Home » Eclipse Projects » Rich Client Platform (RCP) » How to set background color for UI Element associated with command ?(Set the background color for UI Element associated with command (toolbar item).)
How to set background color for UI Element associated with command ? [message #661515] Fri, 25 March 2011 03:00
Santosh  is currently offline Santosh Friend
I am only a beginner in RCP.
I want to to set background color for UI Element associated with command (toolbar item).
I tried:-
In the method updateElements(UIElement element, Map ....)
element.setxxx()
But the there was a no such method in the object "element" to set the background color for ui element.
Is there a workaround to set the background color for UI Element associated with the command?
Help would be much appreciated.
[Updated on: Fri, 25 March 2011 09:47]
Report message to a moderator
Previous Topic:How to disable resizing of view / view folder in RCP
Next Topic:new view on Same Page
Current Time: Fri May 25 20:52:55 GMT 2018
Powered by FUDForum. Page generated in 0.01796 seconds
