Home » Modeling » MoDisco » inter-model references are forbidden. Configure launching options to allow them.
inter-model references are forbidden. Configure launching options to allow them. [message #656921] Mon, 28 February 2011 20:01 Go to next message
Suhrit Rimal is currently offline Suhrit Rimal
I am using modisco 8 + eclipse helios (modeling) and did transformed java project to kdm. I dont get all the information present in java project.
I am getting following errors when i look into log file generated.
My project has only one java class. which looks like
public class test {
public void echo(){
String message = "hello";
System.out.println(message+"world");
Is it bug that is present there??
also when i try using comments it doesnt makes into kdm but is present in java model.
my previous post is related to this too.
Re: inter-model references are forbidden. Configure launching options to allow them. [message #656984 is a reply to message #656921] Tue, 01 March 2011 04:30 Go to previous messageGo to next message
Gabriel  is currently offline Gabriel
this is a known bug, and we have to apologize as correction has been made in head (version 0.9.x) but not reported in version 0.8.x. Sorry Confused
So if you have some time, you should try the Indigo bundle:
http://www.eclipse.org/downloads/index-developer.php
And use this update site:
http://download.eclipse.org/modeling/mdt/modisco/updates/mil estones/0.9
Gabriel
[Updated on: Tue, 01 March 2011 04:31]
Report message to a moderator
Re: inter-model references are forbidden. Configure launching options to allow them. [message #657223 is a reply to message #656984] Tue, 01 March 2011 20:26 Go to previous message
Thankx for your reply. I installed Indigo and Modisco 9.
When I compare helios+8.X model and indigo +9.0 model its same. I think some information gets lost in KDM model when being trasnformed from Java Model.
I am using following code:
public class test {
public void echo(){
String newMessage ="world";
System.out.println(message+newMessage);
In Java Model What I can see is that message and newMessage gets add the information is still there but when it comes to KDM Model Information gets lost. I tried different variation. If inside println function we keep direct string something like System.out.println("hello"+"world"); the information is preserved but variables are never there even if it is direct string + some variable. Seecorresponding JavaCodeModel and KDM Model.
JavaCodeModel
<statements xsi:type="java:ExpressionStatement" originalCompilationUnit="//@compilationUnits.0">
<expression xsi:type="java:MethodInvocation" originalCompilationUnit="//@compilationUnits.0" method=" //@ownedElements.1/@ownedPackages.1/@ownedElements.1/@bodyDe clarations.0 ">
<arguments xsi:type="java:InfixExpression" originalCompilationUnit="//@compilationUnits.0" operator="+">
<rightOperand xsi:type="java:SingleVariableAccess" variable=" //@ownedElements.0/@ownedElements.0/@bodyDeclarations.0/@bod y/@statements.1/@fragments.0 "/>
<leftOperand xsi:type="java:SingleVariableAccess" variable=" //@ownedElements.0/@ownedElements.0/@bodyDeclarations.0/@bod y/@statements.0/@fragments.0 "/>
</arguments>
<expression xsi:type="java:SingleVariableAccess" variable=" //@ownedElements.1/@ownedPackages.0/@ownedElements.3/@bodyDe clarations.0/@fragments.0 ">
<qualifier xsi:type="java:TypeAccess" type="//@ownedElements.1/@ownedPackages.0/@ownedElements.3"/ >
</expression>
</expression>
</statements>
KDM model:
<codeElement xsi:type="action:ActionElement" name="expression statement" kind="expression statement">
<source language="java">
<region file="//@model.2/@inventoryElement.0" language="java"/>
</source>
<codeElement xsi:type="action:ActionElement" name="method invocation" kind="method invocation">
</source>
<codeElement xsi:type="action:ActionElement" name="+" kind="infix expression">
</source>
</codeElement>
<actionRelation xsi:type="action:Calls" to=" //@model.1/@codeElement.0/@codeElement.1/@codeElement.1/@cod eElement.0 " from=" //@model.0/@codeElement.0/@codeElement.0/@codeElement.0/@cod eElement.1/@codeElement.2/@codeElement.0 "/>
</codeElement>
</codeElement>
Well I dont know whether its a bug or KDM is just not meant to hold that much of information.
If I change message to "hello" inside function println I can see following things:
Java Code:
System.out.println("hello"+newMessage);
Java Model:
<leftOperand xsi:type="java:StringLiteral" originalCompilationUnit="//@compilationUnits.0" escapedValue="&quot;hello&quot;"/>
</arguments>
</expression>
</expression>
</statements>
KDM MOdel
</source>
</source>
<codeElement xsi:type="code:Value" name="string literal" type="//@model.0/@codeElement.1/@codeElement.9" ext="&quot;hello&quot;">
</source>
</codeElement>
</codeElement>
</codeElement>
SO my thoughts are that there is CodeElement missing for newMessage storable unit where infix operation is performed.
If this is a bug I can give try fixing it I know the basics of MDT i guess its some ATL file where i need to do changes. Can you tell me where this file is and how to make changes to it.
Suhrit
Previous Topic:kdm missing some code elements?
Next Topic:Just downloaded Eclipse, what is next?
Current Time: Sat May 25 21:47:45 EDT 2013
Powered by FUDForum. Page generated in 0.01515 seconds
