Home » Modeling » EMF » createPropertyEditor for EReferenceImpl(choiceOfValues not limited to selected reference class)
createPropertyEditor for EReferenceImpl [message #668083] Tue, 03 May 2011 12:51 Go to next message
Jay Norwood is currently offline Jay Norwood
I have a model with an attribute which is an EReference to a single selected class type. The class is derived from an abstract class, but in this case I have selected only a single particular class for the EReference, and wish to select only a single instance of that explicit class as the assigned value. Right clicking on the property sheet line creates a list named choiceOfValues in PropertyDescriptor:createPropertyEditor. It gets into the section handling an EStructuralFeature, and the feature is an EReferenceImpl. The problem I'm seeing is that there are items other than the particular referenced class being added to the list.
I'll need to generate a small example ecore that demonstrates the problem. Is this a known issue or limitation? I didn't find discussion.
Re: createPropertyEditor for EReferenceImpl [message #668111 is a reply to message #668083] Tue, 03 May 2011 15:06 Go to previous messageGo to next message
This is the small test case ecore model, which is intended to limit assignment of the refinstance attribute with a reference to a Leaf1Type.
<ecore:EPackage xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="refbug"
nsURI="http:///refbug.ecore" nsPrefix="refbug">
<eClassifiers xsi:type="ecore:EClass" name="Root" eSuperTypes="#//Node">
<eStructuralFeatures xsi:type="ecore:EReference" name="children" upperBound="-1"
eType="#//InnerOrLeaf" containment="true" resolveProxies="false"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Inner" eSuperTypes="#//Leaf1Type">
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Leaf1Type" eSuperTypes="#//InnerOrLeaf">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="leafId" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EInt"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="InnerOrLeaf" abstract="true" eSuperTypes="#//Node"/>
<eClassifiers xsi:type="ecore:EClass" name="Node" abstract="true">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="label" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Leaf2Type" eSuperTypes="#//InnerOrLeaf">
<eStructuralFeatures xsi:type="ecore:EReference" name="Vars" upperBound="-1" eType="#//VStruct"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="VStruct">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="refinstance" lowerBound="1"
eType="#//Leaf1Type"/>
</eClassifiers>
</ecore:EPackage>
This shows that an assignment was allowed of an refbug Inner type to refinstance, and in fact the Inner instance in1 was selected from the dropdown list. This also validates, which I find surprising. I would have expected refinstance dropdown to contain only the Leaf1Type, labeled lf1.
<refbug:Root xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:refbug="http:///refbug.ecore">
<children xsi:type="refbug:Inner" label="in1">
<children xsi:type="refbug:Leaf1Type" label="lf1"/>
<children xsi:type="refbug:Leaf2Type" label="lf2">
<Vars name="vs1" refinstance="//@children.0"/>
</children>
</children>
</refbug:Root>
Re: createPropertyEditor for EReferenceImpl, Never Mind [message #668125 is a reply to message #668083] Tue, 03 May 2011 17:00 Go to previous message
This was totally my fault. Error in the ecore model. Should have been below. Works as it should.
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Inner" eSuperTypes="#//InnerOrLeaf">
</eClassifiers>
</eClassifiers>
</eClassifiers>
</eClassifiers>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name" lowerBound="1" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</eClassifiers>
</ecore:EPackage>
Previous Topic:[EMF Query2] Issue with alias in an or textual query
Next Topic:generate specific xmi ids for eobjects
Current Time: Tue May 21 21:24:02 EDT 2013
Powered by FUDForum. Page generated in 0.01884 seconds
