Home » Eclipse Projects » BIRT » Crosstab memory limitation(Report with crosstab runs out of memory)
Crosstab memory limitation [message #667440] Thu, 28 April 2011 18:45 Go to next message
Steve Schafer is currently offline Steve SchaferFriend
One of my clients was having issues with a crosstab report running too long. It turned out it was running out of memory but the progress bar in their view just kept going. To determine if there is a fundamental memory issue with crosstabs I constructed a simple report that generates a crosstab from a scripted dataset, and it's pretty easy to get an OutOfMemoryError. I'm running this report in a little home-made platform that uses a RunAndRenderTask that works fine with other reports. My -Xmx is 1048 and my -XX:MaxPermSize is 1024 at the moment but I've also tried it at lower values. It's failing in the HTML emitter.
I guess my question is, should crosstabs be able to handle any amount of data, or is there a fundamental limitation?
Re: Crosstab memory limitation [message #667545 is a reply to message #667440] Fri, 29 April 2011 13:13 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Steve,
Can you try with a run task? Also can you lower your maxpermsize?
Jason
Re: Crosstab memory limitation [message #668122 is a reply to message #667545] Tue, 03 May 2011 20:33 Go to previous messageGo to next message
I reduced the perm size to 256 and used a RunTask only. It still runs out of memory. Here's the stack trace:
20110503_142251 => There is insufficient memory to execute this report.
20110503_142316 => Finished Tue May 03 14:23:16 MDT 2011
Exception in thread "main" java.lang.OutOfMemoryError: GC overhead limit exceeded
at java.io.ByteArrayOutputStream.<init>(Unknown Source)
at org.eclipse.birt.report.engine.internal.index.v2.BTreeMap$Ob jectSerializer.getBytes(BTreeMap.java:133)
at org.eclipse.birt.core.btree.BTree.createValue(BTree.java:677 )
at org.eclipse.birt.core.btree.BTree.insertEntry(BTree.java:200 )
at org.eclipse.birt.core.btree.BTree.insert(BTree.java:361)
at org.eclipse.birt.report.engine.internal.index.v2.IndexWriter .flushBtree(IndexWriter.java:153)
at org.eclipse.birt.report.engine.internal.index.v2.IndexWriter .close(IndexWriter.java:128)
at org.eclipse.birt.report.engine.internal.index.v2.DocumentInd exWriterV2.close(DocumentIndexWriterV2.java:48)
at org.eclipse.birt.report.engine.internal.index.DocumentIndexW riter.close(DocumentIndexWriter.java:34)
at org.eclipse.birt.report.engine.api.impl.ReportDocumentWriter .close(ReportDocumentWriter.java:112)
at org.eclipse.birt.report.engine.api.impl.RunTask.closeReportD ocument(RunTask.java:179)
at org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTas k.java:281)
at org.eclipse.birt.report.engine.api.impl.RunTask.run(RunTask. java:85)
at blackboard.report.tester.TestAllReports.testReport(Unknown Source)
at blackboard.report.tester.TestAllReports.main(Unknown Source)
Re: Crosstab memory limitation [message #668128 is a reply to message #668122] Tue, 03 May 2011 20:54 Go to previous message
Steve
Can you open a bug for this?
Jason
> exceeded
Previous Topic:how to know the value of parameter pass from report to subreport
Next Topic:Deploying BIRT & Tomcat on Windows on a non system drive
Current Time: Tue Jan 16 21:48:52 GMT 2018
Powered by FUDForum. Page generated in 0.02287 seconds
