Home » Modeling » TMF (Xtext) » Xtend2 - sorting by a function
icon5.gif  Xtend2 - sorting by a function [message #668016] Tue, 03 May 2011 12:09 Go to next message
Andrew Clark is currently offline Andrew ClarkFriend
Using the MyDsl example in Xtext 2, I have written the following Xtend
class MyDslGenerator implements IGenerator {
	override void doGenerate(Resource resource, IFileSystemAccess fsa) {
		for(model: resource.allContentsIterable.filter(typeof(Model))) {
			fsa.generateFile("example.txt", model.hello)
	hello (Model m) {
		Longest is «m.longest»
	longest(Model m) {
		m.greetings.sortBy(e|e.length).last.name
	longest2(Model m) {
		m.greetings.map(e|e.length).sort.last
	int length(Greeting g) {
		g.name.length
When this runs I get
Exception in thread "main" java.lang.IllegalArgumentException: The 'no duplicates' constraint is violated
	at org.eclipse.emf.common.util.AbstractEList.set(AbstractEList.java:268)
	at org.eclipse.emf.common.util.AbstractEList$EListIterator.doSet(AbstractEList.java:963)
	at org.eclipse.emf.common.util.AbstractEList$EListIterator.set(AbstractEList.java:941)
	at java.util.Collections.sort(Unknown Source)
	at org.eclipse.xtext.xbase.lib.ListExtensions.sortBy(ListExtensions.java:85)
	at org.xtext.example.mydsl.generator.MyDslGenerator.longest(MyDslGenerator.java:46)
	at org.xtext.example.mydsl.generator.MyDslGenerator.hello(MyDslGenerator.java:32)
	at org.xtext.example.mydsl.generator.MyDslGenerator.doGenerate(MyDslGenerator.java:24)
	at org.xtext.example.mydsl.generator.Main.runGenerator(Main.java:63)
	at org.xtext.example.mydsl.generator.Main.main(Main.java:32)
alternatively I can try the longest2 function and get
Exception in thread "main" java.lang.UnsupportedOperationException
	at java.util.AbstractList.set(Unknown Source)
	at java.util.AbstractList$ListItr.set(Unknown Source)
	at org.eclipse.xtext.xbase.lib.ListExtensions.sort(ListExtensions.java:44)
	at org.xtext.example.mydsl.generator.MyDslGenerator.longest2(MyDslGenerator.java:61)
Is this a bug (this worked in Xtend 1)?
Re: Xtend2 - sorting by a function [message #668036 is a reply to message #668016] Tue, 03 May 2011 13:28 Go to previous messageGo to next message
Sven Efftinge is currently offline Sven EfftingeFriend
It's because (currently) the sort functions do modify the passed list.
EMF puts certain constraints on the list which are validated during the
sort operation. I think we should change that and return a new list
instead and leave the old one unmodified.
Please open a bugzilla.
Sven
Am 5/3/11 2:09 PM, schrieb Andrew Clark:
> hello (Model m) {
> ''' Longest is «m.longest»
> longest(Model m) {
> longest2(Model m) {
> g.name.length
> at
> org.eclipse.emf.common.util.AbstractEList.set(AbstractEList. java:268)
> at
> org.eclipse.emf.common.util.AbstractEList$EListIterator.doSe t(AbstractEList.java:963)
> at
> org.eclipse.emf.common.util.AbstractEList$EListIterator.set( AbstractEList.java:941)
> at
> org.eclipse.xtext.xbase.lib.ListExtensions.sortBy(ListExtens ions.java:85)
> at
> org.xtext.example.mydsl.generator.MyDslGenerator.longest(MyD slGenerator.java:46)
> at
> org.xtext.example.mydsl.generator.MyDslGenerator.hello(MyDsl Generator.java:32)
> at
> org.xtext.example.mydsl.generator.MyDslGenerator.doGenerate( MyDslGenerator.java:24)
> at org.xtext.example.mydsl.generator.Main.runGenerator(Main.jav a:63)
> at
> org.eclipse.xtext.xbase.lib.ListExtensions.sort(ListExtensio ns.java:44)
> at
> org.xtext.example.mydsl.generator.MyDslGenerator.longest2(My DslGenerator.java:61)
> at
> at
Need professional support for Xtext or other Eclipse Modeling technologies?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : http://blog.efftinge.de
Re: Xtend2 - sorting by a function [message #668038 is a reply to message #668036] Tue, 03 May 2011 13:36 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
Hi Sven, hi Andrew,
since it's well documented (since M7) which functions modify the passed
list and which create new copies of the input, I'm inclined to not
change the behavior of sort. Otherwise it's hardly possible to sort an
existing list in a convenient way with Xtend.
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 03.05.11 15:28, schrieb Sven Efftinge:
> Sven
>> hello (Model m) {
>> longest(Model m) {
>> longest2(Model m) {
>> g.name.length
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Re: Xtend2 - sorting by a function [message #668047 is a reply to message #668038] Tue, 03 May 2011 14:10 Go to previous messageGo to next message
Hi Sebastian,
If the sort functionality is not changed then how should I write the Xtend code in my example ?
BTW: Which documentation are you talking about, the Java doc in ListExtensions ?
regards,
Andrew
Re: Xtend2 - sorting by a function [message #668052 is a reply to message #668047] Tue, 03 May 2011 14:32 Go to previous messageGo to next message
Hi Andrew,
we discussed this offline and I filed this ticket to describe the results:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=344584
Sebastian
Am 03.05.11 16:10, schrieb Andrew Clark:
> Hi Sebastian,
> ListExtensions ?
> regards,
> Andrew
Re: Xtend2 - sorting by a function [message #668061 is a reply to message #668052] Tue, 03 May 2011 15:02 Go to previous message
Wow that was quick, thanks to you both. I am curious to know the details of the offline discussion Razz
Previous Topic:OCL Execution Environment for Xtext?
Next Topic:assertion error in MergingHighlightedPositionAcceptor
Current Time: Sat May 26 08:25:39 GMT 2018
Powered by FUDForum. Page generated in 0.02366 seconds
