Home » Eclipse Projects » Rich Client Platform (RCP) » [Bindings] Removing a key-binding
[Bindings] Removing a key-binding [message #654605] Wed, 16 February 2011 13:31 Go to next message
Daniel Krügler is currently offline Daniel KrüglerFriend
Actually, redefining a key binding is easy by providing a ney key
extension for the extension point org.eclipse.ui.bindings. Now I have
the following problem: Sometimes a pre-defined key-binding is just ugly,
e.g. I consider the pre-defined key-binding for the CollapseAll handler
as "ugly", "M1+M2+NUMPAD_DIVIDE" is just a mess. In this case it would
be ideal for us, if this Handler would not provide *any* key-binding at
all. But according to the extension point definition
org.eclipse.ui.bindings#key the value is required. Does there exist an
officially supported mechanism to remove a key-binding or replacing it
my something that corresponds to 'no-binding-at-all' magic?
Thanks & Greetings from Bremen,
Daniel Krügler
Re: [Bindings] Removing a key-binding [message #654712 is a reply to message #654605] Wed, 16 February 2011 18:54 Go to previous messageGo to next message
Paul Webster is currently offline Paul WebsterFriend
You cannot mark a command that way, but you can delete a specific
keybinding in a specific context:
copy out the Collapse All keybinding, and simply remove the commandId
.... that will wipe out that binding.
But with a delete marker at the same level provided by a plugin.xml
(considered SYSTEM) only users would be able to bind that key sequence
to something more useful (with a few minor exceptions)
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: [Bindings] Removing a key-binding [message #654800 is a reply to message #654712] Thu, 17 February 2011 08:41 Go to previous messageGo to next message
OK, that worked, thanks!
I have problems to follow you here, could you elaborate, please?
1) Is the "delete marker" the above mentioned keybinding registration
that omits the commandId?
2) I don't understand, in which sense "SYSTEM" and "users" are entering
the game here.
Do you want to describe that by doing above effective removal of the
key-binding "M1+M2+NUMPAD_DIVIDE" I can never reassign this binding to
another command?
- Daniel Krügler
Re: [Bindings] Removing a key-binding [message #654884 is a reply to message #654800] Thu, 17 February 2011 13:57 Go to previous messageGo to next message
yes
> the game here.
Anything that comes in through plugin.xml is SYSTEM. Anything changed
in the keys preference page is USER.
> another command?
right now you have:
binding1: M1+M2+NUMPAD_DIVIDE collapseAll
org.eclipse.ui.contexts.window
org.eclipse.ui.defaultAcceleratorConfiguration SYSTEM
binding2: M1+M2+NUMPAD_DIVIDE <delete-no-id>
binding2 will delete any bindings that match the other attributes (same
scheme, same context, same key sequence, etc).
It just means that you can't re-assign it in your plugin.xml to another
command in org.eclipse.ui.contexts.window
PW
Paul Webster
Re: [Bindings] Removing a key-binding [message #654908 is a reply to message #654884] Thu, 17 February 2011 14:52 Go to previous message
> yes
>> the game here.
> Anything that comes in through plugin.xml is SYSTEM. Anything changed in
OK, I understand - even though I never have looked at it with such roles
in my mind.
>> another command?
> right now you have:
> binding1: M1+M2+NUMPAD_DIVIDE collapseAll org.eclipse.ui.contexts.window
Thanks for your thorough explanation, Paul - it was very helpful.
- Daniel
Previous Topic:Master/Detail with Interface
Next Topic:Migrating from 3.3 to 3.6
Current Time: Wed May 23 20:59:23 GMT 2018
Powered by FUDForum. Page generated in 0.02075 seconds
