Home » Newcomers » Newcomers » OutOfMemoryException
OutOfMemoryException [message #656692] Mon, 28 February 2011 07:54 Go to next message
Lekkie  is currently offline Lekkie Friend
Hi all,
I have am outofmemoryexception while running an ant script on my eclipse, how do I resolve this?
Buildfile: D:\Systems Development\Programming\Enterprise Collaboration\Liferay\liferay-portal-trunk\build.xml
all:
clean:
clean:
clean:
clean:
[delete] Deleting directory D:\Systems Development\Programming\Enterprise Collaboration\Liferay\liferay-portal-trunk\portal-service\cl asses
clean:
clean:
clean:
clean:
build-common-java.clean:
build-common-web.clean:
clean:
clean-themes:
clean:
clean:
print-current-time:
[echo] February 27, 2011 at 09:27 AM
start:
compile:
compile:
[mkdir] Created dir: D:\Systems Development\Programming\Enterprise Collaboration\Liferay\liferay-portal-trunk\portal-service\cl asses
[copy] Copying 1 file to D:\Systems Development\Programming\Enterprise Collaboration\Liferay\liferay-portal-trunk\portal-service\cl asses
[copy] Copied 262 empty directories to 204 empty directories under D:\Systems Development\Programming\Enterprise Collaboration\Liferay\liferay-portal-trunk\portal-service\cl asses
[javac] Compiling 3434 source files to D:\Systems Development\Programming\Enterprise Collaboration\Liferay\liferay-portal-trunk\portal-service\cl asses
[javac] ----------
[javac] 1. ERROR in D:\Systems Development\Programming\Enterprise Collaboration\Liferay\liferay-portal-trunk\portal-service\sr c\com\liferay\portlet\social\service\persistence\SocialActiv ityFinderUtil.java (at line 0)
[javac] /**
[javac] ^
[javac] Internal compiler error: java.lang.OutOfMemoryError: Java heap space at org.eclipse.jdt.internal.compiler.util.Util.getInputStreamAs CharArray(Util.java:401)
[javac] ----------
BUILD FAILED
D:\Systems Development\Programming\Enterprise Collaboration\Liferay\liferay-portal-trunk\build.xml:10: The following error occurred while executing this line:
D:\Systems Development\Programming\Enterprise Collaboration\Liferay\liferay-portal-trunk\build.xml:885: The following error occurred while executing this line:
D:\Systems Development\Programming\Enterprise Collaboration\Liferay\liferay-portal-trunk\build.xml:129: The following error occurred while executing this line:
D:\Systems Development\Programming\Enterprise Collaboration\Liferay\liferay-portal-trunk\portal-service\bu ild.xml:30: java.lang.reflect.InvocationTargetException
regards.
Re: OutOfMemoryException [message #656815 is a reply to message #656692] Mon, 28 February 2011 17:10 Go to previous messageGo to next message
Modify the launch to specify JVM arguments (-Xmx<meg>m) for increasing
the heap size.
Lekkie wrote:
> Hi all,
> all:
> clean:
> clean:
> clean:
> clean:
> clean:
> clean:
> clean:
> clean:
> clean:
> clean-themes:
> clean:
> clean:
> print-current-time:
> start:
> compile:
> compile:
> [javac] ----------
> [javac] /**
> [javac] ^
> [javac] ----------
> BUILD FAILED
> regards.
Re: OutOfMemoryException [message #657966 is a reply to message #656692] Fri, 04 March 2011 18:17 Go to previous messageGo to next message
Originally posted by: coolsnoopy.gmx.net
try the following
- launch ant outside eclipse (nearly always the better way..)
- check your script what it does / should do and correct the error
- give more RAM to your process
> Hi all,
> all:
> clean:
> clean:
> clean:
> clean:
> clean:
> clean:
> clean:
> clean:
> clean:
> clean-themes:
> clean:
> clean:
> print-current-time:
> start:
> compile:
> compile:
> [javac] ----------
> [javac] /**
> [javac] ^
> [javac] ----------
> BUILD FAILED
> regards.
Re: OutOfMemoryException [message #690206 is a reply to message #657966] Wed, 29 June 2011 07:18 Go to previous message
Kevin Thomas is currently offline Kevin ThomasFriend
Hello All,
Please check 6 Common Errors in Setting Java Heap Size:
Two JVM options are often used to tune JVM heap size: -Xmx for maximum heap size, and -Xms for initial heap size.
* Missing m, M, g or G at the end (they are case insensitive).
* Extra space in JVM options, or incorrectly use =
* Only setting -Xms JVM option and its value is greater than the default maximum heap size, which is 64m. The default minimum heap size seems to be 0.
* Heap size is larger than your computer's physical memory.
* Incorrectly use mb as the unit, where m or M should be used instead
* The heap size is larger than JVM thinks you would ever need
* The value is not expressed in whole number.
As per my Experience, The error java.lang.OutOfMemoryError: Java heap space where there is no more space available for the Java program.
You should debug application and try to find why your application is taking more space.
You can also increase the Java heap space using following parameters while starting your application:
While running Java program from command line java -Xms5m -Xmx15m yourjavafile
While running tomcat set JAVA_OPTS="-Xms256m -Xmx1024m"
Kevin Thomas
Attune Infocom Inc
Website : attuneinfocom(Dot)com
Email : info@attuneinfocom.com
Liferay Portlet
Previous Topic:Version number not shown when committing under Helios
Next Topic:Eclipse for Java EE doesn't load past Splash Screen
Current Time: Thu Apr 26 06:08:01 GMT 2018
Powered by FUDForum. Page generated in 0.03954 seconds
