Home » Eclipse Projects » Remote Application Platform (RAP) » Key Bindings (RAP/FAQ)
Key Bindings (RAP/FAQ) [message #662393] Wed, 30 March 2011 14:05 Go to next message
Stephan Leicht Vogt is currently offline Stephan Leicht VogtFriend
In the wiki you describe how to add / inject a key-listener as jscript to the client. How can I remove this key-listener?
If I remove the PhaseListener the call to the server will not be executed further, but the client will call the server with every "correct" keystroke, right?
Re: Key Bindings (RAP/FAQ) [message #662866 is a reply to message #662393] Fri, 01 April 2011 09:19 Go to previous messageGo to next message
Ralf Sternberg is currently offline Ralf SternbergFriend
Hi Stephan,
The JavaScript code is just written to the client once. To unregister the
keybindings, you'd have to remove the event listener from the document
with another JavaScript snippet. However, with the fix for bug 282449
[1], it is now possible to register workbench key bindings using the
standard extension points.
If you want to register key bindings in plain RWT, i.e. without using the
workbench, there will also be an easier way in the next milestone (M7).
The details are still under discussion.
Which version of RAP do you use? Is waiting for the next milestone an
option for you?
Best regards, Ralf
Ralf Sternberg
Twitter: @EclipseRAP
Re: Key Bindings (RAP/FAQ) [message #662885 is a reply to message #662866] Fri, 01 April 2011 11:34 Go to previous message
Hi Ralf
Thats good news. Though using the workbench key bindings is not an option for me. I'll wait for the next milestone (M7). (I'm using RAP version 1.4 M6).
Thanks and greetings
Stephan Leicht
Previous Topic:Display.(a)syncExec() execution problem
Next Topic:"portable" target definitions?
Current Time: Mon May 21 17:12:16 GMT 2018
Powered by FUDForum. Page generated in 0.01757 seconds
