| Missing Theme error in Workbench [message #654575] |
Wed, 16 February 2011 06:29  |
Mike Procter Messages: 1 Registered: February 2011 |
Junior Member |
I have recently installed Eclipse IDE for Java Developers (Version: Helios Service Release 1, Build id: 20100917-0705) with the latest SDK Platform Android plugin - on Windows 7.
I can add, edit and run code for projects, however, in the Workbench area the Graphical Layout view of the layout xml files always shows a "missing theme" message in bottom right navigation area.The left Palette navigator area is ok and the remaining area is blank.
The error message reads: "Selecting page '0' in AndroidXmlEditor failed"
The first and last 10 lines from the Exception Stack Trace reads:
at com.android.ide.eclipse.adt.internal.editors.layout.gle2.Gra phicalEditorPart.renderWithBridge(Unknown Source)
at com.android.ide.eclipse.adt.internal.editors.layout.gle2.Gra phicalEditorPart.recomputeLayout(Unknown Source)
at com.android.ide.eclipse.adt.internal.editors.layout.gle2.Gra phicalEditorPart.activated(Unknown Source)
at com.android.ide.eclipse.adt.internal.editors.layout.LayoutEd itor.pageChange(Unknown Source)
at org.eclipse.ui.part.MultiPageEditorPart.setActivePage(MultiP ageEditorPart.java:1067)
at org.eclipse.ui.forms.editor.FormEditor.setActivePage(FormEdi tor.java:607)
at com.android.ide.eclipse.adt.internal.editors.AndroidXmlEdito r.selectDefaultPage(Unknown Source)
at com.android.ide.eclipse.adt.internal.editors.AndroidXmlEdito r.addPages(Unknown Source)
at org.eclipse.ui.forms.editor.FormEditor.createPages(FormEdito r.java:138)
at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditorPart.java:348)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
Any assistance in resolving would be appreciated
| Re: Missing Theme error in Workbench [message #654658 is a reply to message #654575] |
Wed, 16 February 2011 10:12  |
Eric Rizzo Messages: 2011 Registered: July 2009 |
Android has it's own developer forums; you should ask there. This is not
an Eclipse issue per se, but rather a problem with the Android plugins
that run on Eclipse.
Eric
> java.lang.NullPointerException
> tor.java:607)
> tarter.java:369)
> tarter.java:179)
FUDForum. Page generated in 0.01545 seconds
