Home » Newcomers » Newcomers » Can't see Error Boxes on Right hand side panel(Bad tags)
icon6.gif  Can't see Error Boxes on Right hand side panel [message #654627] Wed, 16 February 2011 09:19 Go to next message
Sean  is currently offline Sean
I am running:
Version: Helios Service Release 1
Build id: 20100917-0705
I use to run the older version and I had the ability to see the color boxes along the right hand side panel for bad tags, But I don't see this on this version.
Re: Can't see Error Boxes on Right hand side panel [message #655063 is a reply to message #654627] Fri, 18 February 2011 03:33 Go to previous message
David Largeteau is currently offline David Largeteau
Member
Sean a écrit :
> I am running:
> on this version.
Hi Sean,
It depends on files type (some editors does not handle annotations).
Make sure to use an editor that handles annotations (use "Open With"
menu to choose the editor you want to use).
In Windows / Preferences / General / Editors / Text Editors /
Annotations, you can customize annotations, checking if they must be
displayed in "Overview ruler" (your right hand panel).
Hope this help
David
Previous Topic:Howto change size of pop-up dialogs
Next Topic:TODO / FIXME not listed in task list
Current Time: Fri May 24 01:57:45 EDT 2013
Powered by FUDForum. Page generated in 0.09215 seconds
