Home » Language IDEs » AJDT » If I use inter-type declarations should I use only compile-time weaving? (ajc compiler)
If I use inter-type declarations should I use only compile-time weaving? (ajc compiler) [message #661335] Thu, 24 March 2011 06:04 Go to next message
Dmitriy Kochergin is currently offline Dmitriy Kochergin
[Updated on: Thu, 24 March 2011 06:05]
Report message to a moderator
Re: If I use inter-type declarations should I use only compile-time weaving? (ajc compiler) [message #661518 is a reply to message #661335] Fri, 25 March 2011 00:39 Go to previous message
Andrew Eisenberg is currently offline Andrew Eisenberg
Nope. There is no restriction. You can use ITDs with load time weaving as long as you are using code style AspectJ. However, ITD use is severely restricted when you use @AspectJ.
Previous Topic:ClassCircularityError
Next Topic:Advice not behaving properly
Current Time: Wed May 22 07:27:56 EDT 2013
Powered by FUDForum. Page generated in 0.01748 seconds
