Home » Modeling » M2T (model-to-text transformation) » [Acceleo] eliminate warnings([Acceleo] eliminate warnings)
[Acceleo] eliminate warnings [message #654814] Thu, 17 February 2011 09:45 Go to next message
olafo987  is currently offline olafo987 Friend
Hello
First, I apologize for my poor Inglish.
I'm working at one project with "Acceleo" and I have the need of eliminate multiples "warnings" that I have. I have very code as this:
[query public hasParameterTypeByName(c : Class, parameterName : String) : Boolean = (c.ownedOperation->asSequence()->collect(ownedParameter)->select(p : Parameter | p.type.name.equalsIgnoreCase(parameterName))->size() > 0) /]
[template public templateImportsSpecialsParameters(c : Class) post (trim())]
[if (c.hasParameterTypeByName('BigDecimal'))]
import java.math.BigDecimal;
[/if]
[if (hasParameterTypeByName(c, 'DataHandler'))]
import javax.activation.DataHandler;
[/if]
[if (hasParameterTypeByName(c, 'Document'))]
import org.w3c.dom.Document;
[/if]
[if (hasParameterTypeByName(c, 'Timestamp'))]
import java.sql.Timestamp;
[/if]
[if (hasParameterTypeByName(c, 'Calendar'))]
import java.util.Calendar;
[/if]
[if (hasParameterTypeByName(c, 'Date'))]
import java.util.Date;
[/if]
[if (hasParameterTypeByName(c, 'EmptyBean'))]
import gnf.ada.core.service.EmptyBean;
[/if]
[if (hasParameterTypeByName(c, 'Map'))]
import java.util.HashMap;
[/if]
[if (hasParameterList(c) or hasOperationReturnLis(c))]
import java.util.ArrayList;
[/if]
[if (hasSerializable(c))]
import java.io.Serializable;
[/if]
[/template]
And the warning that leaving is:
Invalid result for expression c.ownedOperation->asSequence()->collect(temp2 : Operation | temp2.ownedParameter)->select(p : Parameter | p.type.name.equalsIgnoreCase(parameterName))->size().>(0) at line 57 in Module common for query hasParameterTypeByName(Class,String). Last recorded value of self was org.eclipse.uml2.uml.internal.impl.ClassImpl@179a5d (name: MantPropertyTypeService, visibility: <unset>) (isLeaf: false, isAbstract: false) (isActive: false).
That strategy I can use to eliminate this warnings?
Thank in advance for you reply
Juan Carlos
PD: Repito el post because no aparece el primero.
Re: [Acceleo] eliminate warnings [message #654887 is a reply to message #654814] Thu, 17 February 2011 14:08 Go to previous message
Laurent Goubet is currently offline Laurent GoubetFriend
--------------020900030304010106020607
Content-Type: text/plain; charset=UTF-8; format=flowed
Hi Juan,
This error message means that somewhere in the course of evaluating
"c.ownedOperation->asSequence()->collect(ownedParameter)->select(p :
Parameter | p.type.name.equalsIgnoreCase(parameterName))->size() > 0",
one of the objects was null. So I'd say that you either have a
Collection with a Parameter that doesn't have a type, or a type with no
name (check the class MantPropertyTypeService first as it seem to be the
culprit).
If you open your model, right-click the root and use "validate", do you
get any error reported?
Otherwise, you'll have to manually check that all of your operations
have the right kind of parameters, or defend against the issue within
Acceleo itself :
> Parameter | if (not (p.type.oclIsUndefined() or
p.type.name.oclIsUndefined())) then
p.type.name.equalsIgnoreCase(parameterName) else false endif)->size() > 0
Laurent Goubet
Obeo
On 17/02/2011 10:45, olafo987 wrote:
> Hello First, I apologize for my poor Inglish.
> : Boolean =
> (trim())]
> [/if]
> [/if]
> [/if]
> [/if]
> [/if]
> [/if]
> [/if]
> [/if]
> [/if]
> [/if]
> [/template]
> mailto:org.eclipse.uml2.uml.internal.impl.ClassImpl@179a5d (name:
> Juan Carlos
Content-Type: text/x-vcard; charset=utf-8;
name="laurent_goubet.vcf"
Content-Disposition: attachment;
filename="laurent_goubet.vcf"
YmVnaW46dmNhcmQNCmZuOkxhdXJlbnQgR291YmV0DQpuOkdvdWJldDtMYXVy ZW50DQpvcmc6
PGEgaHJlZj0iaHR0cDovL3d3dy5vYmVvLmZyIj5PYmVvPC9hPg0KZW1haWw7 aW50ZXJuZXQ6
bGF1cmVudC5nb3ViZXRAb2Jlby5mcg0KdXJsOmh0dHA6Ly93d3cub2Jlby5m cg0KdmVyc2lv
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------020900030304010106020607--
Previous Topic:[Acceleo] eliminate warnings
Next Topic:[Acceleo] Problems about queries
Current Time: Fri Jan 19 13:52:53 GMT 2018
Powered by FUDForum. Page generated in 0.02610 seconds
