Home » Newcomers » Newcomers » Question about package in Eclipse
Question about package in Eclipse [message #654734] Wed, 16 February 2011 21:08 Go to next message
Teal_Candle is currently offline Teal_CandleFriend
Try to keep this simple. So I create helloWorld in Eclipse. Runs and compiles just fine in Eclipse. Here is what the looks like:
package Folder1.Folder2.Folder3
* @author Teal_Candle
public class helloWorld
* @param args
public static void main(String[] args)
// TODO Auto-generated method stub
System.out.println("Can you see me?");
Now when I trying running this in cmd in Windows, it gives me the following error:
Exception in thread "main" java.lang.NoClassDefFoundError: Folder1/Folder2/Folder3/h
elloWorld
Caused by: java.lang.ClassNotFoundException: Folder1.Folder2.Folder3.helloWorld
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
Could not find the main class: Folder1.Folder2.Folder3.helloWorld. Program will exi
t.
However if I take the package Folder1.Folder2.Folder3; out of the beginning of my file, Eclipse throws an error saying its expecting a package, however if I save the file and compile outside of eclipse it then runs fine.
How do I run this simple program cmd? And before anyone suggest to just move this file to the root folder of the project, that won't work for the project I'm working on, I need to be able to separate all this mini little programs into different folders.
Any help would be highly appreciated!!!
Teal_Candle
Re: Question about package in Eclipse [message #654739 is a reply to message #654734] Wed, 16 February 2011 21:49 Go to previous messageGo to next message
Olivier Thomann is currently offline Olivier ThomannFriend
Do you have the current folder on the classpath ?
How do you invoke this class from the command line ?
Olivier
Re: Question about package in Eclipse [message #654740 is a reply to message #654734] Wed, 16 February 2011 21:50 Go to previous message
Russell Bateman is currently offline Russell BatemanFriend
On 16-Feb-11 14:09, Teal_Candle wrote:
> [snip]
> following error:
> Folder1/Folder2/Folder3/helloWorld
> at java.security.AccessController.doPrivileged(Native Method)
> at java.lang.ClassLoader.loadClass(Unknown Source)
> Program will exit.
You've not created a "runnable" JAR, right? You can't generate a common
("library") JAR and run it. Use File -> Export -> Java -> Runnable JAR
File... see if you can't figure it out from there. (Or, did you do this
and I'm just not reading your problem?)
> then runs fine.
> [snip]
As long as your Java file is down inside a package, the package
statement at the top of the file must match the package it's in.
Russ
Previous Topic:Possible Documentation Bug?
Next Topic:can 2 plugins have same key bindings
Current Time: Fri Jun 22 00:19:12 GMT 2018
Powered by FUDForum. Page generated in 0.03843 seconds
