Home » Eclipse Projects » BIRT » help: postgresql function Can't load the report query
help: postgresql function Can't load the report query [message #664310] Fri, 08 April 2011 06:59 Go to next message
No real name is currently offline No real name
i use posgresql 9.0 and tomcat, and birt can display data set use select query, but when use function, it can't work, thows the error 'Can't load the report query'; and the report works fine in eclipse Preview. anyone have this problem?how can i do ?
thanks
Re: help: postgresql function Can't load the report query [message #664400 is a reply to message #664310] Fri, 08 April 2011 12:16 Go to previous messageGo to next message
JulioC Missing name is currently offline JulioC Missing name
Member
What is the data source are u using?
Re: help: postgresql function Can't load the report query [message #664456 is a reply to message #664400] Fri, 08 April 2011 20:30 Go to previous messageGo to next message
<oda-data-source extensionID="com.genuitec.eclipse.reporting.oda" name="Data Source" id="7">
<property name="meDriver">PostgreSQLDriver</property>
<property name="odaDriverClass">org.postgresql.Driver</property>
<property name="odaURL">jdbc:postgresql://127.0.0.1:5432/test</property>
<property name="odaUser">test</property>
<encrypted-property name="odaPassword" encryptionID="base64">dGhlcnA=</encrypted-property>
</oda-data-source>
Re: help: postgresql function Can't load the report query [message #664458 is a reply to message #664456] Fri, 08 April 2011 21:26 Go to previous messageGo to next message
DataSet1 is OK, and DataSet is the problem
<oda-data-set extensionID="com.genuitec.eclipse.reporting.oda.SPDataSet" name="Data Set" id="8">
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">id</property>
<property name="dataType">integer</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">id</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[{call test(1)}]]></xml-property>
</oda-data-set>
<oda-data-set extensionID="com.genuitec.eclipse.reporting.oda.dataSet" name="Data Set1" id="85">
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select *
from tb_test]]></xml-property>
</oda-data-set>
[Updated on: Fri, 08 April 2011 21:29]
Report message to a moderator
Re: help: postgresql function Can't load the report query [message #665059 is a reply to message #664458] Wed, 13 April 2011 03:23 Go to previous message
ok, i find the solution, postgresql funtion is not sp, so SPDataSet is out of work, and i write the sql select *
from test() in the xml using com.genuitec.eclipse.reporting.oda.dataSet, and it's ok. but eclipse designer can't support "()" in select query , i modified the xml directly.
Previous Topic:Correct way to specify rowFetchSize
Next Topic:Formatting seconds in Y axis to DD:HH:mm:ss
Current Time: Tue May 21 03:14:54 EDT 2013
Powered by FUDForum. Page generated in 0.01819 seconds
