<text-property
</structure>
<structure>
<text-property
<text-property
</structure>
<structure>
<text-property
</structure>
</list-property>
<structure>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<model:DesignValues
<design:attributes>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:criteria/>
</oda-data-set>
</data-sets>
<styles>
</style>
</style>
</style>
</styles>
<page-setup>
<page-footer>
<text id="3">
<text-property
</text>
</page-footer>
</page-setup>
<body>
<table id="10">
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
</list-property>
<structure>
</structure>
</list-property>
<column id="39"/>
<column id="40"/>
<column id="41"/>
<column id="42"/>
<header>
<row id="11">
<cell id="12">
<property
<label id="13">
<text-property
</label>
</cell>
<cell id="14">
<property
<label id="15">
<text-property
</label>
</cell>
<cell id="16">
<property
<label id="17">
<text-property
</label>
</cell>
<cell id="18">
<property
<label id="19">
<text-property
</label>
</cell>
</row>
</header>
<detail>
<row id="22">
<cell id="23">
<property
<data id="24">
<property
</data>
</cell>
<cell id="25">
<property
<data id="26">
<property
</data>
</cell>
<cell id="27">
<property
<data id="28">
<property
</data>
</cell>
<cell id="29">
<property
<data id="30">
<property
</data>
</cell>
</row>
<row id="44">
<cell id="45">
<property name="textAlign">left</property>
<table id="50">
<structure>
<property
name="expression">
<value
</structure>
</list-property>
<structure>
<property
<text-property
<property
</structure>
<structure>
<property
<text-property
<property
</structure>
<structure>
<property
<text-property
<property
</structure>
<structure>
<property
<text-property
<property
</structure>
</list-property>
<structure>
<property
</structure>
<structure>
<property
</structure>
</list-property>
<column id="74"/>
<column id="75"/>
<column id="76"/>
<column id="77"/>
<detail>
<row id="60">
<cell id="61">
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<data id="62">
<property
<property
</data>
</cell>
<cell id="63">
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<data id="64">
<property
<property
</data>
</cell>
<cell id="65">
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<data id="66">
<property
<property
</data>
</cell>
<cell id="67">
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<property
<data id="68">
<property
<property
</data>
</cell>
</row>
</detail>
</table>
</cell>
</row>
</detail>
</table>
</body>
</report>
On 5/6/2011 12:09 AM, Chris wrote:
> Thanks Jason,
> id="1">
> Build <2.6.1.v20100915-1750></property>
> <data-sources>
> <ex-property>
> </ex-property>
> <ex-property>
> </ex-property>
> </list-property><
Jason Weathersby
BIRT Exchange
Previous Topic:Forecasting with a simple linear regression in BIRT?
Next Topic:how to set a datetime parameter default to 11:59:59 pm
Current Time: Sun May 19 11:19:36 EDT 2013
Powered by FUDForum. Page generated in 0.01806 seconds
