Home » Eclipse Projects » EclipseLink » Problems Executing Stored Procedure in DB2 with EclipseLink v1.2
Problems Executing Stored Procedure in DB2 with EclipseLink v1.2 [message #664167] Thu, 07 April 2011 17:14 Go to next message
No real name is currently offline No real nameFriend
I am having an issue executing a stored procedure using Eclipselink v1.2 running on Weblogic 10.0 (JDK 5) and DB2 v9.1 on z/OS. I have the following stored procedure:
CREATE PROCEDURE
PROD.SUBS
(IN    GROUP_ID_VAR                 DECIMAL(10)
,OUT   SQLCODE_OUT                  INTEGER
) VERSION VERSION1
  LANGUAGE SQL
  VALIDATE BIND
  DYNAMICRULES BIND
  QUALIFIER YUT
 DISABLE DEBUG MODE
 DYNAMIC RESULT SET 1
 ASUTIME NO LIMIT
 COMMIT ON RETURN NO
P1: BEGIN
DECLARE SQLCODE INT;
DECLARE TEMP_GROUP_ID DEC (10);
--DECLARE SUB_COUNT INT;
DECLARE ESA CURSOR WITH RETURN FOR
... SOME BORING SQL
OPEN ESA;
SET SQLCODE_OUT = SQLCODE;
END P1
I am executing this via a NamedStoredProcedure annotation :
@NamedStoredProcedureQueries( {
	@NamedStoredProcedureQuery(
		name="subs",
		procedureName="PROD.SUBS",
		returnsResultSet=true,
		parameters={
				@StoredProcedureParameter(queryParameter="groupIdVar",direction=Direction.IN,type=BigDecimal.class),
				@StoredProcedureParameter(queryParameter="sqlCodeOut",direction=Direction.OUT,type=Integer.class)
		resultClass=Subs.class,
		resultSetMapping="subsResult"
@SqlResultSetMapping( name="subsResult", entities={
		@EntityResult( entityClass=Subs.class , fields = {
			@FieldResult( name="firstName", column="FIRSTNAME" ),
			@FieldResult( name="lastName", column="LASTNAME" ),
			@FieldResult( name="streetAddressLine1", column="STREET" ),
			@FieldResult( name="streetAddressLine2", column="STREETNUMBER" ),
			@FieldResult( name="city", column="CITY" ),
			@FieldResult( name="state", column="STATE" ),
			@FieldResult( name="zipCode", column="ZIPCODE" ),
			@FieldResult( name="country", column="COUNTRY" ),
			@FieldResult( name="dayPhone", column="BUSINESSPHONE" ),
			@FieldResult( name="evePhone", column="PRIVATEPHONE" ),
			@FieldResult( name="email", column="EMAIL" )
The interesting bit is the following:
This is being executed from a JPA Controller via the following:
    	EntityManager em = null;
    	try {
    		em = getEntityManager();
    		Query q = em.createNamedQuery( "subs" );
    		q.setParameter( "groupIdVar", new BigDecimal(groupId) );
    		Subs subs = (Subs)q.getSingleResult();
    	} catch( Exception e ) {
    		e.printStackTrace();
When I am running the query I get the following error:
Exception [EclipseLink-4002] (Eclipse Persistence Services - 1.2.0.v20091016-r5565): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: com.ibm.db2.jcc.b.eo: [jcc][10413][10940][3.53.95] Literal replacement parsing failed for procedure call to DB2 for z/OS. Failing SQL text CALL PROD.SUBS(groupIdVar = ?, sqlCodeOut = ?). ERRORCODE=-4463, SQLSTATE=42601
Error Code: -4463
Call: CALL PROD.SUBS(groupIdVar = ?, sqlCodeOut = ?)
