Home » Newcomers » Newcomers » how to force eclipse use http instead of http(cannot install Android SDK Tools)
how to force eclipse use http instead of http [message #664248] Fri, 08 April 2011 03:12 Go to next message
No real name is currently offline No real nameFriend
It's trying to access following URL
https://dl-ssl.google.com/android/repository/repository.xml
but failed. It is because https is blocked by my company's firewall. Using http is OK.
But I cannot find where to force Eclipse to use http instead of https.
My environment information is as below
* Ubuntu 10.10
* Eclipse IDE for Java Developers, Heli人Service Release 2
Build id: 20110218-0911
Thanks a lot for your help~
Re: how to force eclipse use http instead of http [message #664379 is a reply to message #664248] Fri, 08 April 2011 15:07 Go to previous message
Eric Rizzo is currently offline Eric RizzoFriend
> Using http is OK.
At some point you added the Android update site using the https URL; the
good news is that you can edit that URL. Open Preferences and find
Install/Update ? Available Software Sites. There's you'll see the
Android update URL and you can edit it to use http instead of https.
Eric
Previous Topic:Eclipse MKS Integration
Next Topic:not errored result
Current Time: Thu May 24 02:35:23 GMT 2018
Powered by FUDForum. Page generated in 0.03255 seconds
