Home » Eclipse Projects » Rich Client Platform (RCP) » Open View in separate Window/Shell
Open View in separate Window/Shell [message #661205] Wed, 23 March 2011 15:14 Go to next message
budili Missing name is currently offline budili Missing nameFriend
Member
it is possible to open a Eclipse View in a separate Shell?
My Problem:
I have integrate a console view in my RCP application.
At the moment i open it as an internal view.
final MessageConsole systemConsole = new MessageConsole(CONSOLE_NAME, null);
final IWorkbenchPage page = PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActivePage();
            final IConsoleView view = (IConsoleView) page.showView(IConsoleConstants.ID_CONSOLE_VIEW);
            view.display(systemConsole);
But i want to open the Console View in a separate Window.
It is possible? Can someone help me?
THX
Budi
P.S. it is possible to replace the workbench window through an external window/shell?
[Updated on: Tue, 12 April 2011 08:35]
Report message to a moderator
Re: Open View in separate Window/Shell [message #661783 is a reply to message #661205] Sun, 27 March 2011 20:05 Go to previous messageGo to next message
Wim Jongman is currently offline Wim JongmanFriend
Hi Budili,
Views can be detached manually. Once detached they stay detached when the
state is restored on the next run. You can also start a new workbench window
(window/new window) in which you can host this view separate from your other
workbench window.
I have used a nasty trick to detach a view programmatically in the views
setFocus() method. As you can see it uses an interal so I advise you not to
use this.
Wim
public void setFocus() {
if (!once) {
once = true;
IViewReference ref = getSite().getPage().findViewReference(
"org.eclipse.ecf.salvo.ui.internal.views.postNewArticleView", "1");
if (PreferenceModel.instance.getUseDetachedView()) {
((WorkbenchPage)
getSite().getPage()).getActivePerspective().getPresentation( )
detachPart(ref);
getViewSite().getShell().setSize(600, 450);
getViewSite().getShell().setLocation(location.x + 100, location.y + 100);
} else
((WorkbenchPage)
attachPart(ref);
subjectText.setFocus();
> Hello,
> My Problem:
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage();
> THX
> Budi
Re: Open View in separate Window/Shell [message #661898 is a reply to message #661205] Mon, 28 March 2011 13:18 Go to previous message
Paul Webster is currently offline Paul WebsterFriend
Your best bet is probably the second one that Wim mentions. Open a new
workbench window with a different perspective that only contains the
view in question.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/guide/workbench.htm
Previous Topic:Anyway to specify new KeyEvent.keyLocation in plugin.xml?
Next Topic:Product configuration (features included)
Current Time: Sun Jan 21 09:03:50 GMT 2018
Powered by FUDForum. Page generated in 0.01588 seconds
