Home » Eclipse Projects » Remote Application Platform (RAP) » UIJob Problem
UIJob Problem [message #663495] Tue, 05 April 2011 11:45 Go to next message
Hussein Kobeisi is currently offline Hussein KobeisiFriend
Member
hey ppl,
I have a TreeUpdateJob Class which updates the Tree when a new element is created, but it doesnt work, because in the UIJob class the RWTLifeCycle.getSessionDisplay() gives back a null, and this comment was inserted // RAP [fappel]: discovering the display at runtime of a job is not is there another way to update the tree?
thanks,
Hussein
Re: UIJob Problem [message #663511 is a reply to message #663495] Tue, 05 April 2011 12:25 Go to previous messageGo to next message
Ivan Furnadjiev is currently offline Ivan FurnadjievFriend
Hi Hussein,
could you provide a little snippet of UIJob usage?
Best,
Ivan
On 4/5/2011 2:45 PM, Hussein Kobeisi wrote:
> hey ppl,
> thanks, Hussein
Re: UIJob Problem [message #663513 is a reply to message #663511] Tue, 05 April 2011 13:11 Go to previous messageGo to next message
Member
Hi Ivan,
public class TreeUpdateJob extends UIJob {
private final UniqueMultiValueMap _addSet;
private final Set<Object> _removeSet;
private final Set<Object> _refreshSet;
private final UniqueMultiValueMap _updateSet;
private final TreeViewer _treeViewer;
private final TreeArtefactRepository _treeArtefactRepository;
* @param addSet
* @param removeSet
* @param refreshSet
* @param updateSet
public TreeUpdateJob(
DefaultContentProvider contentProvider,
TreeViewer treeViewer,
TreeArtefactRepository treeArtefactRepository,
UniqueMultiValueMap addSet,
Set<Object> removeSet,
Set<Object> refreshSet,
UniqueMultiValueMap updateSet) {
super(Messages.getString("DefaultContentProvider.updateJob.label ")); //$NON-NLS-1$
hier it give back a null
_treeViewer = treeViewer;
_treeArtefactRepository = treeArtefactRepository;
_addSet = addSet;
_removeSet = removeSet;
_refreshSet = refreshSet;
_updateSet = updateSet;
thx for your help,
Hussein
Re: UIJob Problem [message #663522 is a reply to message #663513] Tue, 05 April 2011 13:44 Go to previous messageGo to next message
Hi Hussein,
try to provide the display from the outside by using the other UIJob
ctor - UIJob(Display jobDisplay, String name).
HTH,
Ivan
On 4/5/2011 4:11 PM, Hussein Kobeisi wrote:
> Hi Ivan,
> * @param addSet
> * @param removeSet
> * @param refreshSet
> * @param updateSet
> ")); //$NON-NLS-1$
> hier it give back a null _treeViewer = treeViewer;
> _addSet = addSet;
> thx for your help,
> Hussein
Re: UIJob Problem [message #663530 is a reply to message #663522] Tue, 05 April 2011 14:08 Go to previous messageGo to next message
Member
hi ivan
i tried what you said but it gives me this Exception
Exception in thread "Tree Update Thread" java.lang.IllegalStateException: No context available outside of the request service lifecycle.
at org.eclipse.rwt.internal.service.ContextProvider.getContext( ContextProvider.java:107)
at org.eclipse.rwt.internal.service.ContextProvider.getStateInf o(ContextProvider.java:160)
at org.eclipse.rwt.SessionSingletonBase.getInstance(SessionSing letonBase.java:84)
at org.eclipse.ui.internal.Workbench.getInstance(Workbench.java :378)
at org.eclipse.ui.PlatformUI.getWorkbench(PlatformUI.java:94)
at aquintos.vpr.provider.TreeUpdateJob.<init>(TreeUpdateJob.java:75)
at aquintos.vpr.provider.TreeUpdatesConsumerRunnable.run(TreeUp datesConsumerRunnable.java:72)
at java.lang.Thread.run(Unknown Source)
maybe iam giving the Display wrong :i used PlatformUI.getWorkbench().egtDisplay()
regards,
Hussein
Re: UIJob Problem [message #663537 is a reply to message #663530] Tue, 05 April 2011 14:26 Go to previous messageGo to next message
Hi Hussein,
get it from treeViewer.getTree().getDisplay()
HTH,
Ivan
On 4/5/2011 5:08 PM, Hussein Kobeisi wrote:
> hi ivan
> letonBase.java:84)
> :378)
> regards,
> Hussein
Re: UIJob Problem [message #663542 is a reply to message #663537] Tue, 05 April 2011 14:52 Go to previous message
Member
Hi Ivan,
thank you very much for your help,
now it works.
Hussein
Previous Topic:Theme is not applied in deployable war
Next Topic:Can one overwrite session expired page
Current Time: Fri May 25 01:34:54 GMT 2018
Powered by FUDForum. Page generated in 0.01759 seconds
