Home » Eclipse Projects » EclipseLink » Does deleting a relationsip remove the dependant object from the database?
Does deleting a relationsip remove the dependant object from the database? [message #654540] Wed, 16 February 2011 09:16 Go to next message
Tony Dietrich is currently offline Tony DietrichFriend
If I have the classic Person entity object, with associated TelephoneNumber objects in a OneToMany relationship, does loading the relationship collection of the parent Person object, then deleting one of the TelephoneNumber objects from this collection and merging the parent object back to the database trigger the deletion of that TelephoneNumber from the database, assuming I have orphanRemoval=true ?
class Person{
@OneToMany(mappedBy="telephone", cascade=CascadeType.ALL, orphanRemoval=true)
private Collection<TelephoneNumber> telephoneNumberCollection;
Person p=personFacade.getPersonForID(id);
List<TelephoneNumber> lst=p.getTelephoneNumberCollection();
For(TelephoneNumber t:lst){
if(t.getName().equals("Home") lst.remove(t);
personFacade.merge(p);
Will this pseudocode result in the removal from the database of the 'Home' telephone number?
Re: Does deleting a relationsip remove the dependant object from the database? [message #654558 is a reply to message #654540] Wed, 16 February 2011 09:27 Go to previous messageGo to next message
Tom Eugelink is currently offline Tom EugelinkFriend
You only delete something if you execute the remove method of an entity manager. It may very well be possible that this cascades the delete to other entities (this is what the CascadeType is for).
Your code only removes an object from a collection, not from the database.
Tom
> class Person{
Re: Does deleting a relationsip remove the dependant object from the database? [message #654561 is a reply to message #654558] Wed, 16 February 2011 10:20 Go to previous messageGo to next message
Would it have any effect if I included
p.setTelephoneNumberCollection(lst);
I'm looking at
http://en.wikibooks.org/wiki/Java_Persistence/Relationships# Orphan_Removal_.28JPA_2.0.29
which implies that this deletion is specified by JPA 2.0 in circumstances where the dependant object is no longer referenced by the parent object.
Would de-referencing require that the reference is removed on both ends of the relationship though?
If I adopt the alternative approach (specifically deleting the dependant object using EntityManager.remove), is the parent collection automatically updated or do I have to force a refresh?
[Updated on: Wed, 16 February 2011 10:23]
Report message to a moderator
Re: Does deleting a relationsip remove the dependant object from the database? [message #654615 is a reply to message #654561] Wed, 16 February 2011 13:48 Go to previous messageGo to next message
Nope. Something like lEntityManager.remove(t); would help.
> I'm looking at http://en.wikibooks.org/wiki/Java_Persistence/Relationships# Orphan_Removal_.28JPA_2.0.29
Re: Does deleting a relationsip remove the dependant object from the database? [message #654616 is a reply to message #654561] Wed, 16 February 2011 13:49 Go to previous messageGo to next message
Or, if you do not intend to delete it but simple break the relationship, setting the owning side of the relation. Probably something like lst.setPerson(null);
Re: Does deleting a relationsip remove the dependant object from the database? [message #654617 is a reply to message #654616] Wed, 16 February 2011 13:56 Go to previous messageGo to next message
Thanks for your input Tom Smile
Re: Does deleting a relationsip remove the dependant object from the database? [message #654619 is a reply to message #654561] Wed, 16 February 2011 14:00 Go to previous messageGo to next message
Chris Delahunt is currently offline Chris DelahuntFriend
Hello Tony,
Yes, OrphanRemoval will result in PhoneNumbers being deleted from the database when they are no longer referenced from Person. The code in the first post should work, and there is no need to call p.setTelephoneNumberCollection(lst) as you are manipulating the collection already. EntityManager.remove(t) should not be needed - be sure that nothing else references t though, and especially not with a cascade persist/merge relationship, as this will leave your cache inconsistent with the database and potentially cause the object to be resurected later on.
What Tom mentioned is correct when OrphanRemoval or PrivateOwnership (native EclpseLink) is not used.
Best Regards,
Chris
[Updated on: Wed, 16 February 2011 14:03]
Re: Does deleting a relationship remove the dependant object from the database? [message #654637 is a reply to message #654619] Wed, 16 February 2011 14:36 Go to previous messageGo to next message
I hope so.
Running a test now, I'll let you know if it works.
Re: Does deleting a relationsip remove the dependant object from the database? [message #654669 is a reply to message #654617] Wed, 16 February 2011 15:57 Go to previous message
On 16-2-2011 14:56, Tony Dietrich wrote:
> Thanks for your input Tom :)
You're welcome. Just trying to give something back for such a great free(!) software library.
Previous Topic:EclipseLink & Cell Names with White Space
Next Topic:Incorrect PostgreSQL's BLOB support in EclipseLink JPA
Current Time: Thu Apr 19 13:15:35 GMT 2018
Powered by FUDForum. Page generated in 0.02168 seconds
