Home » Eclipse Projects » JFace » [Databinding] Problem with datetime, validation and unit testing
[Databinding] Problem with datetime, validation and unit testing [message #665664] |
Fri, 15 April 2011 12:30 |
Mats-Ola Persson Messages: 2 Registered: February 2010 |
Junior Member |
I have been experimenting a bit with databindings. I have a dialog whose button i'd like to disable in certain conditions and this property I'd like to have a test for (i.e. some property does not hold -> button is diabled).
I have done one test with a Text-field (that works) , I have also done a very similar test with a DateTime-field (that fails however it works when I run the application). See code below.
I have two questions:
1) Is there someway to programmatically trigger an validation?
2) Have I missed something? If no: is the inconsistency between the behavior for DateTime and Text intended?
public static class Status2BoolConverter implements IConverter {
public Object getFromType() {
return IStatus.class;
public Object getToType() {
return Boolean.TYPE;
public Object convert(Object fromObject) {
return ((IStatus) fromObject).getSeverity() == IStatus.OK;
@Test
public void testInvalidStateWithText() throws Exception {
DataBindingContext context = new DataBindingContext();
Shell parent = new Shell();
Text text = new Text(parent, SWT.BORDER);
final IObservableValue target = WidgetProperties.text(SWT.Modify)
.observe(text);
final WritableValue model = new WritableValue("Hello, World", String.class);
context.bindValue(target, model);
context.addValidationStatusProvider(new MultiValidator() {
protected IStatus validate() {
if (model.getValue().equals("Hi!")) {
return ValidationStatus.error("fail!");
return ValidationStatus.ok();
Button b = new Button(parent, SWT.PUSH);
context.bindValue(WidgetProperties.enabled().observe(b),
new AggregateValidationStatus(context,
AggregateValidationStatus.MAX_SEVERITY),
new UpdateValueStrategy(UpdateValueStrategy.POLICY_NEVER),
new UpdateValueStrategy(UpdateValueStrategy.POLICY_UPDATE).setConverter(new Status2BoolConverter()));
text.setText("Hello!");
assertTrue(b.isEnabled());
text.setText("Hi!");
assertFalse(b.isEnabled());
@Test
public void testInvalidStateWithDate() throws Exception {
DateTime date = new DateTime(parent, SWT.BORDER);
final IObservableValue target = WidgetProperties.selection().observe(date);
final WritableValue model = new WritableValue(createDate(1999, 0, 0, 0, 0),
Date.class);
Date modelDate = (Date) model.getValue();
if (modelDate.before(createDate(1980, 0, 0, 0, 0))) {
date.setDate(1985, 0, 0);
date.setDate(1975, 0, 0);
Re: [Databinding] Problem with datetime, validation and unit testing [message #665786 is a reply to message #665664] |
Fri, 15 April 2011 22:48 |
Carsten Habicht Messages: 14 Registered: January 2011 |
Junior Member |
Hey Mats-Ola,
I just did a little debugging and noticed some "irregularities":
1.: date.setDate(1975, 0, 0) does not work. The setDate() method does nothing if the internal call to DateTime.isValidDate() returns false, which happens when the day field is 0. To get over this, one has to use something like date.setDate(1975, 0, 1).
2.: The setDate() method, when called with a valid date, seems to effect a change in the DateTime's Text control, but I could not find any Selection event being triggered (which I would expect). This only seems to happen if a user actually does some key pressing . I don't know if this misbehaviour is fixed in current versions (I used 3.6.1). Maybe you should consider filing this as a bug.
Hope that helps a little.
Best
Carsten ;o)
Current Time: Thu Apr 25 02:24:55 GMT 2024
Powered by FUDForum. Page generated in 0.03537 seconds
