| PDF printing [message #667642] |
Sat, 30 April 2011 07:44  |
Mauro Condarelli Messages: 366 Registered: September 2009 |
I'm unsure if this is the right place.
Please redirect me if I'm wrong.
I have an RCP application where I produce (among other things) a big PDF
file (via pdfLaTeX).
I want to add a print wizard to my app which should essentially
duplicate programmatically the print driver dialog.
I need to be able to chose (programmatically!) page range and even/odd
printing and then bypass the print driver dialog.
I had a look to PaperClips and other similar libs, but I'm unsure if
this really is the way to go.
They seem more apt to produce the pages to be passed over to the print
driver (eventually producing PDF). I have that part already done.
Ideally I would need a function saying:
boolean MyPrint(String printerName, String fileNameDotPDF, int
startPage, int endPage, int printAllEvenOdd, boolean reverseOrder);
I also googled for command-line programs that can fit the bill, but I
only found the pricey pdfprint
(http://www.verypdf.com/pdfprint/pdf-print-cmd.html); no OpenSource
alternative.
Can someone help me, please
TiA
Mauro
FUDForum. Page generated in 0.02099 seconds
