Home » Modeling » Modeling (top-level project) » How does eclipse resolve model URI's?
icon5.gif  How does eclipse resolve model URI's? [message #654823] Thu, 17 February 2011 05:11 Go to next message
Wilbert Alberts is currently offline Wilbert Alberts
Member
I'm having problems understanding how eclipse resolves model uri's.
Case: I have created an ecore model in project A. Then I create a dynamic instance of an entity and store the resulting (instance) model in a folder of project B. I can edit it using the sample reflective editor. However, if I close eclipse and restart it, any attempt to open the instance model using the samlple reflective editor results in error messages stating:
org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'http://asml_platform.fc25.asml.com/0.1.0' not found.
However, when I use the metamodel explorer, it shows that the metamodel (with the proper uri) is known in the workspace.
The instance model, stored as an xmi file, contains a schema location attribute referring to the meta model (using its uri).
Any hints,
Wilbert
Re: How does eclipse resolve model URI's? [message #655633 is a reply to message #654823] Mon, 21 February 2011 22:23 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
Wilbert,
Comments below.
Wilbert Alberts wrote:
I'm not sure which project provides a metamodel explorer.
I would have expected it to use the physical location, i.e., a
platform:/resource URI. That's what the EMF Core framework would do.
Maybe you're using a wizard provided by some other project, in which
case it's best to ask on that project's specific newsgroup...
> Any hints,
> Wilbert
Re: How does eclipse resolve model URI's? [message #715028 is a reply to message #654823] Fri, 12 August 2011 03:17 Go to previous message
djozef87 is currently offline djozef87
Hi Wilbert,
Did you solve this problem ?
I have the same error message and i don't find a solution.
Thanks in advance,
Youssef
Previous Topic:Visual model of struts-config.xml
Next Topic:Use attributes in model validation messages
Current Time: Mon May 20 16:49:38 EDT 2013
Powered by FUDForum. Page generated in 0.01618 seconds
