Home » Newcomers » Newcomers » Java EE / Solaris 10 / Invalid argument(Java EE / Solaris 10 / Invalid argument)
Java EE / Solaris 10 / Invalid argument [message #663801] Wed, 06 April 2011 14:24 Go to next message
BT  is currently offline BT Friend
I downloaded the Java EE edition (eclipse-jee-helios-SR2-linux-gtk-x86_64.tar.gz) and unpacked it with "gtar -xvzf"
I executed eclipse from the command line and received this:
./eclipse
bash: ./eclipse: Invalid argument
After reading the install help, I added the -vm option to my eclipse.ini file:
-startup
plugins/org.eclipse.equinox.launcher_1.1.1.R36x_v20101122_14 00.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.2. R36x_v20101019_1345
-product
org.eclipse.epp.package.jee.product
--launcher.defaultAction
openFile
-showsplash
org.eclipse.platform
--launcher.XXMaxPermSize
256m
openFile
-vm
/usr/jdk/jdk1.6.0_24/bin/java
-vmargs
-Dosgi.requiredJavaVersion=1.5
-XX:MaxPermSize=256m
-Xms40m
-Xmx512m
I also tried to add it to the command line with no success.
I also tried to specify a -d64 vm parameter on the command line with no success.
I'm running:
Oracle Solaris 5.10
GTK: 2.4.9
Java: JDK 1.6.0_24
I cannot find any logs under /eclipse/configuration or under workspace/.metadata
Any ideas?
Re: Java EE / Solaris 10 / Invalid argument [message #663875 is a reply to message #663801] Wed, 06 April 2011 16:55 Go to previous messageGo to next message
Russell Bateman is currently offline Russell BatemanFriend
Solaris * * might * * be one of the platforms on which you'd want to
use Eclipse from a private distribution. I would avoid that, but
sometimes it happens. I suggest Googling for "Eclipse Solaris install"
or some such thing. Someone with actual experience may just chime in
here eventually too.
> "gtar -xvzf"
> /eclipse
> file:
> -startup
> --launcher.library
> R36x_v20101019_1345
> -product
> openFile
> -showsplash
> 256m
> openFile
> -vm
> -vmargs
> -Xms40m
> -Xmx512m
> I also tried to add it to the command line with no success. I also tried
> I'm running:
> Oracle Solaris 5.10
> GTK: 2.4.9
> Java: JDK 1.6.0_24
> workspace/.metadata
> Any ideas?
Re: Java EE / Solaris 10 / Invalid argument [message #1775374 is a reply to message #663801] Sat, 28 October 2017 16:13 Go to previous message
Eric Oh is currently offline Eric OhFriend
There is an eclipse for Solaris 10
http://archive.eclipse.org/eclipse/downloads/drops/R-3.8.2-201301310800/solPlatform.php
It does java and debug perspective
Maybe there is a plugin link to upgrade it later or java developers for eclipse guide might be able to create a perspective
Previous Topic:Linker error
Next Topic:CODAN errors
Current Time: Fri Apr 20 09:16:12 GMT 2018
Powered by FUDForum. Page generated in 0.02990 seconds
