Home » Modeling » TMF (Xtext) » Duplicate elements error(How to handle duplicate elements error)
Duplicate elements error [message #659612] Mon, 14 March 2011 19:39 Go to next message
Andreas Deinlein is currently offline Andreas DeinleinFriend
i am a beginner in xtext. I am trying to create a grammar for my DSL.
Here is an example:
GROUP a
	INTEGER a1 DEFAULT 1
GROUP b IF a.a1 = 1
	INTEGER b1 DEFAULT 1
GROUP b IF a.a1 = 2
	INTEGER b2 DEFAULT 1
I created the following grammar:
grammar org.xtext.example.config.MyConfig with org.eclipse.xtext.common.Terminals
generate myConfig "http://www.xtext.org/example/config/MyConfig"
Model:
	elements+=AbstractElements*;
AbstractElements:
	Parameter | Group;
Group:
	'GROUP' name=ID ('IF' (condition+=Condition)* )?
		(parameters+=Parameter)*
Parameter:
	'INTEGER'  name=ID 'DEFAULT' default=INT;
Condition:
	EquationCondition;
EquationCondition:
	group=[Group|ID]'.'parameter=[Parameter|ID] '=' value=INT;
I get the following validation error: " Duplicate Abstract Elements 'b' " In my case, this is not right, because the two groups have a different condition ! how could i prevent the validation error ?
Could I change the grammar to prevent the duplicate entries error ?
Thanks in advance.
Re: Duplicate elements error [message #659619 is a reply to message #659612] Mon, 14 March 2011 19:59 Go to previous messageGo to next message
Christian Dietrich is currently online Christian DietrichFriend
you can disable duplicate name checks for your grammar by removing
composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
from your languages workflow
~Christian
Need professional support for Xtext, Xpand, EMF?
Go to: https://xtext.itemis.com
Twitter : @chrdietrich
Blog : https://www.dietrich-it.de
Re: Duplicate elements error [message #659857 is a reply to message #659619] Tue, 15 March 2011 19:27 Go to previous messageGo to next message
Ok, thanks, now i have no errors anymore !
Could you think of a solution where I deactivate or filter the duplicate names check only for these conditional groups, because apart from that exception, the duplicate names check would really help
Andreas
Re: Duplicate elements error [message #659870 is a reply to message #659857] Tue, 15 March 2011 20:11 Go to previous message
Alexander Nittka is currently offline Alexander NittkaFriend
I could imagine that the following works. Extend the NamesAreUniqueValidator overriding doCheckUniqueNames. You basically copy the method body but remove from descriptions those whose type is the one you do not want to be checked before passing them on to the helper.
Alternatively bind your own implementation of NamesAreUniqueValidationHelper and make that one ignore the objects you want to be ignored.
Alex
Previous Topic:Unresolved cross references
Next Topic:Retrieving the qualified name of a reference?
Current Time: Mon May 21 19:06:29 GMT 2018
Powered by FUDForum. Page generated in 0.02097 seconds
