Home » Modeling » EMF » [CDO] CDOMergingConflictResolver in action
[CDO] CDOMergingConflictResolver in action [message #662413] Wed, 30 March 2011 10:50 Go to next message
Sebastian Paul is currently offline Sebastian Paul
after switching from CDO 3.0 to 4.0, I had to exchange the conflict
resolver MergeLocalChangesPerFeature by CDOMergingConflictResolver.
Now I'm getting conflicts when the same feature has been changed
concurrently. Previously, this has been resolved by overwriting the
first change.
LOGGER.debug("[1] adding resource with content");
final CDOResource resource1 =
transaction1.getOrCreateResource(CDO_RESOURCE_PATH);
addContentToResource(resource1);
transaction1.commit();
LOGGER.debug("[1] adding conflict resolver");
transaction1.options().addConflictResolver(new
CDOMergingConflictResolver());
LOGGER.debug("[2] adding conflict resolver");
transaction2.options().addConflictResolver(new
// modify element
LOGGER.debug("[1] modifying element");
modifyElement(transaction1.getResource(CDO_RESOURCE_PATH),
CMTPackage.Literals.NAMED_ELEMENT__NAME, "name1");
CMTPackage.Literals.NAMED_ELEMENT__DESCRIPTION, "description1");
LOGGER.debug("[2] modifying element");
modifyElement(transaction2.getResource(CDO_RESOURCE_PATH),
CMTPackage.Literals.NAMED_ELEMENT__NAME, "name2");
CMTPackage.Literals.PROJECT__DOCUMENT_STORE_ID, "store2");
LOGGER.debug("[1] committing transaction");
LOGGER.debug("[2] committing transaction");
transaction2.commit();
The second commit throws
[ERROR] Merger could not resolve all conflicts:
{OID3=ChangedInSourceAndTarget[target=CDORevisionDelta[Project@OID3:0v1
--> [CDOFeatureDelta[name, SET, value=name2, oldValue=busbar HL]]],
source=CDORevisionDelta[Project@OID3:0v1 --> [CDOFeatureDelta[name, SET,
value=name1, oldValue=busbar HL]]]]}
org.eclipse.emf.spi.cdo.DefaultCDOMerger$ConflictException: Merger could
org.eclipse.emf.spi.cdo.DefaultCDOMerger.merge(DefaultCDOMer ger.java:108)
org.eclipse.emf.spi.cdo.CDOMergingConflictResolver.resolveCo nflicts(CDOMergingConflictResolver.java:60)
org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl. handleConflicts(CDOTransactionImpl.java:708)
org.eclipse.emf.internal.cdo.view.CDOViewImpl.doInvalidate(C DOViewImpl.java:420)
org.eclipse.emf.internal.cdo.view.CDOViewImpl$InvalidationRu nnable.run(CDOViewImpl.java:1135)
at org.eclipse.net4j.util.concurrent.QueueRunner.work(QueueRunn er.java:26)
at org.eclipse.net4j.util.concurrent.QueueRunner.work(QueueRunn er.java:1)
org.eclipse.net4j.util.concurrent.QueueWorker.doWork(QueueWo rker.java:81)
at org.eclipse.net4j.util.concurrent.QueueWorker.work(QueueWork er.java:72)
org.eclipse.net4j.util.concurrent.Worker$WorkerThread.run(Wo rker.java:206)
The new resolver is still marked as 'under construction', but
https://bugs.eclipse.org/bugs/show_bug.cgi?id=319090 is resolved as
fixed. So how is the actual status?
Is the above behavior by design? Currently I am using the default
constructor CDOMergingConflictResolver(), which uses
DefaultCDOMerger.PerFeature.ManyValued. Do I need a different merger? Or
implement my own?
Sebastian Paul
Re: [CDO] CDOMergingConflictResolver in action [message #662431 is a reply to message #662413] Wed, 30 March 2011 11:42 Go to previous messageGo to next message
Eike Stepper is currently offline Eike Stepper
Hi Sebastian,
The CDOMergingConflictResolver is still under development. The JavaDoc says:
@deprecated This conflict resolver is still under development. It's not safe to use it.
It was supposed to be operational already, when we found out that there's a severe issue with applying the produced deltas to the local transaction. That's why MergeLocalChangesPerFeature is also already marked deprecated. But you should still be able to use MergeLocalChangesPerFeature. I'm currently on vacation and can not find the bug that you would cc yourself on in order to get notified about status changes. You could file a new one to remind me.
Cheers
/Eike
http://www.esc-net.de
Am 30.03.2011 07:50, schrieb Sebastian Paul:
> after switching from CDO 3.0 to 4.0, I had to exchange the conflict resolver MergeLocalChangesPerFeature by CDOMergingConflictResolver.
> Now I'm getting conflicts when the same feature has been changed concurrently. Previously, this has been resolved by overwriting the first change.