	bind => [13488062, => sqlCodeOut]
Query: ReadAllQuery(name="subs" referenceClass=Subs )
	at org.eclipse.persistence.exceptions.DatabaseException.sqlException(DatabaseException.java:333)
	at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.processExceptionForCommError(DatabaseAccessor.java:1411)
	at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.basicExecuteCall(DatabaseAccessor.java:677)
	at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeCall(DatabaseAccessor.java:528)
	at org.eclipse.persistence.sessions.server.ServerSession.executeCall(ServerSession.java:529)
	at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeCall(DatasourceCallQueryMechanism.java:205)
	at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeCall(DatasourceCallQueryMechanism.java:191)
	at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.executeSelectCall(DatasourceCallQueryMechanism.java:262)
	at org.eclipse.persistence.internal.queries.DatasourceCallQueryMechanism.selectAllRows(DatasourceCallQueryMechanism.java:599)
	at org.eclipse.persistence.queries.ReadAllQuery.executeObjectLevelReadQuery(ReadAllQuery.java:455)
	at org.eclipse.persistence.queries.ObjectLevelReadQuery.executeDatabaseQuery(ObjectLevelReadQuery.java:997)
	at org.eclipse.persistence.queries.DatabaseQuery.execute(DatabaseQuery.java:670)
	at org.eclipse.persistence.queries.ObjectLevelReadQuery.execute(ObjectLevelReadQuery.java:958)
	at org.eclipse.persistence.queries.ReadAllQuery.execute(ReadAllQuery.java:432)
	at org.eclipse.persistence.queries.ObjectLevelReadQuery.executeInUnitOfWork(ObjectLevelReadQuery.java:1021)
	at org.eclipse.persistence.internal.sessions.UnitOfWorkImpl.internalExecuteQuery(UnitOfWorkImpl.java:2858)
	at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1225)
	at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1299)
	at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1207)
	at org.eclipse.persistence.internal.sessions.AbstractSession.executeQuery(AbstractSession.java:1181)
	at org.eclipse.persistence.internal.jpa.EJBQueryImpl.executeReadQuery(EJBQueryImpl.java:420)
	at org.eclipse.persistence.internal.jpa.EJBQueryImpl.getSingleResult(EJBQueryImpl.java:669)
As I am not sure exactly what SQL that EclipseLink is generating, because the correct syntax for executing a stored procedure in DB2 is :
 CALL PROD.SUBS(?, ?);
I have tried using specifying the name of the parameters with the same result.
Can anyone shed some light on success/failure with executing stored procedures to DB2?
Thank you,
Chuck
Re: Problems Executing Stored Procedure in DB2 with EclipseLink v1.2 [message #664190 is a reply to message #664167] Thu, 07 April 2011 19:13 Go to previous messageGo to next message
I just wanted to inform everyone that I have fixed the problem by manually editing the DB2Platform.java source file in the org.eclipse.persistence.platform.database package in order to have the call formatted properly. I am stuck using v1.2 and I believe in v2.0 this is working fine but for us stuck in the JDK 5 world, this is necessary (well, my job dictates that we use JDK 5 and JPA v1.0).
If anyone is interested in the changes made, please reply.
Re: Problems Executing Stored Procedure in DB2 with EclipseLink v1.2 [message #664680 is a reply to message #664190] Mon, 11 April 2011 15:09 Go to previous messageGo to next message
James Sutherland is currently offline James SutherlandFriend
The issue is that the query is defined using named parameters, but DB2 does not support names. In 2.3 there will be a callByIndex option on the named query that allows the query to call by index.
You can also fix it in the platform, by always generating an indexed call as you have done. Please log the bug, attach your platform changes, and vote for it.
James : Wiki : Book : Blog : Twitter
Re: Problems Executing Stored Procedure in DB2 with EclipseLink v1.2 [message #753474 is a reply to message #664680] Thu, 27 October 2011 12:22 Go to previous messageGo to next message
Ronny  is currently offline Ronny Friend
I used EclipseLink 2.3 and DB2. I set the CallByIndex flag to true. However, SqlResultSetMapping does not work properly.
I have something like
@FieldResult( name="firstname", column="NAME_VALUE" )
However, the result column NAME_VALUE failed to set to Subs.class, unless I have
public class Subs {
@Column("NAME_VALUE")
private string firstname;
But it is not what I want. Please kindly let me know how to fix it. Did the change in DB2Platform.java can do the result set mapping properly?
Many Thanks
Re: Problems Executing Stored Procedure in DB2 with EclipseLink v1.2 [message #753475 is a reply to message #664680] Thu, 27 October 2011 12:22 Go to previous messageGo to next message
Ronny is currently offline RonnyFriend
public class Subs {
Many Thanks
Re: Problems Executing Stored Procedure in DB2 with EclipseLink v1.2 [message #753545 is a reply to message #753475] Thu, 27 October 2011 15:59 Go to previous messageGo to next message
Chris Delahunt is currently offline Chris DelahuntFriend
This thread was about a problem executing a stored procedure, while your problem seems to be with building the results afterward using a SQLResultSetMapping and so likely are not related. You might want to post the problem, the query and the generated SQL using EclipseLink logging set to finest in a new thread. Not much can be said on what is going wrong without information on how you set up the query and set it to use the SQLResultSetMapping you have defined.
Best Regards,
Chris
Re: Problems Executing Stored Procedure in DB2 with EclipseLink v1.2 [message #753547 is a reply to message #753475] Thu, 27 October 2011 15:59 Go to previous message
Best Regards,
Chris
Previous Topic:create-tables doesn't create foreign key constraints
Next Topic:Cache Coordination issue
Current Time: Mon May 28 05:31:43 GMT 2018
Powered by FUDForum. Page generated in 0.02146 seconds
