Home » Language IDEs » AJDT » Can't see advice being applied
Can't see advice being applied [message #655997] Wed, 23 February 2011 16:59 Go to next message
Eike Stepper is currently offline Eike StepperFriend
I'm making my first steps with ApsectJ and AJDT. Not very successful so far ;-(
In my workspace I have plugin projects with my source code and I added an "aspects" project (also a plugin). I added one aspect:
package aspects;
import org.eclipse.emf.cdo.spi.common.revision.BaseCDORevision;
public aspect Universe
before() : execution(* BaseCDORevision.*(..)) { bang(); }
private static void bang() { System.err.println("=== BANG! ==="); }
The AJDT Event Trace view shows this:
17:55:34 ============================================================ ===============================
17:55:34 Build kind = AUTOBUILD
17:55:34 Project=aspects, kind of build requested=Incremental AspectJ compilation
17:55:34 Timer event: 0ms: Flush included source file cache
17:55:34 Timer event: 0ms: Check delta
17:55:34 File: C:\develop\ws\aspectj\aspects\src\aspects\Universe.aj has changed.
17:55:34 build: Examined delta - 1 changed, 0 added, and 0 deleted source files in required project aspects
17:55:34 Timer event: 1ms: Looking for and marking configuration changes in aspects
17:55:34 Configuration changes found: true
17:55:34 Timer event: 1ms: Look for source/resource changes
17:55:34 Setting list of classpath elements with modified contents:
17:55:34 [C:/develop/ws/aspectj/plugins/org.eclipse.net4j.tcp/bin, C:/develop/ws/aspectj/plugins/org.eclipse.net4j.util/bin, C:/develop/ws/aspectj/plugins/org.eclipse.net4j/bin, C:/develop/ws/aspectj/plugins/org.eclipse.emf.cdo.server/bin , C:/develop/ws/aspectj/plugins/org.eclipse.emf.cdo.common/bin , C:/develop/ws/aspectj/plugins/org.eclipse.emf.cdo.server.net 4j/bin]
17:55:34 Timer event: 46ms: Pre compile
17:55:34 Sending the following configuration changes to the compiler: []
17:55:34 1 source file changes since last build
17:55:34 Compiler configuration for project aspects has been read by compiler. Resetting.
17:55:34 Configuration was []
17:55:34 Resetting list of modified source files. Was [C:\develop\ws\aspectj\aspects\src\aspects\Universe.aj]
17:55:34 ClassFileChangeChecking: failed to find a state instance managing output location : C:\develop\ws\aspectj\plugins\org.eclipse.net4j.tcp\bin
17:55:34 ClassFileChangeChecking: queried JDT and 'C:\develop\ws\aspectj\plugins\org.eclipse.net4j.tcp\bin' is apparently unchanged so not performing timestamp check
17:55:34 ClassFileChangeChecking: failed to find a state instance managing output location : C:\develop\ws\aspectj\plugins\org.eclipse.net4j.util\bin
17:55:34 ClassFileChangeChecking: queried JDT and 'C:\develop\ws\aspectj\plugins\org.eclipse.net4j.util\bin' is apparently unchanged so not performing timestamp check
17:55:34 ClassFileChangeChecking: failed to find a state instance managing output location : C:\develop\ws\aspectj\plugins\org.eclipse.net4j\bin
17:55:34 ClassFileChangeChecking: queried JDT and 'C:\develop\ws\aspectj\plugins\org.eclipse.net4j\bin' is apparently unchanged so not performing timestamp check
17:55:34 ClassFileChangeChecking: failed to find a state instance managing output location : C:\develop\ws\aspectj\plugins\org.eclipse.emf.cdo.server\bin
17:55:34 ClassFileChangeChecking: queried JDT and 'C:\develop\ws\aspectj\plugins\org.eclipse.emf.cdo.server\bi n' is apparently unchanged so not performing timestamp check
17:55:34 ClassFileChangeChecking: failed to find a state instance managing output location : C:\develop\ws\aspectj\plugins\org.eclipse.emf.cdo.common\bin
17:55:34 ClassFileChangeChecking: queried JDT and 'C:\develop\ws\aspectj\plugins\org.eclipse.emf.cdo.common\bi n' is apparently unchanged so not performing timestamp check
17:55:34 ClassFileChangeChecking: failed to find a state instance managing output location : C:\develop\ws\aspectj\plugins\org.eclipse.emf.cdo.server.net 4j\bin
17:55:34 ClassFileChangeChecking: queried JDT and 'C:\develop\ws\aspectj\plugins\org.eclipse.emf.cdo.server.ne t4j\bin' is apparently unchanged so not performing timestamp check
17:55:34 Preparing for build: planning to be an incremental build
17:55:34 Starting incremental compilation loop 1 of possibly 5
17:55:34 Timer event: 303ms: Time to first compiled message
17:55:34 Dropping back to full build
17:55:34 Preparing for build: not going to be incremental because no successful previous full build
17:55:35 Timer event: 735ms: Time to first woven message
17:55:35 AspectJ reports build successful, build was: FULL
17:55:35 AJDE Callback: finish. Was full build: true
17:55:35 Timer event: 1588ms: Total time spent in AJDE
17:55:35 Timer event: 0ms: Refresh after build
17:55:35 Types affected during build = 1133
17:55:35 Timer event: 1638ms: Total time spent in AJBuilder.build()
17:55:35 Timer event: 5ms: Delete markers: aspects (Finished deleting markers for aspects)
17:55:35 Timer event: 0ms: Create markers: aspects (Finished creating markers for aspects)
17:55:35 Created 0 markers in 1 files
17:55:35 Timer event: 0ms: Update visualizer, xref, advice listeners for (separate thread): aspects
But in the class BaseCDORevision.java I can not see any advice markers, nor is "=== BANG! ===" output when I start the program.
I have no clue where to start. Please help ;-)
Cheers
/Eike
http://www.esc-net.de
Re: Can't see advice being applied [message #656004 is a reply to message #655997] Wed, 23 February 2011 17:14 Go to previous messageGo to next message
When I copy the BaseCDORevision.java file into the "aspects" project I can see that the advice is properly applied.
Shouldn't the aspect be applied to source in other (plugin) projects, as well?
Cheers
/Eike
Am 23.02.2011 17:59, schrieb Eike Stepper:
> package aspects;
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
Re: Can't see advice being applied [message #656084 is a reply to message #656004] Thu, 24 February 2011 04:15 Go to previous messageGo to next message
Andrew Eisenberg is currently offline Andrew EisenbergFriend
Since you are creating Eclipse plugins, standard compile time aspectj will not work, instead, you must use Equinox Weaving:
http://www.eclipse.org/equinox/incubator/aspects/
This is the only way to get AspectJ working across bundles in an OSGi environment. You already have Equinox weaving installed because you are using AJDT. The documentation is a little outdated, but you should start by looking at the quick start guide and send any questions to this forum.
http://www.eclipse.org/equinox/incubator/aspects/equinox-asp ects-quick-start.php
Re: Can't see advice being applied [message #656089 is a reply to message #656084] Thu, 24 February 2011 06:39 Go to previous message
Am 24.02.2011 05:15, schrieb Andrew Eisenberg:
A lot of steps to follow but finally it's working now. Thank you very much!
Cheers
/Eike
Previous Topic:Need to skip an Entrust jar file during weaving
Next Topic:No development time feedback with Equinox Aspects?
Current Time: Sun May 27 16:05:28 GMT 2018
Powered by FUDForum. Page generated in 0.01570 seconds
