Home » Eclipse Projects » BIRT » Turning off BIRT loggin in web.xml
Turning off BIRT loggin in web.xml [message #657976] Fri, 04 March 2011 13:59 Go to next message
James Mising name is currently offline James Mising name
I am trying to figure out how to turn off logging via the web.xml.
Currently I am trying:
<context-param>
<param-name>BIRT_VIEWER_LOG_LEVEL</param-name>
<param-value>OFF</param-value>
</context-param>
But when I run the report, I still see logging (mainly lots of INFO: Type: COLUMN_EDGE, Measure: 0, Data Position: 38
h) What am I doing incorrectly?
Thanks in advance.
James
[Updated on: Fri, 04 March 2011 15:37]
Report message to a moderator
Re: Turning off BIRT loggin in web.xml [message #658444 is a reply to message #657976] Tue, 08 March 2011 09:50 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
Can you post what packages are logging? You may also want to look at the viewer.properties file which contains a section for loggers.
Jason
Jason Weathersby
BIRT Exchange
Re: Turning off BIRT loggin in web.xml [message #658534 is a reply to message #658444] Tue, 08 March 2011 16:04 Go to previous messageGo to next message
I have looked in the viewer.properties file and read the part about logging, but not sure how to use that to adjust logging levels. I would be happy just to turn logging off for right now.
# [LOGGERS]
# "logger."+class=level
# if no level is specified or the text "DEFAULT",
# then the default level from the web.xml will be used
logger.org.eclipse.datatools.connectivity.oda=DEFAULT
logger.org.eclipse.datatools.enablement.oda=DEFAULT
Forgive me if this is not what you were asking for what packages are logging, but I have a report with crosstabs and lots of data. We are trying to clean up our log files and there is a lot of this everytime a report is run that I am trying to limit to SEVERE logs or even just turn off for right now and cant get it work:
INFO: Type: COLUMN_EDGE, Measure: 0, Data Position: 20
Mar 8, 2011 3:52:35 PM org.eclipse.birt.report.item.crosstab.core.re.executor.Table ColumnGenerator generateColumns
INFO: Type: COLUMN_EDGE, Measure: 0, Data Position: 21
INFO: Type: COLUMN_EDGE, Measure: 0, Data Position: 22
INFO: Type: COLUMN_EDGE, Measure: 0, Data Position: 23
INFO: Type: COLUMN_EDGE, Measure: 0, Data Position: 24
INFO: Type: COLUMN_EDGE, Measure: 0, Data Position: 25
INFO: Type: COLUMN_EDGE, Measure: 0, Data Position: 26
INFO: Type: COLUMN_EDGE, Measure: 0, Data Position: 27
INFO: Type: COLUMN_EDGE, Measure: 0, Data Position: 28
INFO: Type: COLUMN_EDGE, Measure: 0, Data Position: 29
INFO: Type: COLUMN_EDGE, Measure: 0, Data Position: 30
INFO: Type: COLUMN_EDGE, Measure: 0, Data Position: 31
INFO: Type: COLUMN_EDGE, Measure: 0, Data Position: 32
INFO: Type: COLUMN_EDGE, Measure: 0, Data Position: 33
INFO: Type: COLUMN_EDGE, Measure: 0, Data Position: 34
INFO: Type: COLUMN_EDGE, Measure: 0, Data Position: 35
INFO: Type: COLUMN_EDGE, Measure: 0, Data Position: 36
INFO: Type: COLUMN_EDGE, Measure: 0, Data Position: 37
INFO: Type: COLUMN_EDGE, Measure: 0, Data Position: 39
INFO: Type: COLUMN_EDGE, Measure: 0, Data Position: 40
INFO: Type: COLUMN_EDGE, Measure: 0, Data Position: 41
INFO: Type: COLUMN_EDGE, Measure: 0, Data Position: 42
INFO: Type: COLUMN_EDGE, Measure: 0, Data Position: 43
INFO: Type: COLUMN_EDGE, Measure: 0, Data Position: 44
INFO: Type: COLUMN_EDGE, Measure: 0, Data Position: 45
INFO: Type: COLUMN_EDGE, Measure: 0, Data Position: 46
INFO: Type: COLUMN_EDGE, Measure: 0, Data Position: 47
Mar 8, 2011 3:52:36 PM org.eclipse.birt.report.data.oda.jdbc.Connection close
WARNING: JDBC connection: com.mysql.jdbc.JDBC4Connection@5c0c68d is closed
Mar 8, 2011 3:54:16 PM org.apache.tomcat.util.http.Parameters processParameters
WARNING: Parameters: Invalid chunk '' ignored.
BIRT is a wonderful tool and has provided a great way for us to display various data.
James
[Updated on: Wed, 09 March 2011 09:25]
Re: Turning off BIRT loggin in web.xml [message #658733 is a reply to message #658534] Wed, 09 March 2011 11:02 Go to previous messageGo to next message
James,
Are you getting logs in the viewer logs directory or in the app servers
log directory. I have the viewer deployed in tomcat and I had to turn
off its logs in apache-tomcat-5.5.20\conf\logging.properties
Jason
On 3/8/2011 4:04 PM, James wrote:
> I have look in the viewer.properties file and read the part about
> # [LOGGERS]
> close
> WARNING: JDBC connection: mailto:com.mysql.jdbc.JDBC4Connection@5c0c68d
> is closed
> processParameters
> various data.
> James
Jason Weathersby
BIRT Exchange
Re: Turning off BIRT loggin in web.xml [message #658736 is a reply to message #658733] Wed, 09 March 2011 11:20 Go to previous messageGo to next message
in the app servers log directory (catalina log file), and I do not have permission to the logging.properties file, that would be a sysadmin configuration. What is the setting to turn it off in that file if I ask?
James
Re: Turning off BIRT loggin in web.xml [message #658986 is a reply to message #658736] Thu, 10 March 2011 10:51 Go to previous messageGo to next message
James,
I am still looking into this. I just set the log levels in the
logging.properties to OFF but this may not be what you want.
Jason
> James
Jason Weathersby
BIRT Exchange
Re: Turning off BIRT loggin in web.xml [message #659072 is a reply to message #658986] Thu, 10 March 2011 16:31 Go to previous messageGo to next message
Thanks Jason.
I did work with the sys admin on changing the logging setting in the logging properties file in Tomcat. I think he changed it just to WARNING, but i don't think it was BIRT specific but for all logging meaning there would be no way to control the log level setting from within the app (web.xml). I am concerned because we are about to turn logging on wide open for everything for debugging, and I would like to adjust BIRT to not show everything because it takes up more space than anything else logged and is a lot to go through. Thanks again for your help and thanks for BIRT, its wonderful.
James
Re: Turning off BIRT loggin in web.xml [message #659229 is a reply to message #659072] Fri, 11 March 2011 10:26 Go to previous message
James,
If you are trying to debug BIRT and set the log level in the web.xml of
the BIRT app, the log messages for the BIRT code should by default show
up in the WebViewer/logs directory.
Jason
On 3/10/2011 4:31 PM, James wrote:
> Thanks Jason.
> James
Jason Weathersby
BIRT Exchange
Previous Topic:Removing margin (whitespace) between table cells
Next Topic:Adding fields to database table causes error What is best practice?
Current Time: Sat May 25 18:22:28 EDT 2013
Powered by FUDForum. Page generated in 0.01730 seconds
