Home » Eclipse Projects » Spatiotemporal Epidemiological Modeler (STEM) » Modifiers for Graphs?
Modifiers for Graphs? [message #656267] Thu, 24 February 2011 19:42 Go to next message
Tom Schafer is currently offline Tom SchaferFriend
In the STEM documentation, it states that modifiers can be created for graphs and models, but I can find no details as to how to do this. I have successfully created modifiers for infectors, inoculators, and diseases, but the procedure does not seem to work for models or graphs. Has someone done this sucessfully? Or barring this, is there a way to shut down the air transport network mid-run as a mitigation strategy? Any help would be very much appreciated.
Incidentally, I appreciate the help on the CSV issue - Thanks, Dr. Edlund!
Re: Modifiers for Graphs? [message #656289 is a reply to message #656267] Thu, 24 February 2011 23:02 Go to previous message
Stefan Edlund is currently offline Stefan EdlundFriend
Hi Tom,
modifiers, triggers and predicates are actually still kind of experimental features in STEM, hence there are some limitations. So no, you cannot create a modifier on a graph or model (can you send us a link to the doc so we can fix that?).
Actually, the way we envision you would turn off air transportation would be to create a modifier on the air transport edge inside the graph that controls the number of passengers arriving/departing at particular region daily. That would potentially require lots of modifiers to shutdown everything.
We've also been playing with the idea of a global air transport throttle parameter that you could turn to 0 to shutdown air transportation completely.
Here is a workaround if you really want to see what would happen if you shut down air transport after some number of days:
1. Run and log a simulation with a scenario containing all you air transportation graphs in it.
2. Create a new scenario just like the first one, but remove the air transportation graphs from it as well as any infector/inoculator
3. Create a new infector and inoculator using the log file you just generated from the first scenario. You can do this in the New Infector wizard, by checking the checkbox "Import from STEM log files". In the "Selected row", pick the day you want air transportation to shut down. Drag your new (multi-region) infector and inoculator into your new scenario and run and log the result.
So what does this do? It will initialize your new scenario to the exact state your first simulation was in the day you wanted to shut down air transportation. So by combining the log files from the first and second scenario you get the results you want. Observe that this does not work for model that has the Exposed state in it, like SEIR (we have no way of initializing that).
/ Stefan
Previous Topic:Modifiers for Graphs
Next Topic:EclipseCon 2011
Current Time: Wed Jun 20 21:27:14 GMT 2018
Powered by FUDForum. Page generated in 0.02424 seconds
