Home » Language IDEs » C / C++ IDE (CDT) » Strange "Run" behavior(Different behavior when running in Eclipse vs running the .exe)
Strange "Run" behavior [message #665866] Sun, 17 April 2011 14:18 Go to next message
No real name is currently offline No real nameFriend
I have a C++ program that should be outputting a file. However, when I run it it Eclipse, no file gets created. But if I run the .exe file outside of eclipse, created from the same build. the program runs as I expect.
I have tried with simple cout statements, and its the same thing. The Console in Eclipse does not show the proper results.
If I debug, a window pops up in by debug perspective that says "No source available for "main() at 0x04014eb".
Any thoughts? I am trying to switch from VSC++ to Eclipse, but this won't do.
Re: Strange "Run" behavior [message #665867 is a reply to message #665866] Sun, 17 April 2011 14:48 Go to previous messageGo to next message
Some more info...I went into debug configurations and unchecked "stop on startup at main". Now, when I debug the program, it created the file. But when I simply hit "Run", it does not.
What is going on? Is there something that needs to change between my release and debug settings?
Re: Strange "Run" behavior [message #666150 is a reply to message #665866] Tue, 19 April 2011 11:09 Go to previous message
Axel Mueller is currently offline Axel MuellerFriend
Where is the output saved? You should note that you have a different working directory in Eclipse (you can specify it in the Launch Configuration; default is ProjectDir).
Before you ask
- search this forum
- see the FAQ http://wiki.eclipse.org/CDT/User/FAQ
- google
Previous Topic:EclipseCDT + Zylin plug-in
Next Topic:Moving to eclipse
Current Time: Sun Jan 21 09:02:43 GMT 2018
Powered by FUDForum. Page generated in 0.01956 seconds
