Home » Eclipse Projects » JFace » TreeViewer Collapses on refresh(TreeViewer Collapses on refresh)
TreeViewer Collapses on refresh [message #659120] Fri, 11 March 2011 07:32 Go to next message
Animesh Kumar is currently offline Animesh KumarFriend
Member
I have a FilteredTree which is defined as follows:-
PatternFilter patternFilter = new PatternFilter();
final FilteredTree filteredTree = new FilteredTree(container, SWT.MULTI | SWT.H_SCROLL | SWT.V_SCROLL, patternFilter);
TreeViewer treeViewer = filteredTree.getViewer();
I have an action whose selection or de-selection refreshes the tree. But when the treeviewer is refreshed, the tree gets collapsed. How can I prevent my tree from getting collapsed?
I am using the the following code for treeviewer refresh:-
actionShowObjects = new Action("Show Objects") {
				public void run() {
					treeViewer.refresh();
			actionShowObjects.setChecked(true);
Animesh
Re: TreeViewer Collapses on refresh [message #659161 is a reply to message #659120] Fri, 11 March 2011 10:13 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas SchindlFriend
Your problem is very likely that you are recreating your domain objects
in your content provider and so you need to help the TableViewer to map
the old instance to the new one which is normally done by setting an
IElementComparer on the viewer.
Tom
Am 11.03.11 08:32, schrieb Animesh Kumar:
> @Override
> public void run() {
Re: TreeViewer Collapses on refresh [message #659163 is a reply to message #659161] Fri, 11 March 2011 10:30 Go to previous message
Member
Hi Tom,
Thanx for the reply. If you don't mind, can you give a small example on how i can use the IElementComparer for the TreeViewer.
Animesh
Previous Topic:Virtual tableViewer
Next Topic:Regarding TreeViewer
Current Time: Mon Feb 19 18:20:54 GMT 2018
Powered by FUDForum. Page generated in 0.02625 seconds
