Home » Language IDEs » C / C++ IDE (CDT) » CDT installed but invisible on Ubuntu 10.10(Problem using C/C++ dev tools)
icon9.gif  CDT installed but invisible on Ubuntu 10.10 [message #656461] Fri, 25 February 2011 18:44 Go to next message
No real name is currently offline No real nameFriend
I have been using Eclipse with CDT successfully on Windows for several years and recently moved to Ubuntu Linux. I used the standard package manager (Synaptic) to install the eclipse and eclipse-cdt packages (together with other automatically installed packages). After installing everything worked fine, but ever since the first use, all the CDT features are missing. I cannot open the C/C++ perspective (it's not an option), and if I click on a .cpp file, the file opens in the standard OS editor (gedit).
I have tried a complete removal and reinstall, but with the same result. I've also (re-)moved the workspace in case there was something in there causing the problem. If I try and install from the Help/Install new software menu I am allowed to select C/C++ development tools, but on the installation screen I get the message "Eclipse C/C++ Development Tools" will be ignored because it is already installed.
I guess I have something lingering from an old installation but I am not sure where to look.
Has anyone else seen this problem? Any ideas how to fix please?
Software installed:
CDT GNU Toolchain Build Support Source 6.0.0.201002161416
CDT GNU Toolchain Debug Support Source 6.0.0.201002161416
CDT Utilities 5.1.0.201002161416
Eclipse C/C++ Development Tooling Source 6.0.2.201002161416
Eclipse C/C++ Development Tools 6.0.2.201002161416
Eclipse C/C++ Development Tools SDK 6.0.2.201002161416
Eclipse C/C++ DSF gdb Debugger Integration Source 2.0.0.201002161416
Eclipse Platform 3.5.2
Re: CDT installed but invisible on Ubuntu 10.10 [message #656469 is a reply to message #656461] Fri, 25 February 2011 19:29 Go to previous messageGo to next message
David Wegener is currently offline David WegenerFriend
Uninstall everything Eclipse related that you installed from Synaptic. Go to the eclipse.org download page and download the Eclipse for C++ development package. Unzip into a folder on your workstation and run from there.
Also make sure that you are running a Sun/Oracle JDK and aren't using gcj.
The Linux maintained packages should not be used.
Re: CDT installed but invisible on Ubuntu 10.10 [message #656492 is a reply to message #656469] Fri, 25 February 2011 22:00 Go to previous message
Success! Installing from the eclipse.org download site has fixed it.
Many thanks for the rapid response.
Previous Topic:How to refer to a context ID in a different plugin?
Next Topic:CDT shows method prologues taken from .C files
Current Time: Mon Jun 18 21:34:07 GMT 2018
Powered by FUDForum. Page generated in 0.01878 seconds