> final CDOResource resource1 = transaction1.getOrCreateResource(CDO_RESOURCE_PATH);
> transaction1.options().addConflictResolver(new CDOMergingConflictResolver());
> transaction2.options().addConflictResolver(new CDOMergingConflictResolver());
> // modify element
> modifyElement(transaction1.getResource(CDO_RESOURCE_PATH), CMTPackage.Literals.NAMED_ELEMENT__NAME, "name1");
> modifyElement(transaction1.getResource(CDO_RESOURCE_PATH), CMTPackage.Literals.NAMED_ELEMENT__DESCRIPTION, "description1");
> modifyElement(transaction2.getResource(CDO_RESOURCE_PATH), CMTPackage.Literals.NAMED_ELEMENT__NAME, "name2");
> modifyElement(transaction1.getResource(CDO_RESOURCE_PATH), CMTPackage.Literals.PROJECT__DOCUMENT_STORE_ID, "store2");
> [ERROR] Merger could not resolve all conflicts: {OID3=ChangedInSourceAndTarget[target=CDORevisionDelta[Project@OID3:0v1 --> [CDOFeatureDelta[name, SET, value=name2, oldValue=busbar HL]]], source=CDORevisionDelta[Project@OID3:0v1 --> [CDOFeatureDelta[name, SET, value=name1, oldValue=busbar HL]]]]}
> org.eclipse.emf.spi.cdo.DefaultCDOMerger$ConflictException: Merger could not resolve all conflicts: {OID3=ChangedInSourceAndTarget[target=CDORevisionDelta[Project@OID3:0v1 --> [CDOFeatureDelta[name, SET, value=name2, oldValue=busbar HL]]], source=CDORevisionDelta[Project@OID3:0v1 --> [CDOFeatureDelta[name, SET, value=name1, oldValue=busbar HL]]]]}
> at org.eclipse.emf.spi.cdo.DefaultCDOMerger.merge(DefaultCDOMer ger.java:108)
> at org.eclipse.emf.spi.cdo.CDOMergingConflictResolver.resolveCo nflicts(CDOMergingConflictResolver.java:60)
> at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl. handleConflicts(CDOTransactionImpl.java:708)
> at org.eclipse.emf.internal.cdo.view.CDOViewImpl.doInvalidate(C DOViewImpl.java:420)
> at org.eclipse.emf.internal.cdo.view.CDOViewImpl$InvalidationRu nnable.run(CDOViewImpl.java:1135)
> at org.eclipse.net4j.util.concurrent.QueueWorker.doWork(QueueWo rker.java:81)
> at org.eclipse.net4j.util.concurrent.Worker$WorkerThread.run(Wo rker.java:206)
> The new resolver is still marked as 'under construction', but https://bugs.eclipse.org/bugs/show_bug.cgi?id=319090 is resolved as fixed. So how is the actual status?
> Is the above behavior by design? Currently I am using the default constructor CDOMergingConflictResolver(), which uses DefaultCDOMerger.PerFeature.ManyValued. Do I need a different merger? Or implement my own?
Re: [CDO] CDOMergingConflictResolver in action [message #662646 is a reply to message #662431] Thu, 31 March 2011 08:24 Go to previous messageGo to next message
Comments below...
Am 2011-03-30 17:42, schrieb Eike Stepper:
> says:
> safe to use it.
The behaviour of the old MergeLocalChangesPerFeature must have changed,
as my tests failed after switching to the new version. Most conflicts
which have been previously resolved are not resolved any more. That was
the reason for moving to CDOMergingConflictResolver.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=341469
Sebastian Paul
Re: [CDO] CDOMergingConflictResolver in action [message #662893 is a reply to message #662646] Fri, 01 April 2011 08:08 Go to previous message
Am 2011-03-31 14:24, schrieb Sebastian Paul:
I am always getting this error:
[ERROR] Object has feature-level conflicts
org.eclipse.emf.cdo.common.util.CDOException: Object has feature-level conflicts
at org.eclipse.emf.spi.cdo.AbstractObjectConflictResolver$Merge LocalChangesPerFeature.resolveConflict(AbstractObjectConflic tResolver.java:361)
at org.eclipse.emf.spi.cdo.AbstractObjectConflictResolver$Three WayMerge.resolveConflict(AbstractObjectConflictResolver.java :279)
at org.eclipse.emf.spi.cdo.AbstractObjectConflictResolver.resol veConflicts(AbstractObjectConflictResolver.java:102)
at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl. handleConflicts(CDOTransactionImpl.java:704)
Sebastian Paul
Previous Topic:Loading XML with a schema that extends via substitutionGroup
Next Topic:Generated tests from EMF
Current Time: Tue Oct 08 08:06:17 EDT 2013
Powered by FUDForum. Page generated in 0.01565 seconds
