Home » Eclipse Projects » EclipseLink » Generate JAXB Classes - cannot find XJCFacade(Generate JAXB classes menu gets ClassNotFoundException)
Generate JAXB Classes - cannot find XJCFacade [message #662010] Mon, 28 March 2011 21:04 Go to next message
Michael Giroux is currently offline Michael GirouxFriend
Member
I'm attempting to generate JAXB classes from an XSD. When I right-click the schema and select the Generate->JAXB Classes, I get the following error on the console.
java.lang.NoClassDefFoundError: com/sun/tools/xjc/XJCFacade
Caused by: java.lang.ClassNotFoundException: com.sun.tools.xjc.XJCFacade
at java.net.URLClassLoader$1.run(URLClassLoader.java:202)
at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301 )
at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
I've been digging through Eclipse docs for better part of a day now, and cannot find anything that suggests that I need to do anything special to Generate JAXB Classes.
Config:
Version: Helios Service Release 2 Java EE version.
Build id: 20110218-0911
EclipseLink SDK 2.2.0 (not sure if I need this or not)
JDK 1.6.0_24
Can someone point me to docs that explain where XJCFacade is and how to install it into eclipse?
Michael
Re: Generate JAXB Classes - cannot find XJCFacade [message #662014 is a reply to message #662010] Mon, 28 March 2011 21:21 Go to previous messageGo to next message
Member
BTW, I do see com.sun.tools.internal.xjc.XJCFacade.class in JDK 1.6 tools.jar.
Re: Generate JAXB Classes - cannot find XJCFacade [message #662137 is a reply to message #662010] Tue, 29 March 2011 13:40 Go to previous messageGo to next message
Member
Is there a better newsgroup to post this issue?
Re: Generate JAXB Classes - cannot find XJCFacade [message #662200 is a reply to message #662010] Tue, 29 March 2011 17:17 Go to previous messageGo to next message
Blaise Doughan is currently offline Blaise DoughanFriend
Hi Michael,
The JAXB tooling is provided through the Dali project. Here is a link to their forum:
http://www.eclipse.org/forums/index.php?t=thread&frm_id= 113&S=81dc99f12bb978b240758df9ef174836
-Blaise
Re: Generate JAXB Classes - cannot find XJCFacade [message #803662 is a reply to message #662010] Tue, 21 February 2012 16:41 Go to previous messageGo to next message
Frank Lawlor is currently offline Frank LawlorFriend
I had the same problem.
I changed my jdk to 1.7 and the problem went away.
-- Frank
Re: Generate JAXB Classes - cannot find XJCFacade [message #1012273 is a reply to message #662010] Thu, 21 February 2013 08:46 Go to previous messageGo to next message
Mohammed-Salah OKA is currently offline Mohammed-Salah OKAFriend
Hello
You have to use the JDK as runtime for your project in eclipse
It work well with JDK 1.6 but not with JRE6
regards
Re: Generate JAXB Classes - cannot find XJCFacade [message #1110775 is a reply to message #1012273] Tue, 17 September 2013 10:15 Go to previous messageGo to next message
Tapas Choudhury is currently offline Tapas ChoudhuryFriend
perfect.. same issue and this is the fix
Re: Generate JAXB Classes - cannot find XJCFacade [message #1243829 is a reply to message #662010] Tue, 11 February 2014 13:57 Go to previous messageGo to next message
Martin F.Friend
I recently migrated from one machine to another and updated from Kepler Release to Kepler SR1. I am unsure which of these steps made my Java Library change from JDK to JRE during this process... anyway, the hint in this thread is very helpful. As it took me quite some time to google it with a German error message (and it also seems it slightly changed because I only got one single line), I'll just add my (localized) error-message here, as I didn't find the reason for JAXB-generation failing which previously worked, until I got here. So may an early google hit help others, too. Smile
Fehler: Hauptklasse com.sun.tools.internal.xjc.XJCFacade konnte nicht gefunden oder geladen werden
Freely translated:
Error: Main class com.sun.tools.internal.xjc.XJCFacade could not be found or loaded.
Changing the Java library from JRE to the JDK in the project settings worked fine. (after adding the JDK to the workspace in the Eclipse settings)
[Updated on: Tue, 11 February 2014 13:59]
Report message to a moderator
Re: Generate JAXB Classes - cannot find XJCFacade [message #1717128 is a reply to message #1243829] Thu, 10 December 2015 07:47 Go to previous messageGo to next message
Fasil Woldemariam is currently offline Fasil WoldemariamFriend
Thank you Martin F.
It works perfect!
Re: Generate JAXB Classes - cannot find XJCFacade [message #1722894 is a reply to message #662010] Wed, 10 February 2016 07:21 Go to previous messageGo to next message
Amogh Yadawad is currently offline Amogh YadawadFriend
Your Project is pointing to JRE , not to JDK .
Update JRE Home directory with JDK Home directory.
Because JDK 1.6 or 1.7 onwards xjc.jar will be bundled along with JDK.
-Amogh
Re: Generate JAXB Classes - cannot find XJCFacade [message #1744342 is a reply to message #1722894] Mon, 26 September 2016 07:25 Go to previous messageGo to next message
Christin Kocher is currently offline Christin KocherFriend
I updated my project with the jdk1.8.0_91, but still get the same error message. xjc.jar is not contained in my jdk.
Was it removed with 1.8? What do I need to install then?
Christin
Re: Generate JAXB Classes - cannot find XJCFacade [message #1764877 is a reply to message #1744342] Fri, 02 June 2017 19:43 Go to previous message
Patrik Suzzi is currently offline Patrik SuzziFriend
Member
Like Amogh said, you just need to use a JDK instead of a JRE.
Patrik Suzzi
Consultant Software Engineer,
Eclipse Platform Committer
https://about.me/psuzzi
Previous Topic:Cascade persist and map keys
Next Topic:JPA2.1
Current Time: Tue Jan 23 15:57:56 GMT 2018
Powered by FUDForum. Page generated in 0.02175 seconds
