Home » Eclipse Projects » JFace » TreeViewer Selection problem with ColumnViewerEditorActivationStrategy
TreeViewer Selection problem with ColumnViewerEditorActivationStrategy [message #666493] Wed, 20 April 2011 15:15 Go to next message
Jamel G. is currently offline Jamel G.Friend
I have a treeviewer in which i'm using cell edition in TreeViewerColumn and when I activate the below code treeviewer.setselection is not working and when i remove the code the selection is working fine.
TreeViewerFocusCellManager focusCellManager = new TreeViewerFocusCellManager(treeViewer, new FocusCellOwnerDrawHighlighter(treeViewer));
ColumnViewerEditorActivationStrategy actSupport = new ColumnViewerEditorActivationStrategy(treeViewer) {
protected boolean isEditorActivationEvent(ColumnViewerEditorActivationEvent event) {
return event.keyCode == SWT.F2;
TreeViewerEditor.create(treeViewer, focusCellManager, actSupport, ColumnViewerEditor.TABBING_HORIZONTAL | ColumnViewerEditor.TABBING_MOVE_TO_ROW_NEIGHBOR | ColumnViewerEditor.TABBING_VERTICAL | ColumnViewerEditor.KEYBOARD_ACTIVATION);
Plz help
Re: TreeViewer Selection problem with ColumnViewerEditorActivationStrategy [message #666503 is a reply to message #666493] Wed, 20 April 2011 15:38 Go to previous messageGo to next message
After investigation I have found the solution:
				Object selection = ((IStructuredSelection) sel).getFirstElement();
				if (selection instanceof MyObject) {
					treeViewer.setSelection(new StructuredSelection(selection), true);
					ViewerCell cell = treeViewer.getColumnViewerEditor().getFocusCell();
And the selection is shown.
[Updated on: Wed, 20 April 2011 15:46]
Report message to a moderator
Re: TreeViewer Selection problem with ColumnViewerEditorActivationStrategy [message #666507 is a reply to message #666493] Wed, 20 April 2011 15:27 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
The owner draw highlighter remove the selection information using owner
draw.
Tom
Am 20.04.11 17:15, schrieb Jamel:
> Hello,
> protected boolean
> Plz help
Re: TreeViewer Selection problem with ColumnViewerEditorActivationStrategy [message #666512 is a reply to message #666507] Wed, 20 April 2011 15:58 Go to previous message
Yes thank you Tom.
The selection is there, it's just not highlighted.
I will extend FocusCellHighlighter and enable the highlight of the selection.
[Updated on: Wed, 20 April 2011 21:45]
Previous Topic:Zest status
Next Topic:Global Validator Before Loading UI
Current Time: Mon Feb 19 18:20:39 GMT 2018
Powered by FUDForum. Page generated in 0.02151 seconds
