Home » Eclipse Projects » JavaServer Faces » JSF Facet(JSF 2.0 Facet exception )
JSF Facet [message #662105] Tue, 29 March 2011 06:46 Go to next message
Ahmed Al Kahky is currently offline Ahmed Al Kahky
I have a maven project when I try to add JSF 2.0 facet to that project I always get a null pointer exception as following:
at org.eclipse.jst.jsf.core.internal.project.facet.JSFFacetInst allDelegate.resolveConfigPath(JSFFacetInstallDelegate.java:2 96)
at org.eclipse.jst.jsf.core.internal.project.facet.JSFFacetInst allDelegate.createConfigFile(JSFFacetInstallDelegate.java:31 3)
at org.eclipse.jst.jsf.core.internal.project.facet.JSFFacetInst allDelegate.execute(JSFFacetInstallDelegate.java:124)
at org.eclipse.wst.common.project.facet.core.internal.FacetedPr oject.callDelegate(FacetedProject.java:1478)
at org.eclipse.wst.common.project.facet.core.internal.FacetedPr oject.modifyInternal(FacetedProject.java:442)
at org.eclipse.wst.common.project.facet.core.internal.FacetedPr oject.mergeChangesInternal(FacetedProject.java:1182)
at org.eclipse.wst.common.project.facet.core.internal.FacetedPr oject.access$2(FacetedProject.java:1118)
at org.eclipse.wst.common.project.facet.core.internal.FacetedPr oject$5.run(FacetedProject.java:1100)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1975)
at org.eclipse.wst.common.project.facet.core.internal.FacetedPr oject.mergeChanges(FacetedProject.java:1110)
at org.eclipse.wst.common.project.facet.core.internal.FacetedPr ojectWorkingCopy.commitChanges(FacetedProjectWorkingCopy.jav a:2020)
at org.eclipse.wst.common.project.facet.ui.internal.FacetsPrope rtyPage$4.run(FacetsPropertyPage.java:232)
at org.eclipse.wst.common.project.facet.ui.internal.FacetsPrope rtyPage$5.run(FacetsPropertyPage.java:246)
at org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:121)
Re: JSF Facet [message #663887 is a reply to message #662105] Wed, 06 April 2011 13:38 Go to previous message
Ian Trimble is currently offline Ian Trimble
Have you added the web facet to the project? The code that is failing is having trouble resolving the "web content" folder (WTP concept), which leads me to believe either the web facet is not configured for the project, or "web content" is set at the project root (corrected in recent Indigo builds of WTP).
Previous Topic:Support for beans in faces-config.xml outside WebContent
Next Topic:Referencing Bean values in JSF page
Current Time: Wed Jun 19 03:52:21 EDT 2013
Powered by FUDForum. Page generated in 0.01418 seconds
