Home » Eclipse Projects » Eclipse Communications Framework (ECF) » HTTP POST via ECF
HTTP POST via ECF [message #662549] Thu, 31 March 2011 04:59 Go to next message
Dirk Olmes is currently offline Dirk OlmesFriend
I'm trying to integrate an Eclipse plugin with a REST service. I figured
that this should be possible using ECF but google does not come up with
anything useable. This is what I have so far:
IContainer container = ContainerFactory.getDefault().createContainer
("ecf.base");
ISendFileTransferContainerAdapter adapter =
(ISendFileTransferContainerAdapter)container.getAdapter
(ISendFileTransferContainerAdapter.class);
if (adapter != null) {
Namespace namespace = adapter.getOutgoingNamespace();
URL url = new URL("http://posttestserver.com/post.php");
IFileID fileId = FileIDFactory.getDefault().createFileID(namespace,
url);
File localFile = new File("/tmp/test.txt");
IFileTransferListener listener = new IFileTransferListener() {
public void handleTransferEvent(IFileTransferEvent event) {
System.out.println(event);
adapter.sendOutgoingRequest(fileId, localFile, listener, null);
But the code fails with "No protocol handler for FileTransferID
[ ecf.provider.filetransfer:http://posttestserver.com/post.php]"
My plugin.xml references org.eclipse.ecf, org.eclipse.ecf.filetransfer
and org.eclipse.ecf.provider.filetransfer.httpclient.
Am I using the right approach? What am I missing here?
-dirk
Re: HTTP POST via ECF [message #663088 is a reply to message #662549] Sun, 03 April 2011 13:20 Go to previous messageGo to next message
Scott Lewis is currently offline Scott LewisFriend
Dirk Olmes wrote on Thu, 31 March 2011 00:59
("ecf.base");
url);
ECF has a number of APIs...the one you are trying to use with the code above is the ECF filetransfer API. There is currently no http post-based send file transfer provider, and that's why the above does not work. It would be quite possible to create an http-post-based filetransfer provider for a particular file-upload service, but it hasn't been done yet for http post (it has for ssh file upload/send, however).
I think that given that you are accessing a REST-based service, you probably would be better off using the ECF REST API...which is intended for creating clients for REST-based services. This is another API, specifically for creating remote services based upon REST/http methods (get, post, put, delete).
There's an example of using the ECF rest API, using the post method to interact with the Twitter service in this test code:
http://git.eclipse.org/c/ecf/org.eclipse.ecf.git/tree/tests/ bundles/org.eclipse.ecf.tests.remoteservice.rest/src/org/ecl ipse/ecf/tests/remoteservice/rest/twitter/TwitterRemoteServi ceTest.java
See particularly the setUp() method, which sets up the client for accessing the rest-based remote service.
In that same test plugin project, you will find other examples of using the rest API.
There are also some further examples of using the rest API here https://github.com/ECF/ECF-Examples
Re: HTTP POST via ECF [message #663139 is a reply to message #663088] Mon, 04 April 2011 01:53 Go to previous messageGo to next message
>> figured that this should be possible using ECF but google does not come
>> up with anything useable. This is what I have so far:
> however).
org.eclipse.ecf.tests.remoteservice.rest/src/org/eclipse/ecf /tests/
remoteservice/rest/twitter/TwitterRemoteServiceTest.java
Thanks for your reply. Looking at the TwitterRemoteServiceTest I was able
to put together a simple test using my local CouchDB. I did not test
agains the REST service I'm going to integrate yet.
One thing that I stumbled over is the handling of HTTP response codes in
RestClientService. The PUT request returns a 201 response code but
RestClientService throws an exception on anything else than a 200. This
may or may not be an issue once I start testing my REST service. I'll
report back once I did a test - this may take a while, though as I'm
travelling this week.
-dirk
Re: HTTP POST via ECF [message #663486 is a reply to message #663139] Tue, 05 April 2011 10:07 Go to previous messageGo to next message
> remoteservice/rest/twitter/TwitterRemoteServiceTest.java [...]
> able to put together a simple test using my local CouchDB. I did not
> test agains the REST service I'm going to integrate yet.
I did a test with the real REST service I'm trying to integrate meanwhile
and I'm hitting the same road block: the service creates a 201 on
successful completion, not a 200.
I have no idea how to work around this properly? Fork my own ECF
RestClientService? I'd better not.
Any other ideas?
-dirk
Re: HTTP POST via ECF [message #663493 is a reply to message #663486] Tue, 05 April 2011 11:04 Go to previous messageGo to next message
Markus Kuppe is currently offline Markus KuppeFriend
> Any other ideas?
> -dirk
First I would start with an enhancement request [0].
Markus
[0] https://bugs.eclipse.org
Re: HTTP POST via ECF [message #663747 is a reply to message #663493] Wed, 06 April 2011 11:25 Go to previous message
>> meanwhile and I'm hitting the same road block: the service creates a
>> 201 on successful completion, not a 200.
>> Any other ideas?
>> -dirk
Ok, done: https://bugs.eclipse.org/bugs/show_bug.cgi?id=342002
-dirk
Previous Topic:EDEF xml Multiple endpoint problem
Next Topic:Getting all participants of all open IRC channels
Current Time: Wed Apr 25 09:03:55 GMT 2018
Powered by FUDForum. Page generated in 0.02394 seconds
