Home » Eclipse Projects » Rich Client Platform (RCP) » How to Link the properties file in Rcp
How to Link the properties file in Rcp [message #656940] Tue, 01 March 2011 06:06 Go to next message
ash is currently offline ashFriend
How to link properties file in Rcp application.
Plugin.xml will automatically refer plugin.properties file directly
Now i will create abouttxt.properties file i want to refer
key and value pair in plugin.xml of abouttxt.properties
value is not picked from abouttxt.properties in plugin.XML.
i think we need to link the properties file.
Can i know if this can be implemented
ashok
Re: How to Link the properties file in Rcp [message #657057 is a reply to message #656940] Tue, 01 March 2011 13:40 Go to previous message
Paul Webster is currently offline Paul WebsterFriend
On 03/01/2011 01:06 AM, ash wrote:
> Plugin.xml will automatically refer plugin.properties file directly Now
> i will create abouttxt.properties file i want to refer key and value
It doesn't refer automatically. This line tells it to use the
plugin.properties file:
Bundle-Localization: plugin
in theory, you want:
Bundle-Localization: abouttxt
but you only get one properties file for the MANIFEST.MF and plugin.xml
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Previous Topic:IWorkbenchConfigurer.setSaveAndRestore strange behavior
Next Topic:Other than *.* in Open File dialog
Current Time: Mon Feb 19 19:31:31 GMT 2018
Powered by FUDForum. Page generated in 0.01428 seconds
