Home » Language IDEs » C / C++ IDE (CDT) » Create New Makefile Project with existing code
Create New Makefile Project with existing code [message #659307] Sat, 12 March 2011 01:29 Go to next message
No real name is currently offline No real nameFriend
Hello:
I am trying to import an existing autotools project kind of like what was done here.
http://blog.schmichael.com/2010/12/28/noobs-guide-to-hacking -nginx/
Though I cannot find that "Import Existing Code" dialog that was illustrated. I have the autotools support for CDT (plug-in), and CDT installed.
Are there other plug-ins that I need to install?
--B
Re: Create New Makefile Project with existing code [message #659425 is a reply to message #659307] Sun, 13 March 2011 19:13 Go to previous messageGo to next message
Axel Mueller is currently offline Axel MuellerFriend
Which Eclipse version are you using?
Before you ask
- search this forum
- see the FAQ http://wiki.eclipse.org/CDT/User/FAQ
- google
Re: Create New Makefile Project with existing code [message #659536 is a reply to message #659425] Mon, 14 March 2011 13:26 Go to previous messageGo to next message
Galileo,
Eclipse SDK
Version: 3.5.2
Build id: M20100211-1343,
running on Kubuntu.
Linux version 2.6.32-24-generic.
--b
Re: Create New Makefile Project with existing code [message #659670 is a reply to message #659536] Tue, 15 March 2011 07:58 Go to previous message
No Real Name wrote on Mon, 14 March 2011 14:26
Galileo,
Eclipse SDK
Version: 3.5.2
running on Kubuntu.
--b
AFAIK, the "Import Existing Code" was added in Eclipse Helios (3.6).
For Galileo you must do some more work manually
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .cdt.doc.user/getting_started/cdt_w_existing_code.htm
Before you ask
- search this forum
- google
Previous Topic:Confusion re Build and Environment Variables
Next Topic:some questions on debugging
Current Time: Sun Feb 18 09:27:39 GMT 2018
Powered by FUDForum. Page generated in 0.01839 seconds
