Home » Eclipse Projects » SWTBot » pass -configuration parameter to RCP test applcation
pass -configuration parameter to RCP test applcation [message #658487] Tue, 08 March 2011 17:34
Natalia  is currently offline Natalia Friend
Hello everybody,
I have a little question.
A have a RCP application to test and I should pass some parameters to it. One of these parameters is "-configure" parameter. I pass all the parameters in "Program arguments" field of eclipse.
There is no problem passing all the parameters except "configuration", because SWTBot test case thinks that I want to change his configuration....
Is there some way to indicate that the -configuration parameter should be applied to the application under the test, and not to SWTBot test case?
Thank you in advance for your help!
Nat
[Updated on: Tue, 08 March 2011 17:34]
Report message to a moderator
Previous Topic:No "Run As - SwtBot Test" available after installation
Next Topic:Next button remains disabled
Current Time: Sun Apr 22 22:29:35 GMT 2018
Powered by FUDForum. Page generated in 0.02300 seconds
