Home » Eclipse Projects » Subversive » Change sets (Helios, Subversive)(Change sets are not saving)
Change sets (Helios, Subversive) [message #657680] Thu, 03 March 2011 15:58 Go to next message
Brandon is currently offline BrandonFriend
Hi everyone,
My dev group recently migrated from CVS to SVN. I upgraded Eclipse to Helios and then installed Subversive. Now change sets no longer save consistently.
- Changing a file in a change set and saving can kick the file back to <unassigned>
- Closing the workspace and reopening, at least 50% of the files that were previously in change sets are now <unassigned>
I have spent a couple hours searching around and have not found any solutions. I tried a few suggestions on preference changes which have done nothing. Also, someone reported a very similar issue last May, but for them the issue simply disappeared. Any ideas or suggestions would be greatly appreciated.
~ Brandon
Re: Change sets (Helios, Subversive) [message #657879 is a reply to message #657680] Fri, 04 March 2011 12:51 Go to previous messageGo to next message
Stanimir Stamenkov is currently offline Stanimir StamenkovFriend
Thu, 03 Mar 2011 10:58:58 -0500, /Brandon/:
> save consistently.
> to <unassigned>
That would be me reporting the very same issue [1]. It hasn't
completely disappeared for me, but it happens rarely enough I can't
reproduce it reliably, unfortunately. If you can come up with exact
steps to reproduce the problem, it would be great.
[1] http://www.eclipse.org/forums/index.php?t=tree&th=168231
Stanimir
Re: Change sets (Helios, Subversive) [message #821735 is a reply to message #657680] Thu, 15 March 2012 19:00 Go to previous message
Synthos Nysun is currently offline Synthos NysunFriend
I am seeing this issue, but it is happening all the time for me. What sort of version information do you need from me?
Previous Topic:Check-out failed before completion, now what?
Next Topic:MAVEN SUBVERION
Current Time: Mon Apr 23 21:42:16 GMT 2018
Powered by FUDForum. Page generated in 0.02277 seconds
